Old 09-17-2012, 08:20 AM   #1
Ivanvm OP
Ivanvm's Avatar
Oddometer: 14
Lost rear break pressure on ktm 525 exc
I took out my dirt bike out after a long summer break. As I started going down the hill I noticed I had no rear break. The break is there but pressing on the plunger causes no pressure on pads. Inspected the fluid level and it's fine. Lines are free of obstructions and undamaged. I am no mechanic but I can usually find my way around my bike but this one has me puzzled. Any ideas why the pressure is gone?
Yamaha TTR225
KTM 525EXC
Ivanvm is offline   Reply With Quote
Old 09-17-2012, 09:21 AM   #2
Marco Moto
Voyager
Marco Moto's Avatar
Oddometer: 1,226
If the pedal is hard to push then your caliper piston is stuck, if the lever goes down with no pressure then your master cylinder needs to be rebuilt. Rebuild kits are available online for +- $30, good luck!
-Marco Moto
Marco Moto is offline   Reply With Quote
Old 09-17-2012, 09:36 AM   #3
tutone
tutone's Avatar
Oddometer: 37
Same
My 530 did the same thing last weekend and now in the shop for a Master cylinder rebuild. Actually I was told debris plugs some small venting hole. I trust my mechanic and he said this is common on KTMs
KTM 1190R
Husqvarna TE 250
KTM 500 XC-W
tutone is offline   Reply With Quote
Old 09-17-2012, 10:09 AM   #4
Ivanvm OP
Ivanvm's Avatar
Oddometer: 14
Thanks. Must be the master cylinder. Will get the kit.
Yamaha TTR225
KTM 525EXC
Old 09-17-2012, 12:24 PM   #5
dbarale
Squiddly slow
dbarale's Avatar
Oddometer: 1,260
Have you tried bleeding it first?
dbarale is offline   Reply With Quote
Old 09-17-2012, 01:34 PM   #6
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,550
+1
Thats the first thing especially if it was working fine you probably just boiled the fluid, there isn't much in those master cylinders
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 09-17-2012, 05:22 PM   #7
Ivanvm OP
Ivanvm's Avatar
Oddometer: 14
Makes sense. Will get a pump and bleed the lines. Will report back in a couple of weeks (off to Cancun for 7 days). :) Rubbing it in...
Yamaha TTR225
KTM 525EXC
Old 09-18-2012, 05:09 AM   #8
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 720
Happens me on my 450 all the time. I have to be careful not to be slightly weighing the lever with my boot or I boil the fluid and notice I have lost the rear at 70mph in sand
When it happens it cools down in 5 minutes and I can pump the pedal to bring pressure back up.
Jacl-Kampuchea is offline   Reply With Quote
Old 10-05-2012, 04:09 PM   #9
Ivanvm OP
Ivanvm's Avatar
Oddometer: 14
Finally I got a chance to bleed the break and it did the trick. The rear break now has pressure and seems to be working properly. I will try it tomorrow to see if it is working properly. Thanks for all your advice
Yamaha TTR225
KTM 525EXC
Old 10-05-2012, 08:37 PM   #10
elsalvadorklr
southern xr rider
Oddometer: 4,154
your just boiling it so bleeding/flushing every once in a while helps...and not riding the brake too...
elsalvadorklr is offline   Reply With Quote
Times are GMT -7.   It's 03:09 PM.
