Old 12-14-2012, 09:37 AM   #166
TwinDuro
Befuddled Adventurer
TwinDuro's Avatar
Oddometer: 260
Originally Posted by Luke View Post
The big problem now is that I look at the bike and think about putting the gas tank under the seat and the air box over the motor. Putting 0 pound/gallon stuff up high and 6 pound/gallon stuff down low sounds nice. The question is if there's enough room and if it can be built quickly.
I wonder if the 5 gallon plastic fuel cell from a Harley V-rod or the 5 gallon steel fuel tank from a Honda GL1100 would fit...
"Remember, you may have to grow old, but you don't have to mature." - Red Green
TwinDuro is offline   Reply With Quote
Old 12-14-2012, 11:38 AM   #167
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 592
Skunk Works vs. LC Garage
Originally Posted by Loud Al View Post
Plenty of time, if Kelly Johnson can design and build the U2 in 8 months you should be able to get this done in 19 weeks
I think if we gave Luke an operation with resources like the Skunk Works, he could meet any deadline!
"Nothing can stop us but fear and common sense”
LC Garage is offline   Reply With Quote
Old 12-14-2012, 07:36 PM   #168
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,291
Jeebus Cory, don't encourage a lunatic.
Old 12-14-2012, 09:07 PM   #169
DOCsprocket
Sprocket
DOCsprocket's Avatar
Oddometer: 508
The new sub-frame looks awesome. At this rate there is going to be about 3 original molecules of Honda left, but it's getting awesomer (not a real word, but entirely appropriate for this build) by the minute.
2003 F650gs, 2005 KTM 525exc, 2006 Santa Cruz VP-Free
DOCsprocket is offline   Reply With Quote
Old 12-14-2012, 09:08 PM   #170
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 592
Look who's talking!
Old 12-14-2012, 10:09 PM   #171
oregoncoast
Racing Like a Noob
Oddometer: 4,291
Originally Posted by LC Garage View Post
Look who's talking!
Tru dat.
Old 12-14-2012, 10:45 PM   #172
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 3,778
Has your back forgotten the motor already? That's 3 very heavy molecules.
Luke is offline   Reply With Quote
Old 12-15-2012, 12:40 AM   #173
TwinDuro
TwinDuro's Avatar
Oddometer: 260
The Honda SOHC four, herniating spinal disks since 1969!
Old 12-15-2012, 06:36 AM   #174
RSRennsport
Navigator
RSRennsport's Avatar
Oddometer: 63
That's what titanium plates are for.
Just kidding
Strassen?
AHRMA # 59
RSRennsport is offline   Reply With Quote
Old 12-15-2012, 01:17 PM   #175
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 927
Not funny...
I just had a Ti plate in my neck go bad and 2 broken Ti screws. I had to have it all replaced last week after it failed.
Avoid that kind of mess at all costs. Almost cost me all ability to ride ever again and has cost me all dirt riding for 2.5 years so far and 6 more months ahead minimum.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 12-17-2012, 10:48 PM   #176
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 3,778
I got some fancy new carburetors a couple of weeks ago, and of course the outlet on them doesn't match the inlet on the head. I could have bought adapters but they take up an extra inch of space that I'd rather use for the airbox. So it's time to do more lathing.
Start with some round stock that is just the right OD, so I only need to turn out the middle. The downside of this is that the parts are a little eccentric, just like the rest of the bike.
The stock was supposed to be long enough to make 4 spacers and has a little extra for clamping. It turned out to be long enough for 5; the four I needed and one screwup.
Start by drilling out the center so that a boring tool can go in.
Then cut out the middle to the right diameter
The spigots are 30.0mm OD, so this is a .1mm press fit. It felt about right. The final part I did was more like .15mm and it was a bit on the tight side.
Cut the part off:
Side note: using the parting tool this far from the chuck didn't work very well until I used the tailstock to secure the part.
Present the parts for inspection:
Press it on the spigot, with sealant:
One done, three to go.
As mentioned, I did screw one up. It would have been the last one but the cutting tool got dull and started chattering. By the time I figured out what was going on it had cut the part to 30.0mm which was a nice slip fit, but not a proper press.
Finally, fitting one up to the carbs.
All in all, a good warmup to the shock bushing spacers that need to be made.
Old 12-18-2012, 12:45 AM   #177
TwinDuro
TwinDuro's Avatar
Oddometer: 260
Very nice; the spigots look great!
Dang...Keihin CR29s!
Old 12-18-2012, 04:39 AM   #178
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 561
Never mind the CB - what's the Dog working on when it's not busy training you?
Lovely build mate.
CambodiaYeah!
Jacl-Kampuchea is offline   Reply With Quote
Old 12-18-2012, 11:12 AM   #179
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 3,778
Nu uh.
CR26s
Originally I was going to get CR29s, but there were too many reports of them sucking. The common theme was that the carbs were too big for the 550 and would go way lean below 7k rpm. The fact that most people run them with pod filters doesn't help, but still.....
Sudco recommends CR29s for the 550, and probably because they're the only US importer, everyone else recommends the same thing. Except for Keihin. You know, the company that actually makes the carbs. They recommend the 26s for mildly built 550. For a full-on race motor on a racetrack, they do recommend going one size larger to the 29s. For a totally stock 550 they recommend going one size smaller. Or would, if that size existed.
But anyway, that agrees with what the sohcforumites were saying, so I bought a set of 26s. I do already have a set of CV carbs that one guy said worked well; good performace, terrible fuel economy. But, it seemed like a lot of potential screwing around to get them working right. I'd rather spend a week screwing around with jetting than a month.
Old 12-18-2012, 11:24 AM   #180
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 3,778
Lovely build mate.
A couple of weeks ago he was working on a rotting deer carcass. Then sprayed it back all over the house and shop. So he's not allowed to roam any more.
He used to ignore me, I'd have to crack a beer to get his attention. Now he answers to my voice. Good thing, because cold beer isn't so appealing in a 40* shop.
Times are GMT -7.   It's 02:03 PM.
