Old 10-06-2012, 10:56 AM   #16
rufusswan
rufusswan's Avatar
Oddometer: 962
How about a picture? Since them things remain so hidden on the bike it's a bit of a stretch on an old mans memory. Show what you got 'on the bench'.
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Old 10-06-2012, 11:37 AM   #17
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,027
Hi Chad. Without seeing it up close I tend to think like a couple of others that the brushes may be beyond their lifespan and just being disturbed may have put them out of their misery. If you clean(ed) the commutator that the brushes ride on, make sure any copper dust gets cleaned out from between each little contact segment.
Don't know if you have any good old school electric shops up there. We used to have great one here on the Island, but they closed doors about 2 years ago. But a good old time shop should be able to refurb any kind of starter.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 10-06-2012, 12:19 PM   #18
photorider
photorider's Avatar
Oddometer: 286
If you decide to rebuild it, here is a good write-up with pics. It was very helpful when I did mine a few months back:
http://www.thisoldtractor.com/gtbend...ir_-bosch-.htm
photorider is offline   Reply With Quote
Old 10-06-2012, 01:44 PM   #19
Sergeant Joe
Sitrep=Snafu
Sergeant Joe's Avatar
Oddometer: 244
same prob
G'day, I had the very same thing on my R65LS.
The fix is to run an Earth wire from Neg side of Dioad board through to the bolt that holds the back of the starter motor to the engine case.
This gives a full Earthing system as the way BMW did it sucks.
I have had full charge an instant starter turnover ever since.
hope this helps.
Sergeant Joe is offline   Reply With Quote
Old 10-06-2012, 04:59 PM   #20
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,126
Makes no sense to me that since the starter grounds through the engine block at it's mounting point. Can't get much better grounding than that!
The best test for the starter (with a known good battery) is to hook jumper leads directly to the starter while it's installed.
Run the negative jumper from the battery negative to the engine block near the starter.
Connect the positive lead to the cable mounting lug on the starter.
Jump 12V to the solenoid spade and the starter should spin the engine.
If it doesn't, something aint right with the starter.
It's possible to have a poor connection in the solenoid contacts.
Often it's worn bushings in the starter - there are three - two for the armature, one in the bendix drive.
Or it's brushes and grungy commutator.
If the starter turns when the button is pressed, it's not the relay - since that's what the relay's function is - to activate the starter.
Old 10-06-2012, 05:17 PM   #21
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,395
thanks for all the replies
The trick that was missing was what crazydrummerdude mentioned. You have to put 12v to the spade connector in addition to the main positive.
So here were my tests today, tested it on the bench with a battery providing power. Seemed like it wound up ok, but my suspicion is the bearings are going. Seemed like it wound down to fast and was "vibrating" a bit more than I would have expected during wind down. I got none of the solenoid clicking.
Next test, lay it on the engine, hook up batter and starter and test it with the bikes starting system. Same result. At this point started to think that there was a contact issue that I disturbed and it "fixed itself"
Put bike back together with the idea that the starter needs replacing due to the bearing/wind down feel, but that I had fixed the problem. Yeah, no. Went back to the old turnover, clicking, turnover, clicking thing.
GRRRRRRR.
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. Thatís the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 10-07-2012, 08:59 AM   #22
Wirespokes
Wirespokes's Avatar
Oddometer: 8,126
I think it needs the bushings replaced.
Old 10-07-2012, 08:16 PM   #23
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,395
Even if everything else were normal, I would agree to this statement.
Old 10-08-2012, 03:14 AM   #24
Sergeant Joe
Sitrep=Snafu
Oddometer: 244
Bad earth is the culprit 95% of the time. Just saying
Old 11-20-2012, 08:50 PM   #25
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,395
here is a strange update......
As listed I got the bike/starter apart and everything tested normal as best as I could test. Still go the clicking and not "catching" and cranking like it should.
I was going to next look at battery cables, but didnt get the time as my alternator rotor failed and had to be replaced.
Here is the strange part. In the last 2 days since I have had the bike back on the road with a new rotor/brushes in it I dont get the clicking solenoid anymore. I dont get it myself? How can the two be related?
Old 11-20-2012, 10:17 PM   #26
Wirespokes
Wirespokes's Avatar
Oddometer: 8,126
Does this mean the starter is working normally with no clicking solenoid, or...
When you press the starter button you don't get anything, not even get clicking?
Old 11-20-2012, 10:31 PM   #27
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,395
Sorry about that. Yeah, its working normally. Odd huh?
Old 11-20-2012, 10:39 PM   #28
Wirespokes
Wirespokes's Avatar
Oddometer: 8,126
Sounds like the battery was low, and the root of the problem was the failing rotor.
Old 11-20-2012, 10:45 PM   #29
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,395
When this was happening, I was charging and testing the battery regularly to make sure it was not low because that was my first thought. Cant imagine the battery being low for several months at a time?
Old 11-21-2012, 06:42 AM   #30
chasbmw
Oddometer: 2,199
if the starter only gives problems when it is under load, then ther problem is often due to wear in the bushings, this allows the armature to cock sideways under load and everything starts to go really slow.
I dont know if the bushs are available for these old 8 tooth Boschs, but given that you can buy either Valeo or Nippon Denso 8 tooth starter motors nowadays I would go for replacement.
Charles
1971 Commando Fastback
chasbmw screwed with this post 11-21-2012 at 06:48 AM Reason: adding re replacements
Times are GMT -7.   It's 08:02 AM.
