11-09-2012, 06:09 AM
#871 |
Oddometer: 25
11-09-2012, 06:11 AM
#872 |
Oddometer: 25
Just bought my ricochet skid plate, Cycra hand guards and 13t sprocket. Will post pictures installing them soon
11-09-2012, 08:26 AM
#873 | |
Butler Maps
Oddometer: 14,458
unless you've watched your bike come directly from the crate to assy and then you take it, many shops will start all news to confirm they indeed do run properly before a sale so that would be run #2. now the crf move fast but others bikes that don't might be started many times over after that at the dealership.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
11-09-2012, 08:30 AM
#874 | |
Butler Maps
Oddometer: 14,458
11-09-2012, 09:05 AM
#875 |
adventurer
Oddometer: 10,489
Theres no reason to change the oil before the 600 mile check. Not with modern oil and a filter in place and the reasons are simple. A new engine does not have any ash content yet and will have far less while new than an older engine. If the idea that Honda doesn't know how engines, oil, and everything involved behave, the extended warranties will be attractive. Japanese motorcycle engine makers have used 600 miles as the intial check for at least 40 years, and the oil and metalurgy and engine heat control that are involved have only gotten better
My method is warm the engine well before each use, don't use more than half throttle for 40 miles, let it cool off totally, increase revs used until 10 hours use. Probably 300 miles. Only rings and the bore are involved, you don't want either to warp while the final tempering of the steel and iron are completed. 10 hours use is plenty, with a dozen or less heat cycles involved. The theory of assembly lube, extremely fine particles of aluminum and to a lessr extent steel doing a final polishing may have validity. The Thai dealerships are changing oil @ 300 miles then oil and filter and valve check at 600. There's as many ways to do it as buyers. Experience can guide what has worked for each owner, a rider new to all this might consider Honda knows more about small engines than anyone. Bake screwed with this post 11-09-2012 at 09:29 AM |
11-09-2012, 09:42 AM
#876 |
Oddometer: 1,051
Will you remember RamZ's wisdom in the middle of frikkin nowhere when your shift level falls off?
11-09-2012, 09:54 AM
#877 | |
Oddometer: 366
Honda CT70, Hodaka Dirt Squirt, Kawasaki Versys, Suzuki TU250, Honda CRF250L, Honda CRF80F, Honda CRF230F, Honda CL70. Nothing's too cruel if it's funny enough.
11-09-2012, 10:04 AM
#878 | |
Oddometer: 1,051
lube the inside of the throttle before final assembly with dry graphite lock lubricant...be careful..the crap can be real messy! |
11-09-2012, 10:49 AM
#879 | |
Oddometer: 25
Im curious is if Butler Maps has anything in VA, seeing your from CO I doubt it. I want to map out some weekend camping trips next spring |
11-09-2012, 10:50 AM
#880 | |
Oddometer: 366
11-11-2012, 10:31 AM
#881 |
Could save your life
Oddometer: 23
A Few Questions...
So I told myself I was just gonna leave the bike stock......Lets just say i've changed my mind.
I ordered one of the manracks rear racks and the wolfman peak tail bag. I would highly recommend both to anyone looking for a little storage of their 250's. The rack is awesome and it took less than 5 mins to install both. Next up... I was curious how you guys were liking the ricochet skid plates so far, any issues? Has anyone paid the extra $20 and ordered a black one yet? I'd love to see a pic of what that looks like installed on the bike. Also, I finally got a chance to take it for a good little ride this morning (75 miles). The seat is little brutal but the fun factor makes up for it. How easy of an install is the seat concepts cover? Does it make that big a difference in comfort? Do you need to be an upholstery master to install that thing? |
11-11-2012, 11:59 AM
#882 | |
Oddometer: 1,051
11-11-2012, 12:32 PM
#883 |
Oddometer: 2
Tank Bags?
Has anyone purchased a mag mount tank bag for their CRF250L? You can't tell how one will fit from the ads.
11-11-2012, 01:00 PM
#884 |
Oddometer: 10
11-11-2012, 02:07 PM
#885 |
adventurer
Oddometer: 10,489
Acerbis handguards, their white color plastic matches the Honda.
![]() Small dash with 2 BMW power outlets for electric vest, battery tender, etc. Wired direct to battery. The temp gauge is a simple stick-on and can be moved easily. When my Garmin 60csx gets back from repair, I'll fit it to the plate.
Bake screwed with this post 11-11-2012 at 08:59 PM |
