Go Back   ADVrider > Bikes > Battle Scooters
Old 01-01-2015, 06:09 AM   #1
Jim Moore OP
Jim Moore's Avatar
Oddometer: 14,602
1987 Elite 150?
Hi Guys,
I'm about to go look at an Elite 150 from1987 with 10K miles. anything special I need to know?
thanks,
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 01-01-2015, 09:31 AM   #2
Jim Moore OP
Jim Moore's Avatar
Oddometer: 14,602
Well, thanks for the advice guys. Based on your recommendations I just bought a 1986 elite 150 deluxe in electric blue, complete with pop-up headlight, with 9400 miles for the princely sum of $750. It looks good, starts right up and runs up to 59 indicated on the 80s era digital speedo. Awesome!
Jim Moore
Jax, FL
Old 01-01-2015, 09:50 AM   #3
baloneyskin daddy
bikaholic
Oddometer: 2,176
I have the exact scooter, only red ,currently torn to shreds on my lift right now. It has almost 30,000 miles on it and runs like a clock. Started out wanting to fix a few minor issues and now its turned into a mess.Engine mount bushings ,noise in rear end which turned out to be variator issues.Believe it or not all the parts apparently are available,I hope. Its been nothing but a fantastic scooter that had a rough life.
baloneyskin daddy is offline   Reply With Quote
Old 01-02-2015, 07:20 AM   #4
Jim Moore OP
Jim Moore's Avatar
Oddometer: 14,602
Some questions. I didn't get documentation with this scooter. What weight oil do I use? What tires do you recommend? Are those tiny little rims actually tubeless? Any idea where to download a repair manual?
Jim Moore
Jax, FL
Old 01-02-2015, 10:42 AM   #5
theneckasaurus
Oddometer: 25
http://www.scootermasters.com/manual...nual_85-86.pdf
theneckasaurus is offline   Reply With Quote
Old 01-02-2015, 11:06 AM   #6
baloneyskin daddy
bikaholic
Oddometer: 2,176
They are tubeless and any tire you can find in that size will work and there aren't many anymore.As for oil I tend to use anything I have sitting around that's left over from other vehicles.Its only lubricating the engine,no clutch or trans so motorcycle specific oil is not necessary.I change mine every 1000 miles, rather than watching for the indicator to set off, because its easy to keep track of.My Elite 250 has 40k on it and the 150 has over 30k without an engine problem.Check for a cracked intake manifold if you have any performance problems,especially hard starting,I've never had a problem with the Honda elec.chokes.
Old 01-02-2015, 06:02 PM   #7
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 3,191
http://www.motorscooterguide.net/Man...ice_Manual.pdf
There the service manual for it . I would check the belt , rollers and see how old the tires are . Replace the anti freeze etc. Standard stuff to do with any ride you buy.
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is online now   Reply With Quote
Old 01-02-2015, 09:15 PM   #8
REALGRAVEROBBER
LEAVING GRAVES EMPTY
REALGRAVEROBBER's Avatar
Oddometer: 385
These seem super solid to me. I've only worked on one where the auto clutch 'failed.' Took it apart, cleaned it, couldn't find anything wrong, reassembled and it works like new.
I'd buy one if I could afford it/had room.
May want to get fresh tires as they do dry and get unsafe.
We have a lot to do with how the world receives us.
Dr. Frazier Writing
REALGRAVEROBBER is offline   Reply With Quote
Old 01-03-2015, 05:06 PM   #9
Eliter85
Eliter85's Avatar
Oddometer: 320
Fresh tires are fun. And 3.5 x 10 tires can cost as low as $30. So do it!
I'd clean the carb real quick, just standard carb cleaner. Then add some seafoam motor treatment to the gas tank and maybe every 5 tanks or so. Helps keep everything clean inside.
I've done a lot of work over the years to my elite. I'd say maybe 10% was required, the other 90% was just regular preventative maintenence.
Other things to think about are maybe a fuel filter added to the fuel line, Maybe a shut off valve for if you ever have to store it. Replacing all the fuel / vac lines is pretty easy and always good to do with 30 year old rubber lines.
Also another big thing is to check the rubber boot that goes from the carb to the engine. They're prone to cracking causing the bike to run lean.
Check my tumblr in my signiture!
Progress on eliter! - eliter85.tumblr.com
1985 CH150 Eliter | 2006 Yamaha Morphous
Eliter85 is offline   Reply With Quote
Old 01-13-2015, 04:29 AM   #10
scootrboi
scootrboi's Avatar
Oddometer: 1,693
a good solid scooter
I put Michelin S-83s on mine and they work well, a good universal tread.
42 years on a Heinkel Tourist
scootrboi is offline   Reply With Quote
Old 01-13-2015, 05:46 AM   #11
rut3556
rut3556's Avatar
Oddometer: 105
>>complete with pop-up headlight<<
And does it pop up? That's sometimes a weak spot with Elites.
"Foreign Aid: The transfer of money from poor people in rich countries to rich people in poor countries."
rut3556 is offline   Reply With Quote
Old 01-13-2015, 07:24 PM   #12
fullmetalscooter
Oddometer: 3,191
Gee also a weakness with old men , does it still pop up at all ?
Old 01-14-2015, 02:16 AM   #13
Jim Moore OP
Jim Moore's Avatar
Oddometer: 14,602
Hey! This isn't about me!
Jim Moore
Jax, FL
Old 01-14-2015, 07:44 PM   #14
fullmetalscooter
Oddometer: 3,191
Sorry I m a stand up comic with no filter at all. Really I have AIDS : Asshole in Denial sydrum . Beside I m getting old myself I had a 18 year old wave as she walk up the stairs and I thought i wanted to get her drunk. Yah so she would leave me alone .
Old 01-15-2015, 05:56 AM   #15
scootrboi
scootrboi's Avatar
Oddometer: 1,693
take a look in the shop manual
The manual shows how to adjust the pop up headlight. I think Honda pulled out all the stops to make a bullet proof pop up mechanism, after a few minutes with the original CH125 shop manual I had mine working again, It is a 1984.
Times are GMT -7.   It's 08:31 PM.
