Old 09-06-2012, 07:08 PM   #1
De Eee OP
De Eee's Avatar
Oddometer: 172
450 EXC Won't Idle
Hey y'all. My 450 EXC (07) that has always been easy to start has gotten hard starting. I have to use the choke and never did before.
As well it doesn't idle like it used to. When it's warm and I rev it a bit the rpm drops off but then hesitates to return to idle.
I thought maybe the return cable was binding or broken.
Time to clean carb?
Idle jet?
De Eee is offline   Reply With Quote
Old 09-06-2012, 07:39 PM   #2
Gunslinger1
GIVE'R
Oddometer: 627
If the bike has been sitting with gas in the carb the pilot is probably congested..........it's easy to ck there first.
Gunslinger1 is offline   Reply With Quote
Old 09-06-2012, 07:43 PM   #3
Navin
Navin's Avatar
Oddometer: 8,236
Stock jetting? If so yourself a favor and install a JD jet kit while you are in there. Sounds like a partially clogged pilot jet but stock they are super lean already stock. The JD needle smooths the transitions between circuits and really brings the response up.
Navin is offline   Reply With Quote
Old 09-06-2012, 09:42 PM   #4
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,699
+1 sounds lean, you're on the right track. probably pilot.
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 09-06-2012, 11:13 PM   #5
crazybrit
crazybrit's Avatar
Oddometer: 8,557
The JD kit for the RFS is massively overrated IMO. The needle is too rich.
If you feel you need to reject, buy some jets from jetsrus and contact DJH on ktmtalk for his needle.
However, since it used to run well I would suggest you ignore those telling you to install X, Y and Z and instead ........
crazybrit is offline   Reply With Quote
Old 09-07-2012, 12:47 AM   #6
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 11,313
Check your breather hoses too. Shouldn't be too hard to diagnose.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Old 09-07-2012, 01:47 AM   #7
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,052
Check your valve clearances .
Brute is offline   Reply With Quote
Old 09-07-2012, 02:12 AM   #8
husqvarna
Oddometer: 139
Check spark plug & cap
I had a 525 that behaved in a similar way. Cleaned the carb multiple times. Eventually traced (by my local friendly mechanic; not me) to a bad spark plug cap; even though the plug sparked ok when checked. But check the plug as well.
husqvarna is offline   Reply With Quote
Old 09-07-2012, 07:49 AM   #9
Navin
Navin's Avatar
Oddometer: 8,236
If you just bolt it in and go it might not be as good as it can get. I find an hour of testing and tune yielded huge results on every bike i used those needles on, 520exc, 525SX a few Huskys and my most recent 505 and 530.The smoothness as the carb goes thru its circuits is far better to me than any stock needle.
Old 09-28-2012, 03:07 PM   #10
De Eee OP
De Eee's Avatar
Oddometer: 172
Yo, the JD kit took care of it. Nice power improvement as well.
Times are GMT -7.   It's 10:50 PM.
