Old 03-13-2014, 09:53 PM   #796
hizzo3
Oddometer: 97
Is that your manual pick and place featured on hackaday?
Sent by my NSA monitored Verizon Galaxy Nexus.
hizzo3 is offline   Reply With Quote
Old 03-14-2014, 11:23 AM   #797
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,496
Buy an existing mold for testing...cheap...$12. Mix the epoxy very slowly (no air bubbles) or vacuum the bowl of epoxy to de-gas. pour. cure. It would be as smooth as a baby's ass.
Originally Posted by craftycoder View Post
I am not willing to spend the months necessary to become an expert at silicone mold making. Anyone who says you can make a perfect mold the first time is full of it. I know I will need to make 10 before I am satisfied and I just don't have the patience for that. I need to cast a couple dozen of these things and it would be nice if I didn't have to add $350 for a mold to the $500 I've got in each of these Motobrains before they ship. After a few dozen samples are out the door I expect purchase orders which will allow me to outsource the manufacturing and all these goofy failures will be but a distant memory.
Failures are part of the engineering process. I assure you that every other development project of this type ever attempted by man has encountered its share of problems. You guys are hearing about them because I am sharing the entire process with y'all but failures are absolutely part of the process. Normally I am excited by failures because they are learning experience (and I have a hard-on for learning) but in this case since I really don't care about casting and mold making it is just pain. No one ever promised this was going to be all Champagne and stinky cheese however, so I shall persevere.
I've got two more units I've promised to ship out ASAP and I hope the remaining mold I have will survive if I use a different release agent. At that point I'll try a new mold design. This time I will try a soft "silicone like" inner mold and a hard outer mold to support the Motobrain's weight and keep the silicone mold from splitting prematurely. Once I've draw up the new mold I'll post it up here for you guys to see.
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass screwed with this post 03-14-2014 at 11:42 AM
HighTechCoonass is offline   Reply With Quote
Old 03-14-2014, 08:35 PM   #798
craftycoder OP
Motobrain PDU
craftycoder's Avatar
Oddometer: 2,335
Yeah it is. I hadn't seen that. Cool
craftycoder is offline   Reply With Quote
Old 03-15-2014, 12:05 AM   #799
EKinOR
Oddometer: 270
Thanks for the suggestion. That is a fine fleet target.
I have a contact for you in that market. PM shortly.
- Eric
2002 BMW R1150GS
EKinOR is online now   Reply With Quote
Old 03-15-2014, 10:44 PM   #800
craftycoder OP
Motobrain PDU
Oddometer: 2,335
I waxed up my remaining mold with some cheap floor wax and just finished casting another Motobrain. I am hoping that I can remove the Motobrain from the mold without destroying it (unlike the last two Motobrains I cast) so I can keep making these in the near term while I come up with a new silicone mold. You have collectively advised me to go ahead and figure how to work with silicone. I'm planning to try it out.
In other news, I've been refining the firmware and am really getting pleased with its function and reliability. I have heard also from the first recipient of a Motobrain and they are liking it so far. That is great news I'd say.
8026BCA5-3F7E-4F0E-8B1E-1A155028E5FE[1]
Old 03-16-2014, 01:24 PM   #801
craftycoder OP
Motobrain PDU
Oddometer: 2,335
a bit of casting success for a change
I finally have a little success in casting a Motobrain. The Motobrain looks great and the mold is intact! Unfortunately, I made two significant changes compared to the last attempt so I do not know for certain which change was responsible for the better outcome. I changed both the resin (because I ran out of the preferred resin) and the release agent. As I said last night, the release agent I used was cheap floor wax (and AquaNet hair spray). The resin is not preferred because it is harder and not thermally conductive. The customer I will send this unit to doesn't require high current capacity so I decided to make use of this resin rather than waste it.
I am still going to give a silicone mold a try but I won't have to wait on it which pleases me greatly!
4CB7E544-36F0-4DA2-AC06-F40CCAD91F12[1]
7ABAB0C1-CA8F-43AE-A89C-65D7C5CD253A[1]
63D0C345-5F21-4ED5-8C5E-E6D0E7C78231[1]
5446A1F7-C838-4616-BE1E-7A80A7C372F3[1]
Old 03-16-2014, 05:37 PM   #802
craftycoder OP
Motobrain PDU
Oddometer: 2,335
Doing a burn in test.
Old 03-16-2014, 07:14 PM   #803
Captain Excellent
+ll+
Captain Excellent's Avatar
Oddometer: 229
I notice you have 8 x 15Amp circuits. Have you upped the total capacity to 120Amp?
Captain Excellent is offline   Reply With Quote
Old 03-16-2014, 07:16 PM   #804
craftycoder OP
Motobrain PDU
Oddometer: 2,335
Nope, the Motobrain is specified for 100A total. Each circuit can do 15A so you need to not drive it too hard.
Old 03-17-2014, 11:04 AM   #805
craftycoder OP
Motobrain PDU
Oddometer: 2,335
More thermal testing.
I did another several hour test to see how a Motobrain cast in thermally conductive resin responds to high current loads. The test was similar to last one where I started at 50A and began taking regular readings and when I saw the temperature was stabilizing I turned it up 10A. The results are below. The maximum temps are much lower now than with the previous resin. This stuff is clearly allowing more heat to radiate off the device keeping the max temps in check (10 degrees lower inside and out with this resin compared to the previous) while also reducing the thermal gradients across the device which will improve MTBF in the long run.
The top was measured with the FLIR camera. The side was measured with a Fluke thermocouple. The internal was measured with a sensor on the MCU.
Book1+3172014+11307+PM[1]
Here you can see the lab in the IR spectrum. The wires are straining under the current load. You can even see the two AC power lines I an running to the power supply to reduce the fire hazard.
FLIR0064
This is a photo of the fake ignition switch I use. It is really a couple of series diodes that do a fine job convincing Motobrain that an alternator is running or not. All the current also flows through this and boy was it unhappy. 85C is HOT!
FLIR0066
That is as hot as the Motobrain got over 2 hours of testing up to 90A.
FLIR0068
P1000851[1]
I planned to do the test up to 100A but the power supply started to make "creaking" noises and I got nervous and shut it down. I am a bit intimidated by what Motobrain can do. 1300W is a ton of power! Still I did turn it up to 100A and took snap shot. It did the deed and didn't burst into flames. Kudos to you Motobrain. The internal temp was 44C.
4C301996-239C-44DD-9594-41DA4376012C[1]
310D76AD-8E53-47FB-85EF-6974E9C3180D[1]
I even did a little cold temperature testing. I put it in the freezer for 20 minutes and then powered her up to see what would happen. No drama at 4C. I'll need to do more of this but the preliminary testing I've done (down to -80C) has all been positive.
589BA9FA-91B4-4D4F-9AA5-FDAEBCE4AF3A[1]
Old 03-17-2014, 06:48 PM   #806
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Crafty, All very impressive.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 03-18-2014, 09:17 AM   #807
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 03-18-2014, 12:55 PM   #808
craftycoder OP
Motobrain PDU
Oddometer: 2,335
I am going to make a silicone mold as the polypropylene mold has been a pain to work with. Most of the parts have been ordered. This is the master I've drawn up. It is much taller than is necessary, but it does allow me to make the pour a lot less of an exercise in dexterity. I can pour in the correct volume and then left gravity settle it down to the right volume. I am going to do it upside down and as fellow inmate Emerson Biguns first suggested and others have since followed. This allows me to put some heat sink features and a legend directly into the Motobrain which ought to be super cool at the end of the day. Not including the tabs, Motobrain is 3.5"x2.5"x1.5". The tabs can be sawed off.
I have been given lots of guidance on this process offline by someone who is willing help me out because he wants to be able to order his Motobrain already. You guys have been very generous with your attention and advice. Thank you for helping out!
Fullscreen+capture+3182014+34206+PM[1]
craftycoder screwed with this post 03-18-2014 at 01:13 PM Reason: typo
Old 03-18-2014, 01:12 PM   #809
tdcarter
tdcarter's Avatar
Oddometer: 79
I have been given lots of guidance on this process offline by someone who is willing help me out because he wants to be able to order his Motobrain already. You guys have been very generous with your attention and advice. Thank you for helping you!
Yep, Quite a few of us have been following and (trying to offering assistance throughout). It's been cool to see it come together and watch your dream live. You have taken it further then then probably most of us imagined.
Now get the thing on the market and lets have some fun!
tdcarter is offline   Reply With Quote
Old 03-18-2014, 03:49 PM   #810
Gany
Oddometer: 367
Has that model got the 4 posts for the transparent plate? Just checking... How about the motobrain logo along the top edge? You could cast that straight into the resin.
Gany is offline   Reply With Quote
Times are GMT -7.   It's 11:36 PM.
