Old 10-30-2012, 09:53 PM   #721
StupidDogCoffee
IGNORE THIS TEXT
StupidDogCoffee's Avatar
Oddometer: 27
How does the 13t perform on the road, particularly at highway speeds?
StupidDogCoffee is offline   Reply With Quote
Old 10-30-2012, 10:17 PM   #722
Kevinsterner
Kevinsterner's Avatar
Oddometer: 127
Horsehoe Dam to Sheeps Bridge the hard way
Ok I have tried to post these before but I didn't know how to have them show up until I created a Flickr account.
This was a little trip I took about a month ago. It was supposed to be a short little ride to Horseshoe Dam and back. it turned out to be about 120 miles and 5 hours. I have seen other posts with people running this route, but I did it backwards. This made getting up to Sheeps Bridge a bitch. I went to Horseshoe Dam up to Sheeps Bridge on to fire road 24 and back to Cave Creek.
2013 Honda CRF 250 L (Current Bike)
1981 Honda 750 F
1972 Yamaha 250 DT
1971 Hodaka 100
you can't fix stupid.
Kevinsterner is offline   Reply With Quote
Old 10-30-2012, 10:18 PM   #723
itrack
Oddometer: 104
Originally Posted by 'Flagger View Post
After receiving some suggestions from the boys over in the 'Adventure in Ohio' thread in Regionals (thanks, boyz!), I pieced together a spring compressor for two exhaust flanges and some threaded rod.
Compressed the spring far enough to expose the lock nut buried under the spring seat and bump stop.
Then got it apart! Took a little bit of a soak in WD-40 to loosen things up ... but it's done.
Measurements taken so far:
Shock length (eye2eye, uncompressed): 15 9/16"
Travel to bump stop: 2 3/32"
Travel to hard stop: 3 3/16" (The hard stop is the lock nut.)
Spring free length: 9 13/16"
Spring diameter: 3"
Wire diameter: 0.475" (didn't scrape the paint off, however, so this is a little high)
What else should I do while I have this apart? Anything you guys want to know?
Ideally I'd find a stiffer spring before I put it back together. Any shops you can recommend for custom spring?
Yes can you measure both mounting ends, width OD, width ID, and hole sizes, I think we can retro fit CR250 double adjustable shocks if the measurments are close.
itrack is offline   Reply With Quote
Old 10-31-2012, 05:03 AM   #724
Bksports88
Oddometer: 25
Originally Posted by Wargasm View Post
Don't they give a bit of a discount if you buy everything at once? The 13t is a noticeable improvement in trail performance.
The total price for the package is $850, and when you add all of the parts up individually it equals the same. I would think it would be a discounted price.
Bksports88 is offline   Reply With Quote
Old 10-31-2012, 02:20 PM   #725
G19Tony
G19Tony's Avatar
Oddometer: 367
Manracks Utility Rack Photos
I finally got around to installing the rack today. It literally took 5 minutes. Everything fit perfectly. I don't have any pictures without the Rotopax adapter, but, you will get the idea. For day to day riding the adapter might be in the way, but it would be a quick matter of loosening the front bolts, removing the rear bolts and rotating it up to get to the adapter bolts. I'm very pleased with the quality of Mike's work.
Honda CT70, Hodaka Dirt Squirt, Kawasaki Versys, Suzuki TU250,
Honda CRF250L, Honda CRF80F, Honda CRF230F, Honda CL70.
Nothing's too cruel if it's funny enough.
G19Tony is offline   Reply With Quote
Old 10-31-2012, 03:35 PM   #726
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,189
Looked at some images of CR250 shocks .... all I saw were piggyback and remote reservoir styles .... not sure they'll fit. Send me one a remote reservoir version, however, and I'll try it.
Measurements:
- Lower mount hole size: 10mm
- Lower mount inner width: 30.85mm (the width of the mating portion of the link is 30mm, however)
- Lower mount outer width: 41mm
- Upper mount hole size: 10mm
- Upper mount width: 30mm
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 10-31-2012, 05:45 PM   #727
Wargasm
Oddometer: 57
I wonder if that manrack would work with my Giant Loop Mojave???? Hmmmmm.........
Wargasm is offline   Reply With Quote
Old 10-31-2012, 06:46 PM   #728
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 742
How do your wolfman bags fit with the rack?
COHVCO/BRC/AMA
2011 BMW F650GS Twin
2013 Honda CRF250L Little Red Pig!
SugarDust is offline   Reply With Quote
Old 10-31-2012, 07:32 PM   #729
G19Tony
G19Tony's Avatar
Oddometer: 367
I'm going to try and get them back on tomorrow.
Old 10-31-2012, 09:08 PM   #730
MrFurious
MrFurious's Avatar
Oddometer: 678
Originally Posted by Bksports88 View Post
Has anyone installed the 13 t sprocket from bestdualsportbikes.com ? And if so how much better is it. I am planning on buying all the parts from the performance package but individually. I want to install everything myself too and would love to watch someone do it first on YouTube.
I'd be a little leary of the HP claims with this kit. Below is their "supposed" dyno chart showing the HP gains on their website, but look at it closely. I'll give you a hint: upper left corner. See it? They show three curves markered in on the graph, but the actual printout only indicates two (green and red). Either they never did a third pull to validate their claims, or they did the third pull on a separate sheet and the results were so lack-luster they chose not to publish them. Thus Black = Bullshit
I probably wouldn't have caught it, but I found it rather odd they felt the need to go over the actual pull curves with red and blue markers even though the actual curves were clearly visible. Then I looked a little closer and noticed that no where along the black pull can you see anything from the original printed pull poking out from behind the marker. All they did was took the second chart they posted (below) and colored in a third make-bleieve pull to magically validate their claims.
Jim B.
2009 Concours 14 For Sale
MrFurious screwed with this post 10-31-2012 at 09:16 PM
MrFurious is offline   Reply With Quote
Old 10-31-2012, 09:15 PM   #731
espacef1fan
Oddometer: 581
I know everyone will say"Thats not what its for.." How does the CRF250L Compare to the KLX250S..stock for stock on the interstate. Actual numbers and rider weight/size and cargo lloads would b ehelpful too. I like th eprice of the CRF and it strikes me as everything I wanted from my KLX250 but didnt get...
2005 Ninja 250
-WTT or WTS
$2400 OR KLR650, TU250, W650..sportbikes, naked bikes...whatever...
espacef1fan is online now   Reply With Quote
Old 11-01-2012, 04:16 AM   #732
Bake
adventurer
Bake's Avatar
Oddometer: 10,489
My Honda handles perfectly on the street. My 07 klx had a very twitchy feel at anything over 35 mph and at 60 felt like it could go into a headshake at any second. A damned uneasy feeling at highway speeds. The Crf250L handles like its on rails, the complete opposite. My bike runs at 6000rpm and 60 mph, which is the torque peak, so it cruises easily.in every way, the Honda is very much more refined than the klx, having owned both, I think its better in every way. My plans are to go up one tooth on the countershaft sprocket. With a slip on muffler one of the big bore kits thats coming, my uses will be easy to accomplish. My riding is on improved and unimproved gravel roads, and its not uncommon to be in 5 th and 6 th gear alot. Plus, I often ride the bike to the Flint Hills area to do my off pavement touring, so an overdrive ratio is a good thing. With a little more power and carrying the 1 gal. Rotopax, I'll have great bike to use.
I know the 283 is going to be possible, and I hope the bigger kit is also.
Bake screwed with this post 11-01-2012 at 04:53 AM
Bake is offline   Reply With Quote
Old 11-01-2012, 05:05 AM   #733
Bake
adventurer
Bake's Avatar
Oddometer: 10,489
[QUOTE=G19Tony;19941559]I finally got around to installing the rack today. It literally took 5 minutes. Everything fit perfectly. I don't have any pictures without the Rotopax adapter, but, you will get the idea. For day to day riding the adapter might be in the way, but it would be a quick matter of loosening the front bolts, removing the rear bolts and rotating it up to get to the adapter.
[quote]
Great set up, I think this system for now is the way to go.
Old 11-01-2012, 05:08 AM   #734
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 742
I never considered riding my KLX on the interstate (I-25 Northern Colorado) - around here, seems the minimum speed limit is 75 + usually at around 85 to be the average - I set it up for pretty much dirt only. I don't ride my CRFL on the interstate for the same reasons - either bike is not really an interstate bike. I ride my BMW on the interstate
COHVCO/BRC/AMA
Old 11-01-2012, 05:11 AM   #735
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 742
[QUOTE=Bake;19945345][QUOTE=G19Tony;19941559]I finally got around to installing the rack today. It literally took 5 minutes. Everything fit perfectly. I don't have any pictures without the Rotopax adapter, but, you will get the idea. For day to day riding the adapter might be in the way, but it would be a quick matter of loosening the front bolts, removing the rear bolts and rotating it up to get to the adapter.
Sweet - that looks great!
COHVCO/BRC/AMA
Times are GMT -7.   It's 08:13 AM.
