12-10-2012, 03:15 PM
#151 |
Oddometer: 474
The xr650r sprocket has at least double the surface area on the shaft. the xr650l guys use them on their bikes.
I have no idea if that helps you or not. Sweet build bTW!
12-10-2012, 04:41 PM
#152 |
GPoET&P
Oddometer: 3,748
12-10-2012, 07:42 PM
#153 |
fishing with dynamite
Oddometer: 2,029
Absolutely. Easy. You should be able to anneal that with a torch or a BBQ or something. Just heat it up and then let it air-cool. Then send it out to have it heat treated after you're done. Hate the idea of custom consumable parts though. Might also try giving any of the custom sprocket mfgs a call?
12-10-2012, 09:31 PM
#154 | |
Aspiring human
Oddometer: 2,132
You're really going all-out by lengthening the frame, Luke. Great job. I hope to check it out in-person in a few months.
1987 Yamaha XT600 2KF (German) STOLEN: RED XL600 in Portland I do heavy-duty textile repair, upholstery, and design/manufacture bags. |
12-11-2012, 11:17 PM
#155 | |
GPoET&P
Oddometer: 3,748
You're coming back to Portland? Any guess when? It'll be good to see you. |
12-11-2012, 11:34 PM
#156 |
GPoET&P
Oddometer: 3,748
A little more work got done today.
I pulled the bushings from the shock and measured them. I'll replace them with spherical bearings which should work better. ![]() Ohgood had the right tip on cutting the sprocket. I put it in the big lathe, set the speed as slow as possible and it cut quite nicely. Slowly, but nicely. ![]() I put a countershaft in the engine cases that are mounted in the frame. Then fit and adjusted the chain. ![]() This is with the chain tension adjusted and the wheel at full extension. The slack looks pretty good, there won't be too much work for the rollers and guides to do. ![]() It's a long bike. ![]() Tall, too.
12-11-2012, 11:59 PM
#157 |
Racing Like a Noob
Oddometer: 4,278
Racing a Subaru in the 2013 Mexican 1000 |
12-12-2012, 01:59 AM
#158 |
Oddometer: 745
SWEET!! tall enough for us normal people almost! ;-)
You can check hardness of stuff with a good file.. if the edge of a good "mill" file cuts a piece easily, the piece is usually soft or not yet heat treated. If it "screams" or "sings" off the piece, its harder than a preachers dick in a ..... well you get the idea. You can use that to check areas around welds, or welds themselves. If it gets too hard, watch out! There's a whole bunch of hard vs tough vs strong vs black magic I can't remember anymore... but it matters sometimes. This project isssssss great!
Crazy_Dave just made it into my sigline, and I agree: I fall down alot. |
12-12-2012, 02:49 AM
#159 |
Oddometer: 4,244
Its looking good, You'll be finished by next week at this rate.
12-12-2012, 11:22 AM
#160 | |
Oddometer: 301
12-13-2012, 08:36 AM
#161 |
Aspiring human
Oddometer: 2,132
Expect me around late May.
12-13-2012, 06:29 PM
#162 |
On Any Sunday
Oddometer: 578
Rear Sub Frame Pics
Luke was so busy building and fabricating today, he forgot to take pictures!
Posting a few pics of his work today on the new sub frame, he can provide the narrative; ![]() ![]() ![]() ![]() ![]()
"Nothing can stop us but fear and common sense” |
12-13-2012, 11:35 PM
#163 |
GPoET&P
Oddometer: 3,748
I had some help from another friend today. We measured, cut, measured, measured, filed, measured, clamped, clamped, measured,welded, measured, measured, cut, measured, clamped, measured, welded, measured, measured, bent, measured. (I'm getting a lot of use out of my big L-square.) And ended up with a rear frame part that belongs on a tube frame bike, not the pressed sheet frame that I've got. Oh well, better hide it with some black paint.
The stock shock mounts were in the wrong place and were the wrong size, so it seemed easier to just cut the whole rear part of the frame off and build a new one from scratch. It'l all cut up, but only two of the joints are welded so far. The top and down tubes were offset on the cross tube to make fabrication easier. That makes the cross tube weaker since it has more bending applied to it from the shocks than if the top tubes were further out. To compensate, it's much thicker than the other tubes. I'll make some spindles on the lathe to mount the shocks to and they'll get welded into the cross tube. The big problem now is that I look at the bike and think about putting the gas tank under the seat and the air box over the motor. Putting 0 pound/gallon stuff up high and 6 pound/gallon stuff down low sounds nice. The question is if there's enough room and if it can be built quickly. |
12-14-2012, 04:42 AM
#164 | |
Racing Like a Noob
Oddometer: 4,278
![]() 134 Days until race day. 19 weeks.
12-14-2012, 08:19 AM
#165 |
Oddometer: 3,612
Plenty of time, if Kelly Johnson can design and build the U2 in 8 months you should be able to get this done in 19 weeks
Allan |
