Old 11-28-2012, 07:17 AM   #1171
gaw777
Oddometer: 59
Why a Damper for the bike? What benefits will it add to this bike?
As far as a mod's list, how high of a priority would it be?
If so, which one?
BTW: Thanks for the write up Lost Ride, great vid!
gaw777 is offline   Reply With Quote
Old 11-28-2012, 07:18 AM   #1172
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,400
Originally Posted by MrFurious View Post
With that thought in mind, has anyone measured the outside diameter of their fork tubes directly where the tree's clamp onto them? I know the `05 CRF450's 47mm Showa forks are approximately 53mm at the top clamp and 58mm at the bottom clamp, and the clamps are spaced 18.5cm apart. .
My measurements:
Upper = 54
Lower = 57
Yes, 1mm off (in opposite directions) on each from the forks on it's big brothers. Didn't measure the gap.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 11-28-2012, 07:32 AM   #1173
Ed@Ford
Oddometer: 1,664
In general, for any fork made to a price (low in the case of CRF and my KLR650) a gold valve or an Intiminator are a massive improvement. I especially like the Intiminator in my KLR because it provides some anti dive....very nice on a bike with reasonably long front travel that is street ridden....and this bike appears to be a very nice street ride
Ed@Ford is offline   Reply With Quote
Old 11-28-2012, 07:42 AM   #1174
ramz
Professional Trail Rider
Oddometer: 2,019
See this page from Nov 7:
http://advrider.com/forums/showthrea...823409&page=57
post #852.
ramz is offline   Reply With Quote
Old 11-28-2012, 07:43 AM   #1175
MrFurious
MrFurious's Avatar
Oddometer: 704
Originally Posted by 'Flagger View Post
My measurements:
Upper = 54
Lower = 57
One could easily make shims for the upper clamp, but hard to say if the lower has enough meat to be bored out 1mm and still retain sufficient strength.
Jim B.
MrFurious is offline   Reply With Quote
Old 11-28-2012, 07:47 AM   #1176
roundtripping
Adventourist
roundtripping's Avatar
Oddometer: 1,704
I think he's asking about the steering damper.
12 F658GS
13 Honda CRF250L
My SPOT Tracker
roundtripping is offline   Reply With Quote
Old 11-28-2012, 07:55 AM   #1177
MrFurious
MrFurious's Avatar
Oddometer: 704
post #852.
Wow, how'd I miss that chart?
Jim B.
Old 11-28-2012, 08:01 AM   #1178
MrFurious
MrFurious's Avatar
Oddometer: 704
Duplicate post - DB Error
Jim B.
Old 11-28-2012, 08:13 AM   #1179
gaw777
Oddometer: 59
Yes I was, sorry about that
Old 11-28-2012, 08:18 AM   #1180
MrFurious
MrFurious's Avatar
Oddometer: 704
Deleted: Duplicate post - DB error
Jim B.
Old 11-28-2012, 09:28 AM   #1181
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
If so, which one?
The video is supposed to be a little funny and referring to CRFL as the LRP is out of love. I've ridden a BRP ( well known as the Big Red Pig XR650R) in Baja and it is a Big Red Pig compared.
Anyways, glad you like.
As for steering damper, it's been my experience that all bikes, road and dirt, benefit from a steering damper, and getting one for the CRFL is high on my list. Top of the list after protection for the bike.
Kits are supposed to be available in 2-3 weeks, the CRFL kist will use a clamp on stem not a weld on and a top clamp damper mount. After talking with the guys at Scott's, it seems my ROX risers and HDB top clamp will be compatible with it.If it wasn't, the Scott's would get mounted and I'd work around everything else to have it there.
The nice thing about a steering damper is the main cost is the damper itself and once you have it, you can just take it with you to the next bike.
Here's what Scott's says in a more elegant way than I will about their damper, and I'd have to completely agree. It's the first place to start for me when wanting to improve overall handling in any situation, and mine have saved me from crashing countless times.
What is a Scotts Steering Stabilizer?
It is a compact, fully adjustable, hydraulic shock absorbing damper that mounts to your steering head area right above your handlebar mount. By helping to stabilize the front end of your motorcycle, the rear of the motorcycle will track straighter allowing the rest of your suspension to work the way it was designed to. In addition, the Scotts Steering Stabilizer eliminates that sudden "thrust" affect of having the handlebars pulled from your hands after unknowingly hitting something unforeseen like rocks, tree roots or rain ruts. It has also helps to minimize rider fatigue and the dreaded arm-pumping situation that occurs while wrestling the front end of your bike. Once mounted, it dramatically reduces the unwanted phenomenon known as "Head-shake" that is commonly found on ALL off-road production motorcycles. This is more predominant now a-days due to the steeper head angles you find on production bikes. It helps keep your motorcycle going straight in the whoops and smoothes out those rough sections by preventing those handlebar wrenching jolts.
How does it work?
Basically, it operates under the same principle as your front forks. Valving inside the unit reacts to the slightest of jolts that are transferred through the forks and crowns of your motorcycle. Internal circuitry and hydraulic valving readjusts the amount of shock that would have been received through your handlebars. The link arm, which connects the stabilizer to the frame, reacts instantaneously, absorbing any unwanted movement. Your suspension was designed to handle the vertical movement of your motorcycle, while the Scotts Stabilizer completes your suspension package by controlling the unwanted lateral movement.
Where does the Stabilizer work best?
Anywhere there are forces trying to push or pull the front end left to right. If you ride in the desert, our Stabilizer will soon become your best friend. You will find that it almost completely eliminates the head-shake and instability you get while riding on washboard fire-roads, rocky sections and in high speed sand washes. It helps keep your motorcycle straight in the whoops. In the woods, it's a dream come true. Sharp edged rocks and tree roots that send a shock all the way up to your jawbone are reduced to minor disturbances that allows your suspension to work the way it was intended to. Motocrossers will find the Scotts Steering Stabilizer definitely provides the winning edge by reducing rider fatigue and working with you near the end of long Moto. Your bike will track straighter through the stutter bumps, big rollers and sweeping turns while assuring secure landings at the end of big doubles or tabletops. Being infinitely adjustable, there is no reason not to use it. It has no disadvantages!
http://www.scottsonline.com/scotts.php
Lost Rider is offline   Reply With Quote
Old 11-28-2012, 10:14 AM   #1182
Earthscape
Have ya got a helmut?
Earthscape's Avatar
Oddometer: 352
Originally Posted by Bake View Post
Stock piston. This engine has about 200 miles.
stock iron bore
Wow, from that picture I would have guessed that there isn't much room to grow the bore (thinking about the bore size increase on the KLX351). If Bill can get 300+cc from that, it would be great. (Tell him not to stop making the KLX351 kit though.) A big bore kit on a small bike is such a great way to go - more torque all over without adding any weight.
As for cooling capacity, I remember people were concerned with that on the KLX351 kit too. I never noticed any difference in running temperature on mine (kit #11). At some level, since you may be running at lower RPMs with the larger bore due to the increase in low-end power, there may be less heat generated (slower piston, valves, means less friction, less heat). Of course that doesn't apply if you're just holding the throttle wide open.
"You do your own thing in your own time, you should be proud."
2004 KTM 950 ADV : : : : : : : 1998 Triumph Tiger
1999 KTM 640 ADV : : : : : : : 1993 Kawasaki KLX650
2007 Kawasaki KLX350S : : : : 1996 Yamaha XT350
Earthscape is offline   Reply With Quote
Old 11-28-2012, 11:50 AM   #1183
MrFurious
MrFurious's Avatar
Oddometer: 704
You trying to tell me these new-fangled bikes have throttle positions other than Off and WFO? What will they come up with next?
Jim B.
Old 11-28-2012, 03:41 PM   #1184
Ed@Ford
Oddometer: 1,664
280 piston rings?
The original iron sleeve is removed on a lathe and the custom sleeve is pressed in.
I can't tell....is your 280 prototype a 2 ring piston or a 3? Reason I ask is I don't think the 2 ring big bore kit Athena made for the Yamaha WR250R was well received. I know I would buy a 2 ring big bore. From WAAAY back, I can remember when Scott Summers bored his XR250R Honda to 280, it was THE hot setup! I hope your kit is equally impressive.
Old 11-28-2012, 07:46 PM   #1185
85blazer
Oddometer: 1
Just picked mine up on Sunday.
Great bike so far and great site
85blazer is offline   Reply With Quote
Times are GMT -7.   It's 05:39 AM.
