Go Back   ADVrider > Bikes > Battle Scooters
Old 09-11-2012, 05:40 AM   #1
scottorious OP
Oddometer: 9
ch150 carburetor question
I just acquired a kind of basket case ch150 and I want to build a skelly out of it. I am in the process of rebuilding the carburetor and this model has an air cut-off valve. I didnt get the valve while it was put together so I am not sure if there are internals that I am missing. Is anyone familiar with that? The parts view only shows the entire valve and the service manual doesnt mention anything about whats inside the valve body.
scottorious is offline   Reply With Quote
Old 09-11-2012, 10:30 AM   #2
tortoise2
tortoise2's Avatar
Oddometer: 579
Originally Posted by scottorious View Post
air cut-off valve
This video may or may not help . . link.
tortoise2 is offline   Reply With Quote
Old 09-11-2012, 06:09 PM   #3
bbishoppcm
It ain't a moped.
bbishoppcm's Avatar
Oddometer: 666
That video SUCKS. Try this one instead; http://www.youtube.com/watch?v=dxpI-SY39AM
bbishoppcm is offline   Reply With Quote
Old 09-11-2012, 06:12 PM   #4
bbishoppcm
It ain't a moped.
bbishoppcm's Avatar
Oddometer: 666
The cutoff valve should never be disassembled; but yours should include a diaphragm, a tiny o-ring, and a spring. If either part is missing, you'll need to either buy a whole new valve from Honda, or buy a used carb off eBay. You can buy a Chinese carb and use it for parts, but beware; the Chinese carbs are a TOTAL gamble (as you'll see in the first video sent by tortoise), but can save you a bundle in parts IF the parts were accidentally made right! In the case of my Honda Helix, the original cutoff valve was leaking, and the o-ring was not available ANYWHERE! I ended up having to buy a whole new valve... for around $90.
Old 09-11-2012, 07:10 PM   #5
scottorious OP
Oddometer: 9
thanks for all the info. After seeing the video I could see that I no longer had the parts that go inside. I was able to find one on ebay for 19 dollars and i sprung at the chance after seeing that those things are expensive to buy new.
Old 09-11-2012, 07:30 PM   #6
bbishoppcm
It ain't a moped.
bbishoppcm's Avatar
Oddometer: 666
Just don't open it! There is a test procedure to verify the valve actually works; the exact procedure escapes me right now though...
Times are GMT -7.   It's 04:49 AM.
