Old 01-24-2013, 01:39 PM   #286
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
I forgot to add the divide by...dohhhh
If you take the 3.1415 and divide by 4 you get the 0.785375
OR if you take the four 1" outlets at 0.785375 and times them by 4 the you get 3.1415....so my point being 4 outlets at 1" diameter is the exact same size as one inlet of 2"....
I deserved the jabs...
I do still agree that the flow based on TUNED flow could be the issue...but it is not a bad place to start.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-24-2013, 04:43 PM   #287
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,676
Good discussion.... Just wanted to make sure the beast can breath at WOT... Though knowing Luke, it has been thought through thoroughly...
Mr. Fisherman is online now   Reply With Quote
Old 01-24-2013, 05:53 PM   #288
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,139
And besides, this being an ADV build, the only equation relevant here is: N = C + {fb(cm) . fb(tc)} + fb (Ts) + fc . ta
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 01-24-2013, 06:47 PM   #289
Mr. Fisherman
PROUD 2B Riff Raff!
Oddometer: 10,676
1000 hours of testing, what could possibly go wrong?
Old 01-24-2013, 06:53 PM   #290
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 10,858
Nothing is going to go wrong Luke is going to nail this. I just wish I could be there when he crosses the finish line. I'll just have to settle for watching his SPOT during the race and seeing the pictures (Allan, that's you ) after it's over.
Ladybug0048 is offline   Reply With Quote
Old 01-25-2013, 09:05 AM   #291
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 730
E=mc2
"Nothing can stop us but fear and common sense”
LC Garage is offline   Reply With Quote
Old 01-25-2013, 09:09 AM   #292
MortimerSickle
Semi-Adventurer
Oddometer: 12,139
Originally Posted by ladybug0048 View Post
I just wish i could be there when he crosses the finish line.
f = ma
G.H.W.S. 1878-1962
Old 01-25-2013, 11:28 AM   #293
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 730
f = ma
This equation reminds me of flat tracking the old SL350, which unlike my Bultaco 350 Astro that was quick, twitchy and reacted instantly to input, riding the SL350 at speed required thought and planning. It was similar to snow skiing, you were very aware of your mass and momentum and somehow trying to gently direct that mass without scrubbing off too much speed. Kind of like doing ballet with an anvil.
Old 01-25-2013, 01:26 PM   #294
MortimerSickle
Semi-Adventurer
Oddometer: 12,139
Quoted for posterity.
G.H.W.S. 1878-1962
Old 01-25-2013, 09:02 PM   #295
Rich667
Rich667's Avatar
Oddometer: 177
Nice work! thats alot of dedication working out in the cold.
Rich667 is offline   Reply With Quote
Old 01-26-2013, 08:34 AM   #296
drc42
Rally Dreamer
drc42's Avatar
Oddometer: 1,836
Originally Posted by jesusgatos View Post
Gotcha. Do you have any kind of shop press? Dunno if you have any more bending to do, but these actually work pretty well. Or you could just buy one.
I have one of those, works very well. I used it to bend up 3/16" aluminum for my DRZ rally bike last year.
short video of me using it
odd... can't seem to get the video to embed.....
follow my journey: Dreaming of Dakar
drc42 is offline   Reply With Quote
Old 01-26-2013, 09:52 AM   #297
ducnut
Oddometer: 3,301
Some good ideas, there, as I've been looking at buying the HF 20T press. I don't need anything HD, just something to press balljoints, bushings, bearings, etc.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 01-30-2013, 01:54 AM   #298
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,158
I made a little more progress, recently. Unfortunately I had hoped to get the bike barely running this month but I'm not quite going to make it. It may only be a week or two late, so it's not too bad.
The carbs needed some screwing around. The air intake for the enrichener/choke draws from outside the carb, so I had to make up some hoses to route these to the airbox. The fuel line in this picture was too stiff, and I ended up switching to thinner vinyl hose. The wood under the carbs is drilled to match the float bowl caps so they rest in place. An essential tool if you're working on these things alone.
Next was closing up the airbox. The TIG torch made short work of it.
Here it is installed on the bike. The filter will be enclosed on the sides but should be accessible from the top.
The frame needed some mounting tabs for the rear subframe. The TIG mostly works well, but I sometimes I still spaz the starts.
With a lot of help from Rick the subframe was mostly finished. A couple of the welds are incomplete and it needs some gusseting, especially at the tails, but all the hard work is done.
Time for more posing.
Luke is offline   Reply With Quote
Old 01-30-2013, 02:29 AM   #299
TwinDuro
Befuddled Adventurer
TwinDuro's Avatar
Oddometer: 318
So awesome...
It looks like it's seat time!
"Remember, you may have to grow old, but you don't have to mature." - Red Green
TwinDuro is offline   Reply With Quote
Old 01-30-2013, 03:28 AM   #300
wayne_l
Oddometer: 182
i used to rally the pee out my stripped cb450 right up to the sound of the boom ..but i was hooked on bikes ever since ..
wayne_l is offline   Reply With Quote
Times are GMT -7.   It's 07:53 AM.
