01-13-2013, 12:13 AM
#226 |
Racing Like a Noob
Oddometer: 4,291
Looking fantastic!
Racing a Subaru in the 2013 Mexican 1000 |
01-13-2013, 02:35 PM
#227 |
Oddometer: 4,296
So first test run will be Friday then?
I may have asked this already but where did you get your fork brace from? |
01-13-2013, 03:05 PM
#228 | |
GPoET&P
Oddometer: 3,777
Not this friday. Maybe the next. There's still an airbox, electrical system, exhaust, fuel tank mount, seat, clutch cable, rear brake to make before it's really rideable. The fork brace is a Superbrace brand that I bought from procycle.us I obviously don't know how well it works, but it does fit perfectly and has lips so that it won't work its way down into the tire. It might take up a half inch of suspension travel though. I'd need to pull the fork springs and test it to be sure. |
01-13-2013, 04:50 PM
#229 |
Oddometer: 4,296
01-13-2013, 06:56 PM
#230 |
Oddometer: 3,636
The morning started out chilly
Making progress ![]() Purty ![]() ![]() ![]() ![]() Still cold ![]() Measure ![]() Cut ![]() Well that was unexpected ![]() Precision ![]() ![]() ![]() ![]() debris ![]() ![]() ![]()
Allan |
01-13-2013, 10:30 PM
#231 |
Idiot
Location: The Beast (across the bridge from SF), California
Oddometer: 123
Your photos leave me in awe.
01-16-2013, 07:08 PM
#232 |
GPoET&P
Oddometer: 3,777
One step backwards, two big steps forward
I tried to come up with a way of not undoing some of the work I'd done and failed. At least, failed to find a way that was easier.
So out comes the cutting wheel. ![]() And back on it goes. Similar, but not the same. ![]() With the top mounts in the right place, it was time to fix the bottom mounts. First, clear up a lingering problem with the swingarm. ![]() Welding in the cross brace distorted the swingarm, which narrowed it up and twisted the pivot tube so that the bushing was slightly binding. Cutting, inserting a spacer in the slice and then welding it back up fixed it. ![]() Then it was time to attach the lower shock mounts. First measure then clamp then measure some more: ![]() Then weld weld weld. ![]() It's on its feet now. ![]() ![]()
01-16-2013, 07:21 PM
#233 |
Oddometer: 3,636
Wow great progress
Allan |
01-16-2013, 07:25 PM
#234 |
new orange flavor
Oddometer: 1,068
Looks really good. That rear suspension should be plush. Nice work, I am looking forward to seeing it in person.
I also like the tank, where did you find it? -John
An Elefant never forgets. 2012 Baja 1000 www.Raceforthewounded.com Help us race the 1000, and double the value of your KLR by buying a t- shirt |
01-16-2013, 07:47 PM
#235 |
Aspiring human
Oddometer: 2,180
wow, I am worried about the shock mounts. I thought they would be welded inside a hole drilled inside the side of the swing-arm. I know you are the engineery type and know where the force is applied and how it is safe and stuff. It just seems weird and risky to me. Maybe you can explain how welding two small cylinders to the bottom of the swing-arm is sturdy enough!
1987 Yamaha XT600 2KF (German) STOLEN: RED XL600 in Portland I do heavy-duty textile repair, upholstery, and design/manufacture bags. |
01-16-2013, 07:48 PM
#236 |
Racing Like a Noob
Oddometer: 4,291
Fantastic progress!!!
The tank was one that I bought at the 2011 AHRMA race in Chehalis. It almost made it onto our SL350, but didn't. It is a clark tank. I think it looks great on Luke's monster bike!!
01-16-2013, 07:52 PM
#237 |
Bug Sister
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 8,724
It's starting to look like a motorcycle.
2013 Hells Canyon/Wallowa Valley Gathering: http://www.advrider.com/forums/showthread.php?t=843668 "Always be a first-rate version of yourself, instead of a second-rate version of somebody else." - Judy Garland |
01-16-2013, 08:14 PM
#238 | |
GPoET&P
Oddometer: 3,777
This is just for testing. If the handling seems ok then I'll add some gussets up the side of the swingarm and then box those in. |
01-16-2013, 08:30 PM
#239 | |
GPoET&P
Oddometer: 3,777
Thanks! I'm looking forward to seeing you. It certainly _should_ be plush. Bouncing on the bike I can say that it's very ....uh..... resistant to bottoming. ![]() Among the things to do: revalve the suspension. |
01-18-2013, 11:30 AM
#240 |
On Any Sunday
Oddometer: 592
Air Box Stuff
Last night I came home and Luke was in the shop making air filter mock-ups that were similar to dimensions found in some air filter guide books. Here are two of them;
![]() Big one in projected air box intake area; ![]() Small one in projected air box intake area; ![]() Conclusion; we need Goldilocks to find us one that is "just right"! ![]() Luke took additional pictures of other bits he was working on yesterday, I'm sure he will post those soon with more commentary.
"Nothing can stop us but fear and common sense” |
