Old 05-28-2013, 06:51 AM   #1
TheOtherBart OP
TheOtherBart's Avatar
Oddometer: 1,995
Filler for ~1/4" depressions?
I have a little CM200 that I bought off an inmate that I'm turning into a little rat cafe racer. Someone in the past had painted the whole thing flat black, so I'm just going along with the whole Mad Max thing.
The tank on these bikes originally had a hinged cover over the gas cap. This one is long gone (and I wouldn't want it anyway), but there are two big depressions in the tank where it mounted. I'd like to fill them but I'm concerned that whatever I fill them with would crack because of how deep they are. This whole bike is supposed to come in <$500 ready to roll, are there any cheap products that would do the trick?
TheOtherBart is online now   Reply With Quote
Old 05-28-2013, 01:40 PM   #2
396
low-post lurker
396's Avatar
Oddometer: 204
I think you should cut & weld in a filler piece.. Bondo that thick will just crack.
396 is offline   Reply With Quote
Old 05-28-2013, 01:53 PM   #3
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 5,658
Hard to picture, but maybe fiberglass or even jb weld.
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 05-28-2013, 02:21 PM   #4
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,614
^Glass is what I was thinkin . . . . . .
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 05-29-2013, 04:51 AM   #5
kfsinc
Chaingolian Observer
kfsinc's Avatar
Oddometer: 2,585
paintless dent repair??
basically a suction cup on steroids.
Karl
R1100GS
F650GS -- sold -- what's next?
“If everything seems under control, you're just not going fast enough.”, Mario Andretti
Indulge. Repent. Repeat.
kfsinc is offline   Reply With Quote
Old 05-29-2013, 05:11 AM   #6
bill h
Oddometer: 146
try USC all metal
it is a modern substitute for lead.
some testimonial here
http://www.jalopyjournal.com/forum/s...8308&showall=1
yes, I have used it, on a 73 Alfa GTV I am restoring, and am happy with it.
Bill
bill h is offline   Reply With Quote
Old 05-29-2013, 09:33 AM   #7
TheOtherBart OP
Oddometer: 1,995
That's what I figured about Bondo, hadn't thought about either JB Weld of fiberglass. Welding in a patch would be the "right" way to do it I'm sure, but I don't weld and for this project I don't want to pay anyone to weld either.
I don't think the paintless repair would work because these are shapes actually pressed into the panel with fairly crisp edges. I'll try to snap a picture this evening and post it.
Old 05-30-2013, 12:24 PM   #8
396
low-post lurker
396's Avatar
Oddometer: 204
Devcon would probably do the job. It's a metal filled epoxy. It comes in either steel or aluminum filled. You can grind / file / sand after it cures. Then touch up any imperfections with bondo. Sets up pretty hard & should hold up ok.
http://www.mcmaster.com/#devcon-adhesives/=mz81l6
Old 05-30-2013, 02:46 PM   #9
Roland44
Oddometer: 908
Fiberglass it! Quick, simple and it works..
Roland44 is offline   Reply With Quote
Old 05-31-2013, 08:45 AM   #10
TheOtherBart OP
Oddometer: 1,995
I've done a little bit of fiberglass work in the past but just simple things like patching up a cracked canoe. Can you walk me through how you'd approach this? I'm envisioning sort of filling the void with fiberglass mat and then cloth over the top?
Old 05-31-2013, 08:52 AM   #11
ragtoplvr
Oddometer: 6,526
Lead
ragtoplvr is offline   Reply With Quote
Old 06-01-2013, 06:34 AM   #12
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,720
Originally Posted by bill h View Post
try USC all metal
Bill
Thanks...my friend needed that. He was thinking of leading that old Triumph tank but I think he'll go for that now. It can be powdercoated and is available in Canada. I think I'll pick some up anyway and give him the can then I can use it at his shop for my own projects and then get real cheap (too cheap) powdercoating done by him.
Have tools, will travel!
Old 06-02-2013, 12:00 PM   #13
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,853
I ordered some USC all metal right after reading this and i don't even have a need at the moment.
Trying to be prepared, what could go wrong ?
Thread Tools
Times are GMT -7.   It's 02:53 AM.
