Old 10-31-2013, 06:27 AM   #6511
Auto-X Fil
Oddometer: 662
More of my CRF250L HDB handguard comments and photos here:
http://www.advrider.com/forums/showp...&postcount=345
Auto-X Fil is offline   Reply With Quote
Old 10-31-2013, 10:29 AM   #6512
Kray
Kray's Avatar
Oddometer: 955
I was waiting for someone to do this! Excellent!
On my to-do list for sure. Whats the best way to purchase them from HDB, call?
What size top mount did you go with, and can you post a full view from the front and side of your bike to get a better idea how they look?
Edit: also noticed your grips do not match. Care to splain?
Current: '15 WR250R Build Thread
Previous: '14 CB500X | '14 CRF250L
Kray screwed with this post 10-31-2013 at 10:39 AM
Kray is offline   Reply With Quote
Old 10-31-2013, 10:35 AM   #6513
battlecattle
Oddometer: 271
I also have been delaying the HDB stuff, maybe I should just do it.
http://www.batlecatle.com/
CRF250L Service Manual
2014 KTM 690 Enduro
2014 CRF250L - Totaled
battlecattle is offline   Reply With Quote
Old 10-31-2013, 10:37 AM   #6514
Kray
Kray's Avatar
Oddometer: 955
Originally Posted by tirebiter View Post
I'd appreciate it if you Took your credit card and crf250l opinions back to thumpertalk, this thread is for people who actually plan on using their bikes in the real world, not for just bar hopping.
Wanna bar hop? Buy a Harley..
late to the party but this made me laugh. Gnarth and Positron are some of the nicest guys and own a large wealth of knowledge when it comes to CRF250L details. I single them out because I see them on TT a lot and they've gone out of their way to help me in my research/learning. I guess you were just having a bad day when you wrote this. It happens.
Old 10-31-2013, 10:41 AM   #6515
SAPB
SAPB's Avatar
Oddometer: 1,596
For you folks who are fairly new here, you may not know about Lost Rider's thread. He put HDB on Nancy's bike. Not sure if it's on his thread, have a look. Speaking of Lost, we haven't heard from him since he said he was going to Baja.
http://www.advrider.com/forums/showthread.php?t=859691
And Ramz' site is helpful.
http://www.rickramsey.net/CRF250Lmods.htm
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB screwed with this post 10-31-2013 at 10:46 AM
SAPB is offline   Reply With Quote
Old 10-31-2013, 10:48 AM   #6516
Kray
Kray's Avatar
Oddometer: 955
Thanks for the info, SAPB. A quick search didn't yield any HDB results. I've been through his thread a few times and don't remember seeing anything about them. You're right though, he's been MIA for a hot minute. Hope all is well.
One of the tricky aspects of the Advrider's CRF250L repository is that it's all inline to this single thread. Can get tricky to keep up and search for information as opposed to other forums who dedicate a subfolder to the CRF250L model. Not sure why I'm pointing this out. Maybe due to the incredible amount of sugar coursing through my veins today.
Happy Halloween, ya crazies!
Old 10-31-2013, 10:50 AM   #6517
tilliejacques
tilliejacques's Avatar
Oddometer: 407
did you get the LED turn signals in the handguards? I can't quite see if the stock turn signals are there. If you *do* have the HDB integrated turn signals, do they flash very fast?
thanks!
11 Husky TE250
08 Beta Rev3 125
tilliejacques is offline   Reply With Quote
Old 10-31-2013, 10:53 AM   #6518
Kray
Kray's Avatar
Oddometer: 955
thanks!
I don't think they are turn signal guards. See the little weird imprint on the top inside corner of the plastic? That's where the LED turns slip in. You'd see a wire and turns in that area. Plus you can still see his stock turns on the bike. Look at the passenger side brake line and headlight plastic.
Photo: http://www.highwaydirtbikes.com/HDB_...Shields_04.jpg
Old 10-31-2013, 10:56 AM   #6519
Auto-X Fil
Oddometer: 662
If you want to get the SE bars, yes, call or email. If you want the 1 1/8" Contour Bars, you can get to that option on their webpage. They sell adapters to put the fat bars on, or you can use Rox risers or other adapters.
100x33/35mm is correct for mounting 7/8" bars to the stock triple clamp. Note that if you go with 1 1/8" bars, you'll need the 38/40mm top clamp size to fit the bigger bars. If you use the HDB riser/adapter, 100mm will still be correct. If you get Rox risers, the 106mm is the correct width, since they move the top clamps out a little bit.
Sure, I'll do that later.
Those are the stock grips - I just didn't rotate the left one around the bar the way it was from the factory.
Yep.
I totally forgot about one fairly major caveat: on the CRF250L, the key will BARELY go into the ignition with the standard top clamp. You can either cut/machine the top clamp down, or trim the key. I chopped a little bit off my key to make it fit. You could also work with HDB to have them machine a custom one for you - I can provide the measurements if someone wants to do that.
They key should NOT interfere if you have risers, because you'll just be able to fit the key under the top clamp. It'll still be a little bit of an awkward reach to get the key in, unless you machine the top clamp.
Old 10-31-2013, 10:56 AM   #6520
Auto-X Fil
Oddometer: 662
thanks!
I did not get them. I'll add them on later if/when I rip off the stock signals in a crash.
Old 10-31-2013, 10:58 AM   #6521
SAPB
SAPB's Avatar
Oddometer: 1,596
You munchin' on the Halloween candy, that's for the kids! I know it takes a lot of time to go back to the start of this thread, for the new folks. I did, to make a decision about whether I was going to join the club. Lots of good stuff back there, if you've got the time. Yeah, Lost was recovering from when his Husa was taking a nap, hope everything is good.
Old 10-31-2013, 11:09 AM   #6522
Kray
Kray's Avatar
Oddometer: 955
Yep.
Auto-X Fil, thanks for breaking this down so nicely. It never occurred to think about the key issue. I'm only 5'6", so I wanted to avoid risers if possible. Maybe I'll just put them on anyway.
Old 10-31-2013, 11:12 AM   #6523
battlecattle
Oddometer: 271
Could you also get a picture of the key area?
2014 KTM 690 Enduro
Old 10-31-2013, 11:12 AM   #6524
Auto-X Fil
Oddometer: 662
FYI, I believe that HDB will machine a custom top clamp for less money than adding risers. I wouldn't compromise fit for the key issue. I'll take a photo of the clearance later.
Old 10-31-2013, 12:57 PM   #6525
Auto-X Fil
Oddometer: 662
Some photos of the bike:
And they key issue. As you can see, it's really just the extension of the top clamp where HDB allows for mounting accessories that's the issue, so you could easily remove enough material to make the key fit.
There's plenty of room under it, so risers would let you get the key in. But, it would still be a little awkward to reach the key under the top clamp, unless you used Rox risers and tilted them back to give more access.
Times are GMT -7.   It's 11:15 PM.
