09-18-2012, 11:19 PM
#91 |
Winter wonderlanding
Oddometer: 356
I believe the "10% power increase" when I see it. Husky also claimed "20% more power" with TE630 over TE610, but imo, it never materialized, not even close.
Marketing dept. % numbers won't move the bike, actual measured horsepower (hp) and torque (Nm) will. I hope they can prove the 58hp true, but won't hold my breath... FinnDuro screwed with this post 09-19-2012 at 12:58 AM |
09-19-2012, 01:52 AM
#92 | |
Lost but laughing.
Oddometer: 4,569
Barton has down over 30,000 (miles I presume) on his 570 with valve adjustments only. Lukas can give more info on this. I am sweating on the spec of the forks and shock on the Husky 650, really hoping it is a lot better than the XChallenge was.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. |
09-19-2012, 02:54 AM
#93 |
I Am the Mayor
Oddometer: 15,612
Very positive first UK review from MCN; they say the build quality and finish is excellent, and the bike is a lot of fun. They also quote the 58bhp figure, as well as 59ftlb of torque (regular G650 is about 44ftlb?).
They say modded FI, lighter forged piston, bigger valves, modded cams and increased compression ratio. Say it rides like a twin on open roads, not lumpy at all. Fuel economy is quoted at 63mpg (imperial) at a steady 74mph, so 190 miles even when riding quickly. They like the Brembo brakes (ABS can be turned off) and the flickable nature of the chassis. Front forks are USD Sachs (non-adjustable), rear is Sachs adjustable for preload and damping. Factory accessories are: screen, h/guards, panniers/box, h/grips, crash bars, and alarm. No mention of bash plate, but it would seem natural to add one.
IBA #40578 shine on, you crazy emo diamond RaY YreKa screwed with this post 09-19-2012 at 03:01 AM |
09-19-2012, 06:17 AM
#94 | |
AltRoute
Oddometer: 263
![]() ![]() http://www.cycleworld.com/olgallery/77456/77463 |
09-19-2012, 06:38 AM
#95 |
Oddometer: 5,616
It is a BMW. You are supposed to accesorize the bike with stuff like skid plates, hand guards, etc. BMW riders live for that. So you Husky riders need to get with the program and look for a new page in the Twisted Throttle catalog.
KTM 640 LC4E KTM 200 MXC XT200 |
09-19-2012, 06:50 AM
#96 |
beat up ex flat tracker
Oddometer: 6,757
Yah,BMW has kind of dis-appeared Husqvarna from what I see,they put that weird alice 450 engine into a Husqvarna labeled package,I think they jumped the shark on that one,way too heavy,oddball clutch on crank and some other neato things that just arent needed on a dirt bike. Dirtbike guys know better and will avoid it like the plague.
This 650 Terra could be good,if it weighs 400+ lbs and costs 9000.00 then its in twin territory pretty much,it looks neat but its a shame to abandon the old Husky 630 engine. Im hoping for the direct injected 2 strokes that are rumored to be in the pipeline.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
09-19-2012, 07:32 AM
#97 |
Oddometer: 5,616
That will get me into a Husky dealer ...... assuming I can find one within a light year of Annapolis.
09-19-2012, 07:38 AM
#98 |
Neville1 to TT boys
Oddometer: 303
Husky site has finally been updated again. They now have dual sport and dual purpose categories. The site isn't 100%, but if you select the RANGE button, you see all 5 categories, because the main selection page still says "dual sport" twice.
http://www.husqvarna-motorcyclesna.com/index.php New dual purpose category listed. http://www.husqvarna-motorcyclesna.com/range.php |
09-19-2012, 07:46 AM
#99 | |
Oddometer: 3,809
"Deeply flawed people make deeply flawed decisions." |
09-19-2012, 07:54 AM
#100 |
Deputy Cultural Attaché
Swap out the stock battery for a new lightweight Shorai.
Successfully surviving motorcycling since 1976. |
09-19-2012, 09:59 AM
#101 |
Oddometer: 1,460
Yep, already thinking about that, Yossarian!
09-19-2012, 10:39 AM
#102 |
Neville1 to TT boys
Oddometer: 303
Why are people so concerned about making a 400+ lbs motorcycle lighter? It doesn't have the TE suspension, and it's over 150 lbs more than an offroad vehicle should weigh. So, what's the point if you get it from 407 to 360, seriously? If this is a concern, why not buy the TE511 and shorten the suspension 4-5" and get a more comfortable seat made?
09-19-2012, 10:49 AM
#103 | |
Oddometer: 4,904
![]() But I'll try cause I'm nice like that: the idea is to have a bike that is not a fat overweight pig (407 lbs) yet does not need an engine rebuild every x,000 miles like the TE (maybe 1x,000 if you are lucky?).
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
09-19-2012, 10:51 AM
#104 |
Oddometer: 1,743
Specs say it has a Marelli EFI.
The BMW's have Bosh, right? Husky's EFI's are tuner friendly, correct? My X-Challenge like many modern BMW's was plagued with stalling/starting EFI bugs and BMW's locked down software sucked. |
09-19-2012, 10:55 AM
#105 | |
Neville1 to TT boys
Oddometer: 303
Does anyone have stats on engine rebuild with the TE's, or is this just speculation, because if you check the things done to make the BMW engine get 10+ more HP, it looks like it puts in in the same realm as needing work done as the TE. Over a 12 on compression. I tried this on my DR650 years ago, and it NEVER really became more capable. Lighter headlight, rear fender, now this shoria battery, lighter exhaust. It's still a pig with lipstick. Sure, i can tell when a bike weighs 50 lbs less, but if the suspension isn't made to hack the terrain, and the cases get hung up on things a TE won't, the point is you got the wrong bike. Believe me, I'm seriously looking at this as a contender, but I can keep my DR if I want a passenger, and get the TE because it's just more capable overall. |
