Old 09-14-2012, 09:44 PM   #1
afmeyer OP
Oddometer: 73
Throttle Body Sync
Most of the threads are years old. What is recommended now for throttle body sync? The twinmax is available but the Harmonizer doesn't seem to be available. There is also the Carbtune and the home made manometer.I'm looking for suggestions. Is there anything new or is one of the devices I mentioned very good?
afmeyer is offline   Reply With Quote
Old 09-15-2012, 04:21 AM   #2
gn77b
Oddometer: 147
FWIW, I'm using the DIY version (clear tube filled with oil) with good results.
gn77b is offline   Reply With Quote
Old 09-15-2012, 06:07 AM   #3
VStromTom
Oddometer: 1,579
Initially I used the homemade manometer but didn't like it because of rapid changes to the columns of liquid with the slightest change in balance. Flow restrictors may have reduced that problem but I didn't like it, and the damn thing was cumbersome to use and store. I now use a TwinMax with great results. Some hamfisted guys gripe about sensitivity and having to change the 9v battery each year but I have no problem with that. I recall seeing something about the harmonizer, which seemed good, but don't know anything else about it. Good luck. Carb stix are an old tried and true tool/method, but I haven't used it.
VStromTom is offline   Reply With Quote
Old 09-15-2012, 09:19 AM   #4
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,954
I used to use a TwinMax, but threw it away in favor of a manometer tube setup, which was much more reliable and accurate. But I now use Grok's Harmonizer, which I feel is superior in every way for balancing throttle bodies.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 09-15-2012, 10:33 AM   #5
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,052
I have the carbtune... I like it because it's very dampened. It's also a little bigger and easy to see while bent over and adusting the cables while holding the throttle and watching the tach all at the same time... reminds me of playing twister
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 09-15-2012, 02:20 PM   #6
LexLeroy
Chief Mansplainer
LexLeroy's Avatar
Oddometer: 2,608
+1 on the DIY manometer - mine's filled w/ blue 2-stroke oil and I use it every oil change.
"They're smarter than you son... that's why they're the police."
LexLeroy is offline   Reply With Quote
Old 01-16-2013, 10:51 AM   #7
bob393
bob393's Avatar
Oddometer: 392
+2 use red trans fluid in mine. I found kinking the tube at the bend dampens it just fine for my use.
2007 R1200GS almost farkeled to perfection!
bob393 is offline   Reply With Quote
Old 01-16-2013, 11:53 AM   #8
duck
duck's Avatar
Oddometer: 10,403
For two cylinders a TwinMax works fine.
I use a Carbtune now because it does all three or four cylinders at once.
duck is offline   Reply With Quote
Old 01-16-2013, 01:29 PM   #9
fast4d
Oddometer: 2,481
some bikes (rotax/aprilia v-twin for ex) have a map sensor on each TB so you can get it in the ballpark......no tubing necessary!
fast4d is offline   Reply With Quote
Old 01-17-2013, 04:51 PM   #10
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,256
The Carbtune is fantastic. And you can sync 2, 3, and 4 cylinder bikes.
Your friends will gather around to watch you tear down and tune up all kinds of motorcycles...
What sort of conveyance are you synchronizing, anyway?
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Times are GMT -7.   It's 08:40 AM.
