01-31-2013, 11:09 AM
#346 | |
Unwounding
Oddometer: 4,318
Mine may end up just wearing the top 1/4 fairing at some point. I may have it finished as far as modding so it'll stay for now but going under the hood is a PITA.
01-31-2013, 11:59 AM
#347 | |
BAZINGA!
Oddometer: 3,893
'12 Kymco Downtown 300i ABS, '08 Yamaha FZ6n S2 ABS SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125 My Flickr gallery |
01-31-2013, 02:50 PM
#348 |
Oddometer: 897
I really hope they keep both styles around. I would love to get one of these bikes, but I by far prefer the more fully faired version.
(No accounting for tastes, variety is the spice of life, etc. etc.) |
02-04-2013, 06:55 PM
#349 |
Unwounding
Oddometer: 4,318
2002 GSXR 750 brake caliper on a custom bracket.
![]() Corrects the stocker's deficiencies quite nicely.
02-05-2013, 09:41 AM
#350 |
Unwounding
Oddometer: 4,318
02-14-2013, 08:18 PM
#351 | |
Ihave2draft
You're headed in the right direction but let personal views side-track your thinking... I bet, no GUARANTEE, someone said the same exact thing on here when they heard of the new KTM 350... Bumping up displacement will always be the easy way out considering one prolly has already gotten the most out of what ever bore & Stroke = 250 cc's. And as long as the insurance breaks are set in Tennessee anyway at 501cc's, then who cares? All that does is let me ride a "hot" bike like a SMR450 at 250cc insurance premiums? Not to mention, who's gonna tell or even know, if I BB a KTM 450 into a 510cc machine? Get it? All this stroker 250 bike does anyway is open the door for aftermarket to step in with a BB kit... Toyota Scion anyone? But now hold on a minute and don't color me a hater. I'm here in search of a light-bike, one that does not "wake up" at 71 mph and is usually ocompanied by the phrase; "He'll have to catch me first.." ![]() Until then, I'll be draw to crazy number cc bikes like a moth to a flame in order to search out this fast enough, but still "Dayyyyyumm!!!" light bike. It's like my NX... (Yeah, yeah) 280lbs? Fast enough, what maintenance(?), and cool as shit! Now compare that to the CRM250 I've been drooling over that''s for sale here locally... Uhm, yeah... 2 stroke? CHECK! Cheap? CHECK! Street legal and unique? CHECK CHECK CHECK! Am I ready for twice the Hp, half the torque, gear box fluid changes and HALF the MPG my already trouble-free NX is? If the CRM was 230lbs? F-YEAH, I'd be all over it! But at 280lbs..? Just what am I getting myself into with a street legal 6-speed version of the CR250 that hardly ANY parts cross-over to? The Devil is in the details... (And the one riding a CRM250AR if his local economy changes )Guys, new bikes are cool and all... But a little bit of research and you'll find (To paraphrase Nuthnfancy's "Philosophy of Use") another bike out there that's used, cheaper and better suited anyway. Words like "used" and "niche" only add character anyway ![]() What does a 35hp Ninja 300 weigh anyway? OUCH! The same as my 65hp, 345lb Duke 2? Until a Ninja 300 is lighter, I'll stick with the Duke. Why the hell would I need a payment book to figure that out?
Because you can't stave US out, and you can't make US run, cuz we're them ol' boys raised on shotgun! We say Grace, and we say Ma'm and if you aint into that we don't give a damn! Make our own whiskey and our own economy too, aint too many things these ol' boys CAN'T DO! IheartmyNx screwed with this post 02-14-2013 at 08:29 PM |
02-22-2013, 06:26 PM
#352 |
Unwounding
Oddometer: 4,318
I got the Emulators installed today. It took all of a lazy hour.
I decided to start off with them at a base starting point of yellow springs, 3 turns preload, stock damper rods (no drilling) and stock oil levels. My reasoning was that I prefer stiffer suspension, you can't easily make the damper rod holes smaller after you drill them. If I need more oil flow, they come apart and I'll drill 2 holes per leg till I get what I want. So, off with the brake, the wheel, the fender, out come the fork tubes. Next, compress the center of the top fork caps and pop out the C clips. Remove the cap, the spacer, the washer and the spring in that order. If you go slow removing the springs you don't lose any oil. I cut the preload spacers 16mm to match the overall height with the emulator under the spring and cleaned them up. I dropped the Emulator in the tube, spring on that, washer, preload spacer and finally the cap, compressed it in the tube and seat the C clip back in the groove. The test ride went well. The forks no longer bottom on hard braking. They seem to actually match the firmness of where I have my GSXR shock set. Bumps transmit thru the bike with the same effect, firm and controlled. I tried to hit as many hard, sharp bumps as I could. I can't get them to give me the hammering lock up they had before. I'm guessing they stay up higher with true damping and don't move as much towards full blown bottoming, which was pretty regular for me. It is snowing and I can't hit the really nasty braking bumps in the mountains. If they deal with that, I might not do much more. As far as I can test them today, they are right on the $. I'll reserve final judgment for a good thrashing road to see if the complete transformation has been achieved. Totally worth the price of admission, and if I need to tune them further there are quite a few options at my disposal. Different springs to open the valves, and different preload on both sets of springs along with any combo of those adjustments per fork leg. Also more/less spring preload, 12 different holes to open up on each damper rod, and oil levels along with different spring rates, which as of now I am happy with. |
02-23-2013, 07:44 AM
#353 | |
Bronze Age Fall Guy
Oddometer: 5,126
Hate gets you nowhere. |
02-23-2013, 08:25 AM
#354 |
Unwounding
Oddometer: 4,318
Oil? Stock monkey piss that Kawi installed, stock height too. I figured I'd be back in to try different stuff anyway so why not? It was still clean and I want to really ride it hard before I can determine a direction I need to move in.
03-07-2013, 04:44 PM
#355 |
Unwounding
Oddometer: 4,318
03-18-2013, 03:17 PM
#356 |
Namaste
Oddometer: 1,739
Alright...it looks like winter may not actually last the rest of my life.
I asked the dealer to uncrate my new 300 (ABS) and slap a Carbon Akropovic on it. Should have it by this time next week. This thread has gone way too long with only one owner pulling the train.
2013 Ninja 300 ABS, '11 883 Iron ( kicked to 1200), '08 Vespa 250 GTV http://www.secordgallery.com/gallery...2_itemId=35642 |
03-18-2013, 03:25 PM
#357 |
Unwounding
Oddometer: 4,318
I figured I was the only one who would ever own one here!
![]() Steering head bearings, 15t sprocket and then a tuner, in that order IMO. Best of luck with it!
03-19-2013, 06:59 AM
#358 |
Oddometer: 50
I'm getting a green one as soon as my Bandit sells. Looks like a perfect bike for my twilight years. It's been a long time since any new bike really exited me but these new small bore sport bikes really speak to me.
03-20-2013, 02:07 PM
#359 | |
Tilting the Horizon
Oddometer: 1,430
Went and sat on one again at the motorcycle show this weekend and it's gonna be a hard decision for me. Ninja 300 or a DS......Hummmmm |
03-20-2013, 02:44 PM
#360 | |
Oddometer: 475
Heck, if you're trying to sell the Bandit PM me and I will give you my email address. Then you can email me a flyer I can put on our for sale board in the showroom. Kevin
TwistedThrottle.com Toll-free 855-255-5550 Follow us on YouTube, Facebook and Twitter! |
