Old 10-18-2012, 12:59 AM   #61
TwinDuro
Befuddled Adventurer
TwinDuro's Avatar
Oddometer: 324
What type of rod are you using and at what amperage?
Anyone have any tips on doing fillet welds on thin steel with an AC stick machine?
"Remember, you may have to grow old, but you don't have to mature." - Red Green
TwinDuro is offline   Reply With Quote
Old 10-18-2012, 10:48 AM   #62
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,221
1/16" 6013 @ 50A It's somewhere between perfect and a little bit hot for butt welds, but is a disaster for fillets. It seems to be right on the edge of burning thorough, but still won't stick in the root. It just goes to one side or the other. For thicker metal I'd just crank the heat up, but that doesn't seem to be an option here. I'll try messing around with the rod angle and arc length on some scrap. See how it goes.
Luke is offline   Reply With Quote
Old 10-18-2012, 12:38 PM   #63
TwinDuro
TwinDuro's Avatar
Oddometer: 324
Hmm... 6013 sounds like a good choice for the job... I'm far away from being an expert, but for some fiddling around, on scrap, I'd give 1/16" 7014 or 7018AC rod a try and see how you like those, the big downside being, they're both very sensitive to moisture, so keep them in a sealed container.
Old 10-19-2012, 12:21 AM   #64
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,221
So in the time-honored tradition, I'm blaming the tool.
I went and bought an inverter based DC welder. A Lincoln 130. It doesn't have the power of the buzz box, but it's also 1/10th the weight. I'll probably stick with the big welder for anything over 1/4", but there shouldn't be any of that on this bike.
I made a couple of short beads with it and it seems to work a lot better than the AC one. It'll take some practice to get right, then I can add a TIG torch and have to figure it out all over again.
Sorry, no pics of mine. I left my camera at the shop. Here's the CL picture, don't know how long it will stay up.
Old 10-19-2012, 02:15 AM   #65
TwinDuro
TwinDuro's Avatar
Oddometer: 324
Ooooh! Nice!
That should come in handy.... very handy!
There's nothing that warms my heart quicker then the bacon-like sizzle of DC stick welding...mmm bacon...
Old 10-19-2012, 08:48 AM   #66
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 759
Amps
After last night am about 80% completed on the dedicated 20 amp circuit for the little wire feed welder. Pulled 50' of 10/2 wire last night, mounted the outlet box (as well as the 220 box and receptacle for the bigger welders). Bought almost everything needed from the local Habitat for Humanity retail store, and all for about $5.00 (except the wire), love surplus shopping!
What would John Penton do?
LC Garage is offline   Reply With Quote
Old 10-24-2012, 10:50 PM   #67
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,221
Team Green Coats got a day of work in. First up was to try out the new welder. Alex hadn't ever welded before, so it was time to burn some rods.
I had ordered some parts to convert my mill to a lathe. It was a 'factory' conversion, and still needs some improvement- like a good tool post. I tried to turn some thick tube to make some inserts for stretching the frame, but the part wouldn't stay centered in the chuck- that setup really needs a tailstock. The other parts I was hoping to turn with this setup should be less demanding, but we'll see.
Then more grinding on the clutch cover. It finally fits properly over the primary gear, but has a little hole in it where I ground through in one point. Oh well, first project in line for an Al welder.
On to the transmission, where a slot needed to be cut in the shaft to lubricate the 5th gear properly. Precision Dremel work. The zipty guide/protector was Alex's idea, it worked perfectly.
Last project of the day was to mount the electronic ignition. It's made for a 500/550/750, so had to be modified to fit the 650 crank. The crank was drilled to accept the locating pin. No pics, that was a hairy operation. The new rotor was also drilled to work with the 650 bolt. New drill bits + good aluminum + drill press = easy.
Now that the rotor is on the crank, it doesn't want to come off. It's a nice tight press fit.
It was a pretty long day, but we all had a good time. Someone didn't want it to end.
(Larry, on the right, is supposed to go home with Alex in the Landy. Danny, on the left, isn't)
Old 10-24-2012, 11:14 PM   #68
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
Don't do it? Sorry, not sure I understand why you're messing around with sticks when you could just burn it in with that MIG welder and be done with it.
jesusgatos is offline   Reply With Quote
Old 10-25-2012, 04:33 AM   #69
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 11,203
Good to see the shop steward now has a helper to keep an eye on you guys.
Ladybug0048 is offline   Reply With Quote
Old 10-25-2012, 05:26 AM   #70
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 759
Agreed. Finished the dedicated 20 amp power supply for the 110 mig, so now it should have enough ooomph to weld properly. This was completed last night after Luke, Alex & Larry were already gone, hopefully they will get a chance to try it out today and report back.
Old 10-25-2012, 10:08 PM   #71
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,221
For part of the day. We had to kick them out while using the welder, so he had a helper to sniff things and pee on things and sniff things and rassle and sniff things.
Danny started frantically begging for my new drill bit; it took a while for me to realize that it was because it came in a ziploc bag, just like bacon strips.
Old 10-25-2012, 10:18 PM   #72
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,221
Because I've done so little work with a mig that it would probably just make a mess. Hopefully that will change.
Old 10-26-2012, 12:16 AM   #73
jesusgatos
jesusgatos's Avatar
Oddometer: 2,394
Haha, but MIG welding is what you do when you don't know what you're doing, and even when you do know what you're doing it's still the right kind of welding for this kind of work.
Old 10-26-2012, 04:36 AM   #74
Ladybug0048
Bug Sister
Oddometer: 11,203
Thanks for the morning giggle before I go to work. So Danny is an ADV dog with wanting bacon and all that sniffing and peeing sounds like ADV men too. Just don't teach those two how to do the ADV salute.
I don't understand most of what you are talking about in this thread but I'm enjoying it anyway. It's great seeing you guys working together on this project and what all you are coming up with to build this bike.
Old 10-26-2012, 04:47 AM   #75
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,808
G'day Luke and crew
Enjoying your build, bringing back a lot of great memories.
I found a set of Husky Ohlins were perfect for my build.
I extended the swing arm 100mm and they lined up perfectly
A couple if it finished and on its first ride
sorry for the hi-jack
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Times are GMT -7.   It's 03:50 PM.
