Thread Tools | Search this Thread | Rate Thread | Display Modes |
09-17-2012, 04:10 PM
#1 |
Crazy Bastard
Oddometer: 243
MapSource Appends a "1" to waypoint names??
So I take a GDB file with waypoints and routes and export or "save as" to a GPX file. If I then open that file, the waypoint names are all correct on the list, but if you open a route, all of the "via" points now have a "1" appended to the name. For example, HOME becomes HOME1.
Anyone know what's up with this?
Our Baja California Loop GPS Tour is now available and shipping! GripTwister Dual Sport Tours |
09-17-2012, 05:11 PM
#2 |
Long Haul Adventurer
Oddometer: 3,171
What GPS are you using?
Cheers,
Cheers, Dan |
09-17-2012, 05:14 PM
#3 |
Crazy Bastard
Oddometer: 243
No GPS involved, just MapSource.
09-17-2012, 05:33 PM
#4 |
Oddometer: 3,171
This is behavior typical of BaseCamp - it can't handle duplicate Waypoint names. I've never seen MapSource do this on it's own. Did you create the GDB file or was it given to you?
Cheers,
Cheers, Dan |
09-17-2012, 07:34 PM
#5 | |
Oddometer: 3,978
Are you saying you open (MapSource) the .gdb file and it only has single waypoints, then you "save as" .gpx and now it has double Waypints? Are you sure the double Waypoints did not come from your GPS? If I download the same waypoint in two routes, like said above Garmin does not like this and gives the exact same waypoint a sufix (1)
Jerry Counts |
09-18-2012, 01:44 AM
#6 | |
Crazy Bastard
Oddometer: 243
I initially thought it had to do with auto-routing using a routable mapset, but tried recreating a route both with and without utilizing a mapset and with autorouting off (use direct routes) but to no avail.
09-18-2012, 01:49 AM
#7 | |
Crazy Bastard
Oddometer: 243
Go figure.
09-18-2012, 08:12 AM
#8 |
Oddometer: 3,171
I think you (or, MapSource) have stumped the panel Dave. I've never seen MapSource do that and I just tried to recreate that condition and could not - using MS v6.16.3.
Cheers,
Cheers, Dan |
09-18-2012, 12:18 PM
#9 |
Oddometer: 3,978
You still didn't answer the question, where did you get this .gpx file?
Jerry Counts |
09-18-2012, 01:17 PM
#10 |
Oddometer: 1,949
I just tried it and replicated it.
I believe your problem is that GPX files treat waypoints (in the tab) and waypoints in a route the same. So, if they are both in the same "pool" of waypoints, they are naturally duplicates of each route waypoint. Easy solution is to just use the GDB file. If you want to share the file with GPX users, save it off as a GPX when all your planning is done, and let the other guy worry about it. This is a non-problem. |
09-18-2012, 03:17 PM
#11 | |
Crazy Bastard
Oddometer: 243
Still, I guess I should try opening the resulting GPX file with a program other than MapSource and see if the waypoint/via point names are appended there. Maybe it's just a MapSource glitch and doesn't happen with other software. Thanks for giving it a try and confirming it isn't just my system. By the way, using version 6.16.3 of MapSource. Anyhow, anyone else wanting to try replicating this, just create a few waypoints in MS, then create a route using those waypoints. Save file (as GDB) and then also "save as" a .gpx file. Then open the GPX file you created (with MapSource), select the route properties for the route you made, and click on the via points tab. See if the waypoint names you used show with a "1" added to the end. I'd be interested to know if it's always the case that the names are appended with a 1.
09-18-2012, 03:24 PM
#12 |
Oddometer: 3,171
Interesting that MAC could replicate this and I could not even after five route creations.
So, Dave, why are you sharing Routes with your clients? We only provide Tracks (and Waypoints) for our clients and therefore require them to have a GPS that will show Tracks on the screen. I've never had a problem. Routing sucks - even Direct Routing can have issues between GPS's (like duplicate waypoints). Cheers,
Cheers, Dan DRTBYK screwed with this post 09-18-2012 at 03:34 PM |
09-18-2012, 03:39 PM
#13 | |
Crazy Bastard
Oddometer: 243
No problems with our routing using Off Road or direct with Garmin units. As long as auto routing does not occur, which can be controlled locally on the GPS, it's the same results every time. The same is not true for tracks. Exceeding a threshold of (I think 200 or so) causes major problems with Zumo/Nuvi units as they create their own via points and then try to autoroute when navigating a track (converted to route locally). Whereas exceeding the trackpoint limits on the other Garmin units just truncates the route (it ends) at the point where the limit is reached.
09-18-2012, 03:51 PM
#14 | |
Oddometer: 3,171
Cheers,
Cheers, Dan |
09-18-2012, 03:54 PM
#15 |
Oddometer: 3,978
All Dual Sport Events that I know of only supply Tracks because of the many problems with Routes. A few people tried Routes in the early days but had many problems. Then one club tried to give ouit 750 point tracks to people with 250 point / track units, again problem. The current standard is 500 point tracks and let people with B&W units ask for special treatment.
Jerry Counts |
