Old 10-12-2013, 02:19 PM   #6406
shua
plays in snow
shua's Avatar
Oddometer: 225
Anybody do a fuel injection controller without an aftermarket silencer?
shua is offline   Reply With Quote
Old 10-12-2013, 02:37 PM   #6407
SAPB
SAPB's Avatar
Oddometer: 1,615
Originally Posted by Auto-X Fil View Post
My weight report:
MT43 rear
MT21 front
Dirt Bagz Ranger bags
Tool kit (lots of stuff) in a Tool Tube
Cycra CRM handguards
IMS tank, full of 3gal+ fuel
Charcoal canister removed
Stock tool box removed
335lb. Porky!
FYI, my IMS tank took 2.950 gal after I ran it down until it died, the added 1/4 gal to get to the gas station. So, 3.1 gal seems just right.
When you swapped to the MT43, did you put in a rim lock? I've read that all the magic happens when it's aired down. After the D606 is toast, that is my next tire.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 10-12-2013, 03:05 PM   #6408
Auto-X Fil
Oddometer: 684
Yes, I have a single rim lock front and rear. I run as low as 6-8 psi when really getting into the gnarly stuff. 10-12 works pretty well too, and feels ok on the street for short jaunts. Dirt/paved commuting I run 18-22psi.
Auto-X Fil is offline   Reply With Quote
Old 10-12-2013, 03:46 PM   #6409
SAPB
SAPB's Avatar
Oddometer: 1,615
Thanks! And probably the original front will be just about gone by that time. I like having tires on hand before I actually need them. How would you rate the MT21 front, mostly off road compared to the IRZ? Even though my dirt/road has been more more like road/dirt, I still would prefer to have a great tire for off road, and just live with what it's like on road. 7,500 miles on mine now, throw the dealer the last oil/filter change next week for the 8K, and my 12 month is over end of Dec. Not seeing much sense in extending the warranty. Anyone else's opinion on that?
Old 10-12-2013, 09:21 PM   #6410
kiwi5
Oddometer: 385
Yup, definately helps, and changing to a 10w-40 Motul semi synthetic was a great improvement as well. Along with a 13t front sprocket ....and MotoZ Desert HT front.... And a Michelin t63 rear....!!
kiwi5 is offline   Reply With Quote
Old 10-13-2013, 05:39 AM   #6411
Auto-X Fil
Oddometer: 684
The MT21 is phenomenal. It's massive improvement over the stock front. It byes better in mud, grass, and other loose stuff, but the biggest improvement is stopping power on dirt roads, hard pack trails, and rocks. It feels almost like to could stoppie on those surfaces, which is very confidence-inspiring.
It wears very fast. I don't think I'll get any more than 2.5-3k out of it. It's only got 980 miles on it and it is wearing so much I need to flip it already. And it's expensive. But, I'll keep buying them for sure.
Old 10-13-2013, 08:17 AM   #6412
shua
plays in snow
shua's Avatar
Oddometer: 225
That's good to hear. It's funny when I was younger I wanted that loud pipe. Now, not so much.lol. Is there only one programer on the market? What's everybody running?
Old 10-13-2013, 11:14 AM   #6413
kiwi5
Oddometer: 385
I am running a EJK, but there is another one- can't remember the name but if you look up posts from "Lost", he had found another manufacturer. The EJK works perfectly so far...
Old 10-13-2013, 11:18 AM   #6414
jsonder
Tired Old Fart
jsonder's Avatar
Oddometer: 534
I was only getting 2K miles out of them so I shifted to Dunlop 606s (along with increasing the rear sprocket size), The 606 rear is an 18-120/90 and on my 2009 230L that meant a chain addition to fit it on anyway, so I overkilled changing the rear sprocket from 39 to 48 teeth. She climbs pretty good now.
PS I have 3200 miles on the 606s after this mornings ride. Looks like another 500-1000 available.
John
2009 Honda CRF230L (L'il Red Piglet)
2014 Honda CB500XA (Daily Rider)
jsonder screwed with this post 10-13-2013 at 02:13 PM Reason: add PS
jsonder is offline   Reply With Quote
Old 10-13-2013, 11:25 AM   #6415
SAPB
SAPB's Avatar
Oddometer: 1,615
http://www.bazzaz.net/index.php/honda/crf250l-13
Old 10-13-2013, 04:45 PM   #6416
tony.m
tony.m's Avatar
Oddometer: 6
Just replaced front sprocket with 13T
Hello everyone. New here and I know this has been covered many times but can someone tell me how this affects my speedometer? Also if it could affect the warranty which I don't see how it could.
tony.m is offline   Reply With Quote
Old 10-13-2013, 04:55 PM   #6417
SAPB
SAPB's Avatar
Oddometer: 1,615
Welcome to the 13t club, best bang for the buck IMO. This will correct things. Also corrects after tire swaps.
http://shop.12oclocklabs.com/index.p...&product_id=59
Old 10-13-2013, 05:31 PM   #6418
tony.m
tony.m's Avatar
Oddometer: 6
Cool2
Thanks SAPB bookmarked site for later use, looks like a must have. Installed the 13T last night and took her for a spin this morn. It's much easier to turn dirt and throw gravel that's for sure. I also wanted to gear it down to have more control when cornering on pavement and it did the trick. Almost perfect.
Old 10-13-2013, 05:38 PM   #6419
Bolty
Señor Member
Bolty's Avatar
Oddometer: 42
Workshop manual owners , help please...
The workshop manual still isn't available in the UK yet so here's another request for info!
Please could someone look in the book at the torque settings for the fork leg triple clamp bolts, also if you could would you identify the plugs in this picture
photo(1)
I think I remember reading in this thread that the green one is the sidestand switch connector but what are the other three? There's a buff coloured one and another two black ones.
Thanks all
1997 RD-07A Africa Twin (3rd consecutive owner from the XRV.org.uk forum)
2013 CRF250L EJK, Decat'd standard exhaust, DNA Air filter, 13t sprocket and Speedo DRD.
Bolty is offline   Reply With Quote
Old 10-13-2013, 05:50 PM   #6420
SAPB
SAPB's Avatar
Oddometer: 1,615
photo(1)
Thanks all
Triple clamp fork bolts, referred to as top bridge, and bottom bridge pinch bolts, 24 lb-ft. I've not been in there that you have a pic, must be the left side under where the battery is?
Times are GMT -7.   It's 10:20 AM.
