Old 12-06-2012, 04:52 AM   #1291
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 866
Originally Posted by Lost Rider View Post
Interesting.
I just sent them an email already asking about having the shock worked on. That could fit the budget much better than the new shock option and probably help quite a bit. Maybe a spring change to get it just right for Nancy is in order too if possible.
First things first though - A Scott's steering damper.
Will keep you posted on the results.
Please do very interested in both the damper and especially the rear shock - thanks!
2014 BMW R1200GS -- 2011 F650GS-- 2013 Honda CRF250L -- 2013 KTM 250 XCW
In loving Memory of Cruzn2b - 1953 - 2014
SugarDust is offline   Reply With Quote
Old 12-06-2012, 05:44 AM   #1292
goondock
Oddometer: 68
Originally Posted by CRFSoCal View Post
So I am going to order some 1 1/8 handle bars and the highway dirt bike adapters and Handguards. What are the stock dimensions on the triple clamp is it 100mm x 33mm?
yep top clamp 100x33/35mm bolt pattern
goondock is offline   Reply With Quote
Old 12-06-2012, 05:56 AM   #1293
Ed@Ford
Oddometer: 1,682
Originally Posted by Ed@Ford View Post
My XR400R Honda has a steel shifter with a folding tip. What length is the stock lever from the centerline of the shaft to the centerline of the folding tip, and the offset from the centerline of the pinchbolt to the inside surface of the shifter that faces the alternator....I will take my shifter off and measure it for comparison. Sadly the SRP of the Honda one is $38....but there are many aftermarket ones cheaper...and in different lengths...like Moose Offroad
"length" of the XR400R folding shifter from center line of shaft to center line of the folding tip is 5 5/8", the "offset" from the C/L of the pinchbolt to the inside surface of the shifter that faces the alternator cover is 1 5/8"
Ed@Ford is offline   Reply With Quote
Old 12-06-2012, 06:13 AM   #1294
Guerillah
Guerillah's Avatar
Oddometer: 103
Which mount for the drc did you order? Also do you have anymore pics?
I ordered the KLX250 kit, you will have to drill new holes in the mounting plate, solder 3 wires, get two longer M6 bolts, two longer M8 bolts, and a bunch of washers for each. I mounted it further back than the guy who did the DIY early on in this thread, saved me forming plastic and it looks like it is OEM still. I have more pics, I will have to upload them to the server later when I get home.
Guerillah is offline   Reply With Quote
Old 12-06-2012, 07:11 AM   #1295
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 666
CRF 230L suspension options
Hi Folks,
Rick here from Cogent Dynamics. I owned a CRF230 dirt only bike that I loved as a woods bike, traded it in for the KLX 250 that we now own and have modified to suit. I still miss the tight woods performance and the lower height of our old 230. Any how, we had the honor of building a custom shock for a customers 2013 CRF230 L a couple weeks back. It has been delivered and installed on that bike and we know that the shock fit correctly as well as seems to work well (we are still awaiting details of further performance testing to make sure we have the performance we expect). I am wondering if there is any other interest in these types of shocks as a regular product from Cogent and if so, what people are looking for regarding features and performance. The shock we have built is similar in design to our Moab shock for the KLR. The Customer we are working with is interested in improved off road performance and matching the shock to a longer travel fork at some point. Are we correct in assuming that there are riders looking to improve the load capacity of the bikes suspension as well as improving the on-road capabilities?
We are interested in making improvements on the stock forks for these bikes but need a set to look at for a dyno work-up.
What about lowering options?
We would be very interested in the groups input with comments or experience.
Thank you
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Old 12-06-2012, 07:28 AM   #1296
Guerillah
Guerillah's Avatar
Oddometer: 103
Glad to have you in this thread Rick!
I for one am interested in the rear shock, mostly for off-roading purposes... the stock setup is wayyy too soft. Is the price expected to be the same as your KLR moab? Once you get the front fork setup figured out I may be interested in that as well. Thanks!
Old 12-06-2012, 07:46 AM   #1297
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 866
Originally Posted by NC Rick View Post
Hi Folks,
Rick here from Cogent Dynamics........I am wondering if there is any other interest in these types of shocks as a regular product from Cogent and if so, what people are looking for regarding features and performance. The shock we have built is similar in design to our Moab shock for the KLR. The Customer we are working with is interested in improved off road performance and matching the shock to a longer travel fork at some point. Are we correct in assuming that there are riders looking to improve the load capacity of the bikes suspension as well as improving the on-road capabilities?.....Thank you
I am very interesested in increased off road performance, I bought the bike primarlly to do ride off road - especially for light adventure off road/dual track camping and easy single track - think TAT, Back country discovery routes...
Old 12-06-2012, 07:55 AM   #1298
bungie4
Frostback
bungie4's Avatar
Oddometer: 501
Originally Posted by 'Flagger View Post
Just want to take a moment to plug Cogent Dynamics as another source for a rear shock.
No affiliation, just a satisfied customer.
Yup, you speak the truth, Rick @Cogent did the front and rear suspension on my FJR. Great company to work with and he certainly knows his stuff. He's just down the road from Ohlins Corporate in Hendersonville NC.
Highly recommended.
2013 FJR1300, 1984 CX650e, 2013 CRF250L - Help when you need it -http://www.assistancelist.com
bungie4 is offline   Reply With Quote
Old 12-06-2012, 08:04 AM   #1299
bungie4
Frostback
bungie4's Avatar
Oddometer: 501
Speak of the devil!
I'm interested as well Rick, my criteria would be increasing the load capacity the rear spring, increasing the damping with a bonus of adjustability (preferably rebound). Stock height is great for me. I'm not looking for race performance. This isn't a race bike, it a rather porkulent trail bike
I'm not asking for that much, my over-riding concern for a replacement rear shock would be price. It just doesn't make any sense to spend a fifth of the cost of the bike on a high end Ohlins setup. But if you can get close to a $500 price point I'd definitely be interested.
I don't find the front that bad at all even when pushed. Everything can be made better for sure, but it doesn't scream out for attention like the rear unit does, at least to me.
Looking for a rebuild of my Ohlins on my FJR in the spring. We'll be in touch!
Old 12-06-2012, 09:16 AM   #1300
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,427
Hi Folks,
Hi, Rick. .
Good to see you hereabouts. Super happy with your shock. Still need to rope the wife into helping measure the sag. I'll post here and send you an email when I get them.
Byron
- B
Proud to be an inmate of AdvRider.
'Flagger screwed with this post 12-06-2012 at 04:50 PM
'Flagger is offline   Reply With Quote
Old 12-06-2012, 09:19 AM   #1301
dsn11487
dsn11487's Avatar
Oddometer: 52
Hi Folks,
Thank you
Yes Rick interested in more off-road performance and adjust ability. Not concerned with changing stock height or dimensions, just beefier components. Agree on the price RaceTech is a bit of a turn off since a rear setup is close to $800 which doesn't make a lot of sense. Don't need a kick butt MX bike, but just mainly single track adventure touring.
2005 FJR (the blue ones are faster)
2013 CRF250L
dsn11487 is offline   Reply With Quote
Old 12-06-2012, 09:32 AM   #1302
callison
callison's Avatar
Oddometer: 120
Thanks for the warm welcome, here's a pic of my bike:
I got mine from the Honda dealership here in Winston-Salem, NC. They put the FMF muffler on it. Aside from that, it's pretty much a stock bike. Eventually I'd like to clean up the tail end, all that crap hanging down off the back fender is kind of janky looking. Racks for day/weekend trippin' are in my future as well. Since I haven't ridden in so long I've got to get the basics before I can really start planning bigger upgrades. First on the list is a good pair of cold weather gloves, it was cold out there this morning (38 degrees) on my ride to work.
I figure I should post a pic now, a guy I work with has 80 acres near Pilot Mountain. I'm heading up to ride with him this weekend, I will probably dump the bike at some point. It won't be shiny and new after happens...
I have a technical question:
When I'm riding 50+mph the bike doesn't seem all that stable, the front end feels fairly loose. Would this be due to the the knobby front tire and relatively small size of the bike? Right now, I don't know if I'd be comfortable getting on the interstate. All of the street riding I've done in the past has been on bigger bikes, CBR600's and what not, so I don't have a frame of reference as for what to expect. I realize it's not going to ride like a street bike and I don't plan on doing any significant highway riding so it's not a huge issue, mainly just my own curiosity.
thanks,
Cory
callison screwed with this post 12-06-2012 at 09:41 AM Reason: hit save too quick...
callison is offline   Reply With Quote
Old 12-06-2012, 10:29 AM   #1303
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 729
thanks,
Cory
Did the dealer set the rear suspension sag correctly? It will cause instability if its not set correctly. Tire pressure? Setting ride(race) sag and static sag would be my first area I would check. This should be done when you get the bike. These measurements will also help determine if the spring rate is correct for your weight.
Otherwise it's kind of the nature of the beast.
Win a Free Helmet. xladv.com/topic/258-msr-x-pedition-helmet-give-away-round-1/
MentalGuru is offline   Reply With Quote
Old 12-06-2012, 11:45 AM   #1304
SAPB
SAPB's Avatar
Oddometer: 1,661
Looks like the plug & play version is available on 12 o'clock labs: http://shop.12oclocklabs.com/index.p...product_id=104
SAPB is offline   Reply With Quote
Old 12-06-2012, 12:02 PM   #1305
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,322
Cory,
A steering damper will greatly help with that head shake or high speed stability, along with off Tarmac handling even more so from my experience.
Scott's Performance will have a kit for the LRP in a few weeks I'm told. It will be a clamp on post type, not weld on, and use a top clamp mount for the damper. It should be the same price as similar kits they have listed for other bikes with same mounts. $400 some odd bucks. Best money spent for any bike IMHO.
That's next our our list.
Lost Rider is offline   Reply With Quote
Times are GMT -7.   It's 10:09 PM.
