Old 11-01-2013, 05:06 PM   #6541
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,752
Originally Posted by Bolty View Post
I'm aware of the battery operated ones but the ones that I have are the Powerlet ones from these guys: http://www.adventure-spec.com/defaul...ontroller.html
I reckon the battery operated ones will be great if you need to use them when away from the bike but I've never needed heated gloves apart from when I'm on my motorbike and I'm 50 odd years old, can't see a need for them for me!
I see an advantage of not needing wires. If you are also worried about the capability of the charging system, no load on the bikes stator.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is online now   Reply With Quote
Old 11-02-2013, 06:53 AM   #6542
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,262
Woohoo fairing on the CRF
Anyone aware of plastic skidplate that protect the lower frame? Ordered the Cycra one on that is advertised as fitting L but it does not fit.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 11-02-2013, 06:58 AM   #6543
SAPB
SAPB's Avatar
Oddometer: 1,615
http://www.mooseracing.com/products/...e=productGroup
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is online now   Reply With Quote
Old 11-02-2013, 07:02 AM   #6544
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,330
I think that the gloves use slightly less power than heated grips too which may be handy for our little bikes!
Does anyone know how much extra power we have available from the charging system?
The CRF250L has 335w. I would guess that you have at least 100w available at a cruising RPM.
I think gloves actually pull more watts than grips? Grips are nice if you hands just get a little chilly, but gloves do a much better job of actually keeping your hands warm in colder weather. Now a set of heated grips + hippo hands do a great job.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 11-02-2013, 08:13 AM   #6545
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
We've run a 77w Gerbings heated jacket liner + 35w heated grips all day with no issue last winter, there seems to be plenty of power left over to stay warm in cold weather on the LRP.
I can't see the bike using more than 150w between lights, fuel pump, injector, and ECU, but haven't put an amp clamp on it.
Speaking of, I remember seeing OEM honda heated grips a long ways back in this thread, maybe from someone in Japan, has anyone found a source for OEM heated grips in the USA or have a part #?
The el cheapo generic heated grips I installed just to get us through winter have failed and if I can get OEM ones I'd like to go that route. If not these Moose Racing ones have served me well on another bike.
Lost Rider is offline   Reply With Quote
Old 11-02-2013, 10:59 AM   #6546
Tnutt
Oddometer: 20
IMS tank
For those of you who have changed over to the IMS tank, When you changed the OE fuel pump out of the OE fuel tank to the IMS tank, What did you do about the gasket? The OE tank has ridges with the studs in it, versus the IMS tank which has a flat surface where the gasket goes. I happened to have a motorcycle shop next door and he did not feel to comfortable using the same gasket cause you can't tighten it down to the right torque with out the gasket getting pushed out the sides. What did you torque the bolts too?
Tnutt is offline   Reply With Quote
Old 11-02-2013, 11:49 AM   #6547
Lapchik
Tinkeritis posterboy
Lapchik's Avatar
Oddometer: 357
Watch me fall down and test how strong my mods are.
http://www.youtube.com/watch?v=SzyTi1W8Xn8
Lapchik is offline   Reply With Quote
Old 11-02-2013, 12:03 PM   #6548
r6realtor
Oddometer: 249
your reaction when you first went down on one side(48 second in) then picked the bike and it fell to the other side was hilarious!
great vid by the way, enjoyed the whole thing!
r6realtor is offline   Reply With Quote
Old 11-02-2013, 12:13 PM   #6549
SAPB
SAPB's Avatar
Oddometer: 1,615
You've got crashing down to a science! BTW, bars at full lock increase leverage, for lifting the bike. But hey, you are all done crashing.....
Old 11-02-2013, 01:54 PM   #6550
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,262
They are proud of that one! Figured a piece of plastic would be less than aluminum!
Old 11-02-2013, 03:26 PM   #6551
ScootToots
ScootToots's Avatar
Oddometer: 232
I enjoyed that video. It seems that the best way to overcome the fear of those tricky situations (and learning how to handle them), is by giving them a go. And it sure helps if you have buddies nearby.
Good stuff!
YouTube Channel: Blasts from the Saddle
ScootToots is offline   Reply With Quote
Old 11-02-2013, 03:50 PM   #6552
wolftrax
wolftrax's Avatar
Oddometer: 463
Well I pulled the trigger today on the LRP. Rode it 150 miles today on the interstate, twisties and 2 track. I have to admit the LRP exceeded my expectations.
I bought this little gem with the intention of setting it up for touring. All my kit fitted right up!
2014 Honda CRF250L
2013 Husky TR 650
1990 KLR650
wolftrax is offline   Reply With Quote
Old 11-02-2013, 05:37 PM   #6553
Auto-X Fil
Oddometer: 684
I just snugged them until it started squishing out. It seals fine.
Auto-X Fil is offline   Reply With Quote
Old 11-02-2013, 06:28 PM   #6554
nbrooks
Oddometer: 30
Fork bleeder
Why hasn't anyone come up a fork bleeder option for the LRP? I would think a machine shop could drill holes in the stock fork caps and resell them to fit a motion pro fork bleeder. RAMZ made some but I don't want to put forth the effort to get it done. Someone should put a kit together. Unless someone already has a lead on this.
nbrooks is offline   Reply With Quote
Old 11-02-2013, 06:29 PM   #6555
Bicyclist
Bicyclist's Avatar
Oddometer: 515
Hey John, what fairing is that?
Bicyclist is offline   Reply With Quote
Times are GMT -7.   It's 03:11 PM.
