Old 09-30-2013, 11:07 AM   #6301
higher_ground
Oddometer: 5
Originally Posted by Darknessprevails View Post
i always have had the fear of my bike getting jacked. more so with how light it is. sorry to hear man : (
did you have any kind of insurance full coverage or something that might help in a situation like that?
Yeah, they took it during the day in a relatively busy residential area. Unfortunately I was too cheap to get the comprehensive coverage... actually it was not even offered to me, I've been told you often have to specifically request it. Anyway, lesson learned.
higher_ground is offline   Reply With Quote
Old 09-30-2013, 12:17 PM   #6302
Darknessprevails
Oddometer: 26
that was my first question : ) with as cheap as it was i couldn't pass up 200 for a year!!
2013 CRF250l
Darknessprevails is offline   Reply With Quote
Old 09-30-2013, 12:34 PM   #6303
callison
callison's Avatar
Oddometer: 120
What do you mean by rear fender assembly?
I've got the license plate holder monstrosity, you're welcome to it if you don't mind paying the shipping.
Cory
callison is offline   Reply With Quote
Old 09-30-2013, 01:33 PM   #6304
higher_ground
Oddometer: 5
I mean the whole thing.. license plate holder, rear tail light, rear turn signals, etc.
Old 10-01-2013, 06:13 AM   #6305
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 395
modification done
Oil change , Valve check , and Grease on all the necessary places done.
YSS Shock and Dunlop D605 are big improvement in the handling ,
as FMF ,13T and EJK on the Power
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 10-01-2013, 10:18 AM   #6306
Lapchik
Tinkeritis posterboy
Lapchik's Avatar
Oddometer: 395
Where did you get that grey exhaust cover?
Lapchik is offline   Reply With Quote
Old 10-01-2013, 10:52 AM   #6307
Schrauberklaus
***ifyer
Oddometer: 395
Thats one off the real Carbon Parts that Honda Big Wing Bangkok sell for the CRF
Klaus
Old 10-01-2013, 10:59 AM   #6308
gvcrt
Oddometer: 13
Originally Posted by Schrauberklaus View Post
modification done
Hiya mate could you let me know where you got the graphics and rear carrier from thanks
gvcrt is offline   Reply With Quote
Old 10-01-2013, 02:12 PM   #6309
Bolty
Señor Member
Bolty's Avatar
Oddometer: 42
Thanks for all that Cory, Just done my bike this morning and did the swingarm pivot too. (it was completely missing any goodies from the grease fairy BTW)
I didn't know what to torque the pivot axle to so I guessed at 120Nm
Doing all this along with the wheels took no more than a couple of hours and it is something that if you're handy with a spanner, then you should really get it done as there was no grease at all on the axles and bolts and just the smallest amount of grease on the needle bearings, if you're not handy with the spanners then pay someone to do it for you!
I also checked out the fasteners on the rear chainwheel, I managed to undo all but one of them which appeared to be made of some kind of cheese based substance, all bar this one have been removed and copperslipped so at least I know that come chainwheel change time I should only have to drill the one unless I get access to a 12 volt impact driver to ease the damaged one out.
Shock Linkage Service
Diss assembly
  • Remove brake return spring (1)
  • Remove bolts 2 - 5
Maintenance
  • Check for worn grease seals
  • Grease each needle bearing
  • Grease pivot bushings before reinserting into linkage
  • Grease bolts before putting things back together
Assembly
  • Reinstall bolts in reverse order
  • Service manual recommends putting a drop of motor oil on the threads of bolt 5 before torquing to spec
  • I used a dab of blue thread lock on each nut before torquing to spec
  • Reconnect brake return spring (1)
Torque Specs:
  • Bolt 2 - 32lb ft
  • Bolt 3 - 32lb ft
  • Bolt 4 - 32lb ft
  • Bolt 5 - 55lb ft
1997 RD-07A Africa Twin (3rd consecutive owner from the XRV.org.uk forum)
2013 CRF250L EJK, Decat'd standard exhaust, DNA Air filter, 13t sprocket and Speedo DRD.
Bolty is offline   Reply With Quote
Old 10-01-2013, 03:20 PM   #6310
SAPB
SAPB's Avatar
Oddometer: 1,661
Swingarm pivot nut 88 Nm.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is online now   Reply With Quote
Old 10-01-2013, 03:24 PM   #6311
Bolty
Señor Member
Bolty's Avatar
Oddometer: 42
Doh!
I'll not be riding the bike until next week now so it'll stay as it is until then but thanks for that SAPD, Honda UK don't have the workshop manual available yet and I refuse to buy one from the states and pay as much or more in postage than the book actually costs!
Old 10-01-2013, 03:39 PM   #6312
SAPB
SAPB's Avatar
Oddometer: 1,661
Doh!
After I got one from Helm, the price came down right through the dealer, talk about Doh!
Old 10-01-2013, 07:22 PM   #6313
Schrauberklaus
***ifyer
Oddometer: 395
Hi
The graphics come from a small Printshop in Bangkok
I work out the design 10 Days ago as i visit them .
they have many more , see
http://crfthailand.com/forum/index.p...1&topic=2680.0
2900 THB ~ 93USD/57GPB for the complete set inc. EMS to Phuket after they print it .
You can email JOY at
shopitart@gmail.com
to work out your owen design
No info from the rear Rack , its from a local modify shop .
They had only one .
No manufactorer Label , see it , buy it for 15 Euro
It happen that a Friend from Manchester will be here near Bangkok next
month until christmas . PN me if you interestet maybe we can work out something .
Klaus
Old 10-01-2013, 08:31 PM   #6314
Bicyclist
Bicyclist's Avatar
Oddometer: 530
I did this project the other day and while I was at it, I put anti-seize on all of the exhaust system fasteners. The cylinder head studs are most important.
The link bearings on my bike weren't too bad, but the swingarm bearings had almost no grease in them. It's worth the time to do this service.
Bicyclist is offline   Reply With Quote
Old 10-02-2013, 12:45 AM   #6315
Turk
'Bab Man
Turk's Avatar
Oddometer: 126
While we're on the topic, how big/heavy is the service manual? I have a friend coming over from DC who is kindly bringing some parts already for me. If the manual is a reasonable size and weight I will have one sent to her house, however if it's anything like the Haynes manual for my GS I'll be taking the piss...
Turk is offline   Reply With Quote
Times are GMT -7.   It's 05:15 PM.
