Old 03-02-2013, 01:19 PM   #391
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 721
That thing sounds sweet! Great work (except for muffler mounting)
Jacl-Kampuchea is offline   Reply With Quote
Old 03-02-2013, 10:08 PM   #392
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,227
What is that I hear?......The rich sound of SPeeD!
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 03-03-2013, 12:11 AM   #393
DustyRags
Idiot
DustyRags's Avatar
Oddometer: 626
There is absolutely nothing polite, quiet, neat, soft, nice, clean or in any way civilized about that bike. My god, that's going to make every bastard on a BMW shit his pants when it shrieks by.
DustyRags is online now   Reply With Quote
Old 03-03-2013, 12:56 AM   #394
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,173
Allan and Ray helped out on Friday, we got a lot done.
For convoluted reasons I wanted to check the cam timing, we did and it was right. Since we already had the top of the motor often we figured we might as well re-torque the head. It's the good thing we did. I turned the first bolt the wrong way and it came loose in less than an eight of a turn. Not good. We weren't sure whether to loosen each bolt before re-torquing it or not, but they were all so loose that it was moot. All of the bolts were at around 5 ft lbs. We tightened them up to the 20 ft lbs that they are supposed to be.
We also checked the valve clearances; one was slightly loose, three or four had tightened up. None were down to zero clearance, though.
Next up was the jetting. I had leaned out the needles because the bike was blowing black smoke, that seemed to fix it but it didn't run very well. We tried a couple of richer settings which worked much better. The bike used to be difficult to get going from a stop without stalling, now it does burnouts with ease. The jetting's hardly perfect, but it's close enough to ride. The gas tank had always looked clean, but since I was also having issues that looked like fuel delivery we drained it and cleaned the petcock. It was all clean, but we also discovered that the petcock settings are not off-on-reserve like I thought, they are actually off-on-off. Another mystery solved.
Next was a basic handling check. I wanted to make sure that the rake was about right before welding in the rear shock mounts. Once those are on solid it will be very hard to make big changes to the geometry. We set the sag front and rear. The springs are all a bit too soft now, so needed a lot of extra preload to get them right. The rear spring collars are at the end of their adjustment and we added 1.25" spacers in the forks to get them right. A little test ride was taken and the geometry is declared 'close enough'. It doesn't resist turning too much, and the front end doesn't flop over in tight turns.
Last up was the exhaust. You've seen the results, the process was just as bad. I picked up a bunch of parts for fabricating a muffler on the back of the stock headers and that's where we started. I welded a slip fitting on to each of the headers and just for fun we stuck tube into the fitting to make shotgun pipes. Those sounded really nice. Just as loud as headers, but a better tone.
As we were discussing exhaust options, someone - I think it was Allan - remembered that Rick had an old supertrapp muffler laying around. So we hunted it down and just for fun tried to install it. It was a perfect fit on the inside of the header, and just a half inch too long to clear the rear shock mounts. It even cleared the centerstand. Rick came home as we were trying it out, and dug out the other matching muffler and we stuffed that in the other header and you've seen the results.
Luke is offline   Reply With Quote
Old 03-03-2013, 02:29 AM   #395
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
Wicked
I have seen some of the results and I guess as far as exhaust goes, all you need to keep them from blowing off might just be some thick wire mounts and either springs or safety wire to hold them on, I love little trick accessory stuff like that in a build. Once again, this build rocks my ass of and I have complete confidence in your ability to make A very capable race bike. You're going to let me take a spin when it's all said and done, right?
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 03-03-2013, 08:06 AM   #396
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,647
Nice Bike sounds awesome. I'd love to line it up against my 600...
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 03-03-2013, 08:18 AM   #397
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 10,955
You, Allan and Ray loose in a fully stocked garage could be entertaining. I hope Danny is keeping an eye on you guys. I would think Rick would keep you out of trouble but I see he's just as crazy.
Keep up the good work guys.
Ladybug0048 is offline   Reply With Quote
Old 03-03-2013, 08:27 PM   #398
Loud Al
Loud Al's Avatar
Oddometer: 3,908
Some Pics from Friday
Adjusting the valves
That man and his machine
Mr. Fisherman stopped by
Lets see if it works any better
Still needs work
Don't drop it
Ray isn't just a pretty face
That seems to work better
Let's work on that suspension
Exhaust version 1
Exhaust version 2
We got a bunch done but there is a bunch more to do.
A Quick Trip to Big Sur
Allan
Loud Al is offline   Reply With Quote
Old 03-03-2013, 09:03 PM   #399
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,216
Originally Posted by Loud Al View Post
Exhaust version 1
OK, that's the one we need to hear.
Where is YouTube when we need it.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 03-04-2013, 08:47 AM   #400
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,227
That seat cracks me up - it looks hard as a board.
Old 03-04-2013, 10:54 PM   #401
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,173
Yeahyeahyeah, the seat.
The other weekend Cory made up a really nice seat on the plastic pan. Over the week he made up a cover and attached it. He brought it down on Saturday and I was able to mount it up this afternoon. It looks really nice. I didn't take any close up pictures of it but should have. It's pretty firm, by request.
No more fir seat.
I did a little messing around with the carbs. I capped off the choke inlets- the hose system was just too complicated, and I don't want any unfiltered openings on the carbs so the chokes have to go. It shouldn't be that big of a deal, the bike doesn't need the chokes to run, and they can still be open to flood the motor for startup. Capping off the inlets required separating the outer carbs from the rack, so I re-synced them as well.
Last up was a weigh-in.
The original goal was to keep the weight similar to the stock 550, which was 420 pounds dry. Right now I'm at 395 pounds with not too much to add, so that's been a real success.
Old 03-05-2013, 12:31 AM   #402
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,173
That'd be fun.
Frankenrally anyone?
Old 03-05-2013, 03:33 AM   #403
DRjoe
DRjoe's Avatar
Oddometer: 5,096
Evil looking weapon.
Old 03-05-2013, 03:46 AM   #404
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,727
It is... I was bleeding within the first 5 minutes of working on it. "Whose blood is this? oh, mine"
Mr. Fisherman is online now   Reply With Quote
Old 03-05-2013, 08:07 AM   #405
Loud Al
Loud Al's Avatar
Oddometer: 3,908
Wow 395 full of oil and with a gallon of gas, I didn't think it would come in under 400. As long as you don't make the skid plate out of 1/4" plate steel you should be very close to 400lbs
Allan
Times are GMT -7.   It's 09:38 AM.
