Old 10-12-2012, 11:13 AM   #106
scooterspirit
Ilovekitty
scooterspirit's Avatar
Oddometer: 747
The first ninja 300 has posted at fuelly.com- 267 miles best 57 average 55 US mpg.
http://www.fuelly.com/motorcycle/kawasaki/ninja%20300
scooterspirit is offline   Reply With Quote
Old 10-12-2012, 01:48 PM   #107
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,487
Wow that seems really low? My carb'd 250 will get 65 in mixed riding, and closer to 70 if it's all highway/biway cruising. Even with 50 extra CC, you'd think the EFI would yield better results...
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 10-12-2012, 05:49 PM   #108
scooterspirit
Ilovekitty
Oddometer: 747
New bike, I would think the guy was taking it somewhat easy. Shouldn't be hard to make it go under 50mpg US. I get 65 on my cbr250, seems to get better if I stay off the highway.
Old 10-12-2012, 06:13 PM   #109
Navin
Navin's Avatar
Oddometer: 8,495
Not every bike converted to FI ended up getting better MPG, the Huskys in 450/510 come to mind. Maybe it needs a good tune? Who knows how it is set to beat the EPA sniffers? Maybe it has a more accurate odo?
Navin is online now   Reply With Quote
Old 10-12-2012, 07:47 PM   #110
DiabloADV
Semi-Occasional
Oddometer: 2,335
Been getting ~65mpg on my CBR250R, and I basically crack the throttle to the stop every single time I accelerate.
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 10-13-2012, 12:59 AM   #111
straightrod
Oddometer: 1,313
I am thinking it is the wrong color.
straightrod is offline   Reply With Quote
Old 10-13-2012, 09:56 AM   #112
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
I like riding small flickable bikes.
I don't get why people are ok with accepting 380lbs as an acceptable weight for a 250/300 cc class small twin?
Anyone remember the venerable Yami FZR 400? 50hp and 347lbs....that bike was a blast!!!!
With todays technology and alloys and the high tech designs in trannys why cant they get a small cc twin down to 300lbs ish?
I mean look at supermoto 450cc bikes? Yes they are singles usually, but at 250-270lbs soaking wet it sure seems possible to save 30-70lbs off of a small twin.
These little 250/300 twins should really be 300lbs MAX.
My reasoning is along the lines of the ridiculous weight of the CBR250R. It weighs 357lbs according to the Honda USA website. It uses the Honda CRF250X motor in it. A fully fueled CRF25X with lights and battery weighs 253lbs....where is 104lbs neccesary to turn it into a sport bike?
I can see 40lbs in ABS components and cast wheels and body work....blah blah blah, but come on, 104 lbs?
Ridiculous especially for a single.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 10-13-2012, 12:08 PM   #113
Gryphon12
Gryphon12's Avatar
Oddometer: 1,347
If you want a light weight street single, the upcoming KTM Duke 350 will weigh approximately 335 lbs. wet with a good battry, alternator, and 17" supermoto wheels. If you want a light weight / high spec small street bike, you have to pay for it - a 300 lb. Ninja 300R or CBR250R would cost $10k or more for the light weight components.
In comparison to dirt bikes, the frame, wheels, suspension, alternator, steel tank, bigger triple clamps, much different frame and swing arm (large cross-section aluminum vs. steel), much larger batteries, handle bars, mirrors, rear subframes, seats all contribute to the difference in weight between Enduro (super light racing dirt bikes) and non-racing street bikes. The VERY light Daytona 675R weighs 415 lbs. wet. A 600cc supersport track bike weighs about 370 lbs and costs $20k plus.
Also, we need to be very careful comparing published weights of older motorcycles with our new standards. The first year of the FZR-400 in Japan (1986) called the FZR-400 1WG had a claimed dry weight of 157 kg (345 lbs). This was when those weights didn't include battery or alternator, or engine oil, fork oil, etc. etc.
The 1989 version of the FZR-400 for the US market had a published dry weight of 172.8 kg (380 lbs.) which included the battery and the alternator. With a 4.8 gallong fuel tank, full, the bike weighed 410 lbs. wet with all other fluids.
The FZR-400 had an aluminum delta-box frame and had what we would now call super-sport level components. The new Ninja 300R doesn't. If it did, it would weigh less, and cost what a 600 cc supersport costs, whick is $10k - and no one (except maybe me) would buy it (see our thread on "Nobody will buy High spec 250-400cc sportbikes." http://www.advrider.com/forums/showthread.php?t=648218
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 10-13-2012, 02:38 PM   #114
LuciferMutt
Oddometer: 11,487
I'm glad somebody mentioned this. Most of today's weight specs are "curb weight" and the whole super retarded dry/wet weight thing is finally going away. Last I heard, curb weight is all fluids/ready to ride with a half tank of fuel. It is a much more realistic way to measure this detail.
Also, those old lightweight bikes had shitty suspension and shitty brakes. No thanks.
Old 10-13-2012, 02:38 PM   #115
Navin
Navin's Avatar
Oddometer: 8,495
And that ain't the CRF250X engine either, it's a shared engine with the CRF250L. Totally different than a CRF-X.
I'd be all in on a true SS 250-400 but I'll take the super light feel of a Ninja 250 anyway. I just spent a few miles on one in twisties (2012) and it is super toss-able. Light crank? Low rotating mass? Skinny tires? Whatever it adds up and it works. Even the shitty little front brake works alright. Better shock/forks would be welcome and a few aluminum components wouldn't break the bank but this is all you can get stock sooo.
And I have a EXC530 that gets sumoto wheels swapped on. It climbs north of 280lbs with 17s and is basically stripped to bare minimum head/tail lights and switchgear. No mirrors, no nonsense. Even the "light"/exotic DS bikes aren't all that light.
Old 10-14-2012, 08:55 AM   #116
HONKR
HONKR's Avatar
Oddometer: 148
Current 90 day average on my KLX686 is 64.25 mpg, with a high tank of 67.7 mpg.
Needle selection on the FCR41 is very important for economy at low throttle settings vs power at WFO.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
HONKR is offline   Reply With Quote
Old 10-16-2012, 02:33 AM   #117
DudeClone
DudeClone's Avatar
Oddometer: 1,858
its AWESOME!!
my scooter lovin', scooter ridin' ass is in for one
300cc, 379 pounds, agile, nimble, not too small, not too big. i'd say its perfect
and cheap!
bikes
DudeClone is offline   Reply With Quote
Old 10-16-2012, 05:48 AM   #118
LuciferMutt
Oddometer: 11,487
Originally Posted by DudeClone View Post
and cheap!
In what world? It's nearly $6K.
Old 10-16-2012, 07:37 AM   #119
DudeClone
DudeClone's Avatar
Oddometer: 1,858
^well the abs version is $5500 but the base is $4800. i wouldn't expect to walk OTD under $6,000 all in, but that is still fairly reasonable imo. say $6250.
i think thats pretty decent for a bike like this. i mean ok its not exactly "cheap" but it is a somewhat inexpensive way into a brand new bike that can do as much as this one
lots of bigger cc bikes out there but most will run at least $2500 more if bought new. and many a good deal above that. so for this freeway capable, somewhat highway capable, and great around town bike? well, $4800 sounds a little cheap, at least.
bikes
Old 10-16-2012, 07:43 AM   #120
Anteraan
Oddometer: 124
That "shitty little front brake" will do stoppies, stock. How much more braking power do you think you can use?
Anteraan is offline   Reply With Quote
Times are GMT -7.   It's 08:13 PM.
