Old 04-12-2013, 03:43 AM   #2266
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
Useful Information/Specs
Valve clearance (with engine cold)
Intake............................................ .................0,009 0,011 in (0,23 0,28 mm)
Exhaust........................................... ............. 0,015 0,017 in (0,38 0,43 mm)
Spark plug type.............................................. .................."NGK" MAR9A-J-G06
Spark plug electrode gap............................................... .....0,024 in ( 0,004 in)
0,6 mm ( 0,1 mm)
Drive chain dimensions........................................ ...................520KR0 112 links
lubricating oil................................ CASTROL POWER1 RACING SAE 10W-50
Oil and oil filter replacement.................................................. ................... 0,44 Imp. Gall. / 0,528 U.S. Gall. / 2.0 l
Topping up oil between minimum and max. level.................................. 0,055 Imp. Gall. / 0,066 U.S. Gall. / l 0.25
Torque Specs (Nm):
Fastening of tank assembly screw on LH side 8,0
Fastening of mesh oil filter on chassis 10,0
Fastening of oil pipe clamps 3,0
Fastening of plug on union for oil drainage from chassis 24,0
Fastening of oil delivery/return/breather pipes on engine 38,0
Fastening of rigid pipes on engine cylinder head seat 12,0
Fastening of engine to chassis on LH side 5,0
Fastening of oil refuelling cap on chassis 10,0
Fastening of ECU to support 8,0
Fastening of ECU support to chassis 8,0
Fastening of ignition/starter lock 19,0
Fastening of handlebar clamps 19,0
Fastening of steering upper plate nut 80,0
Fastening of handlebar clamp screws 19,0
Fastening of fork plate side screws 19,0
Fastening of brake pipe screws to pumps/callipers/ABS ECU 24,0
Remove the two screws of the bottom yoke on LH side and refit with plate 12,0
Tightening of bushing for adjustment of swinging arm clearance 6,0
Fastening of swinging arm pin to chassis 120,0
Fastening of engine lower screw on chassis 38,0
Fastening of engine LH screw to chassis 38,0
Fastening of engine RH screw to chassis with spacer 38,0
Fastening of engine front clamp nuts 24,0
Fastening of engine clamp plate - close 56,0
Retrieve the lower clamp upper screw - reclose 56,0
Retrieve the lower clamp lower screw - reclose 56,0
Fastening of clamp on throttle body coupling 0,6
Fastening of earth cable to engine cylinder RH side 8,0
Fastening of nut for starter motor cable 6,0
Fastening of neutral sensor cable to engine RH side 0,8
Fastening of turn indicator screws 2,0
Fastening of light support to upper plate 5,0
Fastening of front fairing support bracket screws to light support 2,0
Fastening of filter box air temperature sensor 2,0
Fastening of cover to filter box base 2,0
Fastening of central front locking to filter box base 2,0
Fastening of filter drawer to filter box base 1,5
Fastening of filter drawer to filter box 2,0
Fastening of top of shock absorber 56,0
Fastening of bottom of shock absorber 56,0
Fastening of rear suspension kinematic mechanisms 80,0
Fastening of airbox to RH seat of chassis 2,0
Fastening of expansion tank to chassis (LH side) 1,0
Fastening of airbox to chassis (LH side) 8,0
Fastening of pinion guard 4,0
Fastening of rear chassis 28,0
Fastening of fuel tank to rear chassis 8,0
Fastening of fuel tank to chassis (RH side) 8,0
Fastening of gear shift pedal to chassis 13,0
Fastening of number plate holder to rear chassis 2,0
Screws for fastening saddle release onto chassis 8,0
Screws for fastening saddle release onto chassis 3,0
Fastening of rear mudguard lower clamp to chassis 2,0
Fastening of ECU to support plate 6,0
Fastening of ECU support plate to rear mudguard 1,5
Fastening of sprocket 19,0
Screw for fastening footrest fixing plate onto support 8,0
Fastening of rear brake master cylinder 8,0
Fastening of rear stop switch cover 0,7
Fastening of stop switch support 2,0
Fastening of rear brake lever 28,0
Fastening of side stand 38,0
Fastening of side stand switch 5,0
Fastening of silencer to chassis 19,0
Fastening of silencer and manifold clamps 19,0
Fastening of front manifold to cylinder head 19,0
Fastening of Lambda sensor to manifold 45,0
Fastening of heat-protecting cover onto exhaust manifold 8,0
Fastening of RH and LH footrest supports to chassis 56,0
ABS - Fasten rear brake pipe to master cylinder using screw and two washers 10,0
ABS - Fasten rear brake pipe to master cylinder using screw and two washers 24,0
Fasten the delivery and return pipes to engine seat 3,0
Fastening of top of radiator to chassis 8,0
Fastening of BLOW-BY pipe from filter box to engine ignition cover 2,0
Fastening of BLOW-BY pipe to filter box 2,0
Fastening of horn 5,0
Fastening of voltage regulator plate to engine 5,0
Fastening of front mudguard / fork guards 5,0
Fastening of front wheel axle 80,0
Fastening of screws on fork feet 8,0
Fastening of front brake calliper 38,0
Connect and fasten front brake pipe to brake calliper seat 24,0
Terra-fastening of wire guide plate to LH fork guard 1,5
Strada-fastening of wire guide plate to mudguard 1,5
Fastening of front wheel speed sensor 8,0
Fastening of voltage regulator 8,0
Nut for rear wheel assembly pin 30,0
Tighten rear wheel axle to torque 100,0
Screw for fastening brake hose ring to swinging arm seat 7,0
Fastening of rear wheel speed sensor 8,0
Fastening of chain casing 8,0
Terra-fastening of pushrod to front mudguard tail 1,5
Fastening of front fairing / front mudguard lower clamp to plate 8,0
Front fastening of front fairing lower clamp to light support 2,0
Rear fastening of front fairing lower clamp to light support 2,0
Fastening of front headlight to support 2,0
Fastening of voltage regulator guard 5,0
Fastening of anti-theft cover 2,0
Fastening of rear brake oil tank 2,0
Fastening of chain slider to swinging arm 5,0
Fastening of clutch control assy clamp 5,0
Fastening of LH switch to handlebar 2,0
Fastening of front master cylinder to handlebar 5,0
Fastening of RH switch to handlebar 2,0
Fastening of throttle control to handlebar 3,0
Fastening of front brake disc to rim 11,0
Fastening of rear brake disc to rim 11,0
Fastening of tone wheel to brake disc 5,0
Fastening of chain roller 8,0
Fastening of fuel pump ring nut to tank 6,0
Fastening of fuel cap ring nut 3,0
Fastening of reflectors to number plate holder 0,8
Fastening of turning indicators 2,0
Fastening of licence plate light to number plate holder seat 3,0
Fastening of tail light to number plate holder seat 3,0
Fastening of radiator guards 1,8
Fastening of sides to chassis 1,8
Fastening of side connecting cover 1,8
Fastening of scoops 1,8
Fastening of tank cover 1,8
Fastening of heat-protecting covers onto silencers 5,0
Fastening of front fairing 1,8
Fastening of luggage rack 19,0
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 04-12-2013, 03:58 AM   #2267
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,697
Originally Posted by Some Dude View Post
I doubt we'll see a G650GS in BMW's line-up come 2014 anyhow, I'm willing to bet they have something in the pipeline to replace it by 2015 for sure.
I thought those were selling pretty well.
What about the Sertao?
The Murph Channel
Acoustic Originals and some Double Aught
http://www.youtube.com/channel/UCkomGsMJXH9qn-xLKCv4WOg
Murphy Slaw is offline   Reply With Quote
Old 04-12-2013, 07:07 AM   #2268
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 9,139
I've been to three BMW dealers that reported less than stellar sales of the Sertao. It really is kind of unimpressive for the price. It looks the part, but doesn't really seem to perform it offroad.
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 04-12-2013, 11:38 AM   #2269
spjinseattle
Strom and DR Rider
spjinseattle's Avatar
Oddometer: 20
Ricochet Skid Plate - $110
http://www.ricochetoffroad.com/store/page484.html
spjinseattle is offline   Reply With Quote
Old 04-12-2013, 12:39 PM   #2270
LosOsos
New Old Guy
Oddometer: 4
Originally Posted by spjinseattle View Post
I ordered one yesterday in Black and it has already shipped. That was fast.
LosOsos is offline   Reply With Quote
Old 04-13-2013, 09:15 AM   #2271
farp
DualsportBC Rider
farp's Avatar
Oddometer: 81
Hey Rugged Exposure, thank you for all that data. I've been looking for some of those specs and they've been hard to find. Good job.
John
A motorcycle will go anywhere the rider has the ability to take it
2014 Yamaha XT250; 2013 Honda CB500X
farp is offline   Reply With Quote
Old 04-13-2013, 04:05 PM   #2272
RuggedExposure
Oddometer: 1,247
John
No problem.
What could I be up to now...?
RE Fotowerks
Old 04-13-2013, 04:31 PM   #2273
Muddler
Muddler's Avatar
Oddometer: 797
Originally Posted by RuggedExposure View Post
No problem.
Paint job?
Muddler is offline   Reply With Quote
Old 04-13-2013, 04:39 PM   #2274
RidingDonkeys
Purveyor of Awesome
Oddometer: 9,139
I'm going with he's adding a sidecar for his dog.
Old 04-13-2013, 04:53 PM   #2275
wolftrax
wolftrax's Avatar
Oddometer: 471
I know he was going to check his valves.
Mark
2014 Honda CRF250L
2013 Husky TR 650
1990 KLR650
wolftrax is offline   Reply With Quote
Old 04-13-2013, 06:09 PM   #2276
Beemermcr
Big, Dumb, Happy!
Beemermcr's Avatar
Oddometer: 293
Changing tires since he trashed them on the Border run and, lets see ------- engine guards??
Paul Baird
Sandy, UT
2013 Husky/BMW/KTM Terra
2000 DRZ "Burro"
Beemermcr is offline   Reply With Quote
Old 04-13-2013, 08:39 PM   #2277
RuggedExposure
Oddometer: 1,247
Mark
Not quite yet, still 2k miles out. But this helps me realize what all I'll have to take off to get to them.
Originally Posted by Muddler View Post
Paint job?
Close...
Closer...
RE Fotowerks
Old 04-13-2013, 08:39 PM   #2278
RuggedExposure
Oddometer: 1,247
Yes. You nailed it.
RE Fotowerks
Old 04-13-2013, 08:58 PM   #2279
Chazbo
Oddometer: 149
Yes. You nailed it.
I'm thinkin wheel change and add ABS instead.
Chazbo is offline   Reply With Quote
Old 04-14-2013, 05:44 AM   #2280
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,774
He's parting it out!
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Times are GMT -7.   It's 01:09 PM.
