11-21-2012, 09:45 AM
#1 |
Vintage Rider
Oddometer: 1,670
tube type tires
Just wondering, what do you do when you have a flat tire on a large road bike that has tube type tires, and no centerstand? This is the case with a lot of bikes, especially cruisers. I refuse to ride a bike with tube type tires and no centerstand, but have noticed that many people don't consider it a big deal. Just interested in how you would handle such a situation.
"I refuse to give up the thrill of living for the relative safety of existing" Nick Ienatsch "Life is not a race. Don't treat it as such. If you don't believe me, just have a look at the finish line" |
11-21-2012, 09:51 AM
#2 |
Deputy Cultural Attaché
Inflated tire + sidestand + portable stand = stable tripod.
Successfully surviving motorcycling since 1976. |
11-21-2012, 10:29 AM
#3 | |
diplomatico di moto
Rocker59 (aka guzzimike), Aux Arcs (NW Arkansas) Moto Guzzi: LeMans 1000 CI, Sport 1100, V11 LeMans Nero Corsa IBA #24873, MGNOC #21347 “Just keep playing, no matter how weird it gets.”
11-21-2012, 10:43 AM
#4 |
Oddometer: 460
some riders make takedown centerstands in case they get a flat....there is a clever one for a DR650 at http://advrider.com/forums/showthread.php?t=811587
11-21-2012, 10:46 AM
#5 | |
Vintage Rider
Oddometer: 1,670
EDIT: Interesting. But why? the DR650 and KLR 650 have factory made centerstands made specifically to fit them, from several places, including Dual Star, SW Motec, and Happy Trails. I put over 20,000 miles on a Honda Rebel (really small bike) and rigged up a "portable stand" but it was a PITA to use. But definitely a lifesaver if you had a flat, which I did, about 3 times if I remember right. I made a BOLT ON stand that fit where the right side footpeg bracket went. You had to remove the footpeg bracket, and use the same bolts to bolt on the stand. Combined with a piece of 2x4 under the stock sidestand it would get the bike off the ground, and it could not fall off because the stand was bolted to the bike with 2 bolts. But that was a small bike, and just happened to have frame bolts in the right spot.
"I refuse to give up the thrill of living for the relative safety of existing" Nick Ienatsch "Life is not a race. Don't treat it as such. If you don't believe me, just have a look at the finish line" JerryH screwed with this post 11-21-2012 at 10:58 AM |
11-21-2012, 10:51 AM
#6 | |
bam-a-lam
Oddometer: 1,834
If your speaking of big cruisers like the touring line of HDs, a centerstand wouldn't do much good as the rear fender wraps back down so far you literally have to have the bike jacked high enough to drop the tire down as it will not simply roll backwards when the axle is removed. However, after owning 5-6 HDs between me and the ex and over 150,000 miles in the last 8-10 years we never experienced a flat tire. The only flat I've ever had on a streetable bike was on my DR650 where I picked up a nail while riding off-road. No centerstand on that bike. It's a big dirt bike, just threw it on it's side and removed and replaced the wheel.
'12 H-D Road Glide Custom '09 Suzuki DR650 '09 H-D XR1200 |
