Old 11-05-2013, 07:59 AM   #3331
kjackbrown
Oddometer: 104
Interesting!
kjackbrown is offline   Reply With Quote
Old 11-06-2013, 01:06 AM   #3332
Delnari
Tom
Delnari's Avatar
Oddometer: 88
Safari Tanks USA - Ready for Orders
I noticed this morning the Safari Tanks USA website now has the new gas tanks listed. Price is $735.99 including domestic shipping. Still waiting for the instructions to be posted to see what changes are made to the OEM tank setup, if any before I purchase. From their website listing:
Husqvarna TR650 long range Safari Tank
Litres: 32 (18 litres +plus 14 litre standard tank)
Gallons: 8.46 total
Colors: White, Red, Black, Translucent White
Includes: mounting kits and fuel line connections to connect to the standard fuel line system.
Delnari is offline   Reply With Quote
Old 11-06-2013, 01:25 AM   #3333
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 11-06-2013, 06:40 AM   #3334
William42
William42's Avatar
Oddometer: 2,978
Enjoyed your ride and repair report Rugged Exposure.
Mud is evil
William42 is offline   Reply With Quote
Old 11-06-2013, 07:03 AM   #3335
RuggedExposure
Oddometer: 1,247
You're welcome!
Stay tuned for part II coming in the spring... Lukeville to San Diego
RE Fotowerks
Old 11-06-2013, 07:59 AM   #3336
beerbuzz
beerbuzz's Avatar
Oddometer: 250
Gallons: 8.46 total
Lucky a holes! Check on a tank for a sertao sometime and that things a steal.
12 G650 sertao
03 DRZ400e
03 YZ250F
99 TTR225
beerbuzz is offline   Reply With Quote
Old 11-06-2013, 09:15 AM   #3337
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,109
Gallons: 8.46 total
5% discount available
http://www.advrider.com/forums/showthread.php?t=717160
http://justgastanks.com/product_info...oducts_id=5216
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 11-06-2013, 05:20 PM   #3338
Delnari
Tom
Delnari's Avatar
Oddometer: 88
Gallons: 8.46 total
Received a response back from Safari Tanks today. You do need to tap a hole into the side of the factory tank to mount the fuel connector between the two tanks. The Safari tank feeds the factory tanks so no moving the of the fuel pump assembly is needed. Trying to decide if a tapped hole in my factory tank is worth it to have over 4 more gallons available. Message from Safari Tanks:
To enable the connection of the Safari tank set to the standard fuel system on the TR650, the instructions will state that a 13mm hole will need to be drilled into the standard tank to enable connection of the fuel line from the Safari tank set. This would mean if you were to remove the Safari tanks and fuel lines, an appropriate rubber plug or equivalent would need to be used to seal the fuel inlet hole. I have attached a pic to help explain the setup.
Old 11-07-2013, 09:44 AM   #3339
RuggedExposure
Oddometer: 1,247
I would be worried about that tube and mount being damaged when the bike is laid over.
That would probably end your ride.
RE Fotowerks
Old 11-07-2013, 04:10 PM   #3340
Quirky
Quirky's Avatar
Oddometer: 585
Ordered a Terra Safari tank today. The likelyhood of that fitting being ripped out or damaged seems small to me. I reckon there would be many other weaknesses to consider (me being one of them).
BMW R1200GS, Yamaha WR250R
SPOT link
Quirky is offline   Reply With Quote
Old 11-08-2013, 08:27 AM   #3341
kjackbrown
Oddometer: 104
Yeah, looks recessed enough.
Old 11-09-2013, 03:24 PM   #3342
AltRoute
AltRoute
AltRoute's Avatar
Oddometer: 282
another thing to remvove when you change the oil
might want to put a self sealing quick connect fuel lines so you can just leave the line there
AltRoute is offline   Reply With Quote
Old 11-09-2013, 06:14 PM   #3343
William42
William42's Avatar
Oddometer: 2,978
TCI Rack
Very happy with the rack. It fit and seems strong enough.
Excellent customer service from TCI
Mud is evil
Old 11-19-2013, 01:49 AM   #3344
27rich
roughing it :)
27rich's Avatar
Oddometer: 379
New Terra on its way
well just put down a deposit for the Terra, non available in SA or Husqvarna Australia, so now have to wait the two weeks for delivery from a bike shop interstate.
Quirky, what colour safari tank are you getting and can you post pics
2010 KTM 990A
2013 TR 650 Terra
2007 TE 510
1989 XTZ 750 super tenere SOLD
27rich is offline   Reply With Quote
Old 11-19-2013, 02:49 AM   #3345
Quirky
Quirky's Avatar
Oddometer: 585
"Translucent" would be the colour. I figure no fuel gauge so may as well see the damn fuel level. Can post pics when I get the tank.
Lots of little jobs ahead setting this little workhorse up.
When you get yours, check the clutch cable out it rubs on the sharp edges of the radiator and on the stupid guide. I used some clear 1/2" hose as another sheath and then also used "P" clamp that snugs the clear hose just enough, instead of the stupid guide.
Cheers
SPOT link
Times are GMT -7.   It's 02:57 PM.
