Old 02-17-2014, 08:38 AM   #7426
Kray
Kray's Avatar
Oddometer: 1,076
Originally Posted by Epy View Post
I'm planning on some sort of suspension upgrade (either the YSS or Racetech). Even if I were to set the preload right, it only takes me about 20 minutes to make the shock overheat.
I can definitely see that happening. It's just not a race type setup. I'm more of an ADV rider so never really pin-it to win-it.
The thing I don't like is the amount of road vibration that gets transmitted up through the bike. That reason alone may push me to a racetech setup. It kills me on long rides.
'15 WR250R Build Thread
Kray is offline   Reply With Quote
Old 02-17-2014, 10:35 AM   #7427
roundtripping
Adventourist
roundtripping's Avatar
Oddometer: 1,704
Air down the tires and watch the wobble disappear... Overinflation can make the bike very scary handling. Coming from bigger bikes, I overinflated mine at first.
Sent from my Moto X using Tapatalk
12 F658GS
13 Honda CRF250L
My SPOT Tracker
roundtripping is offline   Reply With Quote
Old 02-17-2014, 10:55 AM   #7428
Kray
Kray's Avatar
Oddometer: 1,076
to what? I run 22-24psi
Old 02-17-2014, 11:01 AM   #7429
roundtripping
Adventourist
Oddometer: 1,704
Set it down a couple PSI at the time until the wobble goes away. Different tires - different pressure.
12 F658GS
13 Honda CRF250L
My SPOT Tracker
Old 02-17-2014, 11:03 AM   #7430
Kray
Kray's Avatar
Oddometer: 1,076
Fair enough - i'll give it a shot. Thanks.
Old 02-17-2014, 11:18 AM   #7431
kiwi5
Oddometer: 385
Interesting option- i run 22psi front and rear but will try 20psi on the front to see if the wobble goes away- if that doesn't work then another cheap option would be to switch to a super moto front fender....don't want to go too far under 20psi as i want to avoid any pinch flats when off road. Changing to a supermoto front fender made a HUGE difference on my old DR650 ( much better road riding). The crf250l front fender doesn't look floppy like the dr650 but certainly a cheap mod....probably go with a black colored one...
kiwi5 screwed with this post 02-17-2014 at 11:23 AM
kiwi5 is offline   Reply With Quote
Old 02-17-2014, 11:21 AM   #7432
r6realtor
Oddometer: 273
I run 15-16 psi in the rear and 16 psi up front no wobble at all, same with my new tires.
r6realtor is offline   Reply With Quote
Old 02-17-2014, 11:58 AM   #7433
SAPB
SAPB's Avatar
Oddometer: 1,661
Never had any wobble, either with the original rear, or the replacement D606. The front still has some wear left before replacement, and I'm at a little over 8K. I do check with a bicycle pump that has the gauge built in if it's been sitting. Most of the time, I just put both hands around the tire, with my fingers clutching the rim, and push with my thumbs to see how it seems. When these tires are toast, I'm going with MT43 front 1st, since that one will need it before the rear, but probably get both at the same time. I always like having a tire on hand before I actually need it.
Wobble problem folks, maybe ride with someone, and have them watch to see what it looks like?
More fn' snow tomorrow.....
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is online now   Reply With Quote
Old 02-17-2014, 03:43 PM   #7434
Harcomo
Oddometer: 120
Are you running rim locks at those pressures or are they not needed?
Harcomo is offline   Reply With Quote
Old 02-17-2014, 05:40 PM   #7435
kiwi5
Oddometer: 385
Well I'll be dipped in dogshit! I just dropped my pressures to 19 psi front and rear and no more wobble! When I am on on gravel/ muddy back roads i take 'em down to 17psi and have not needed rimlocks yet. But I am not going hard on the braking which is what usually causes the tire to spin and rip out the valve. Guess I don't need to swap out the tires after all...
Old 02-17-2014, 06:25 PM   #7436
roundtripping
Adventourist
Oddometer: 1,704
12 F658GS
13 Honda CRF250L
My SPOT Tracker
Old 02-17-2014, 07:37 PM   #7437
r6realtor
Oddometer: 273
I don't run them but we have nothing but deep sand here, so spinning and catching rocky mountainous terrain won't be happening for me, not that its impossible to spin a tire but i haven't had an issue yet.
Old 02-18-2014, 06:37 AM   #7438
Fytclub
Oddometer: 17
Have this stuff in the sale section but this is 250L specific. Please PM with questions.
Wolfman Enduro bag $35.00 shipped
Manracks with Pelican 1450 $150.00 shipped
Fytclub is offline   Reply With Quote
Old 02-18-2014, 06:40 AM   #7439
Kray
Kray's Avatar
Oddometer: 1,076
PMed on the Enduro bag
Old 02-19-2014, 03:04 PM   #7440
ScootToots
ScootToots's Avatar
Oddometer: 242
AirBox mod: Fabricated new snorkel
At first I was resistant to modifying the air filter and airbox -- but I finally decided it's worth a shot. I did not want to drill the airbox cover though, and I also didn't want holes level with the airbox lid that would allow water to migrate into. So here's what I did:
I fabricated a brand new snorkel to replace the stock one. My new snorkel is at least 60% larger I.D. than stock (based on a quick measure of the oval stock snorkel). It actually looks almost twice the volume. I used a 2" I.D. flexible rubber elbow (available in the plumbing department). The photos don't clearly show it, but because of the shape of the airbox, I cut the opening freehand (fine tooth keyhole saw) in a slightly bent elongated curve, then pressed the rubber elbow to conform to the available space.
If after a few weeks I am satisfied with this, I'll silicone seal where it inserts. Doing it this way, also gives me the option to fabricate another version that extends into the airbox as far as the stock snorkel did, to reduce the induction noise -- and if you listen to some -- to improve low-end torque. At the moment, I quite like the throatier growl that I get from this snorkel length, and the performance seems markedly improved.
So now my question is: how much should I enrich the EJK settings? Before this mod, my settings were for a stock bike as suggested by EJK: 1.5,1.5,2.5 (cruise, acceleration, WOT). After the mod, I enriched the settings to 2,2,3, to make use of the increased air available. The cutoff/engage settings are unchanged from the original EJK settings for this bike. I haven't inspected the spark plug yet. I want to ride it for a week or so first. A quick sniff and poke at the tailpipe though, tells me it may be running a tad rich, but it's cold outside, and that can enrich it more than normal also.
Opinions... thoughts... ?
PS: I also removed the backfire screen from the filter, I have 13/42 sprockets and stock exhaust.
Thanks,
John
YouTube Channel: Blasts from the Saddle
ScootToots screwed with this post 02-19-2014 at 03:16 PM
ScootToots is offline   Reply With Quote
Times are GMT -7.   It's 04:00 AM.
