Old 09-20-2012, 09:39 AM   #1
ebohnet1 OP
ebohnet1's Avatar
Oddometer: 75
$2000 spent at BMW dealer, bike still not running
Okay, so here is the background. I have a 00 1150 GS with just over 63k. I was in Nova Scotia having a great vacation until my bike died on the side of the road on a rainy day. The bike lurched (correct term?) then would shut off. I restarted it and it did the same thing as before, died when given throttle. I pulled over on the side of the road, it would not start. The RPM gauage did bounce around (from 0 to 3) I had to tow it to nearest BMW dealer in Canada ($640 tow job )
They have spent 2 weeks lookng at the bike and i will be spending $2000 dollars and it still is not working. One of the coils was going bad (mechanic showed me the graph and it was bad) so that was replaced.
The bike would not start up fine but only when giving it throttle. If you continue to give it throttle it will run fine. As soon as you let the bike idle, it sputters and dies. The mechanic has spent a lot of time and is lost. Checked multiple sensors, fuel pump, throttle cable, throttle bodies, and i assume (hope) a lot more stuff. They are stumped.
The bike is still in Dieppe NB and I will not be able to go get it until the last week in September, but I am trying to gain some knowledge of any other possible reasons why this is happening.
Does anyone have any new ideas? different ideas?
Thanks,
Eric
UPDATE
Okay, so I contacted BMW North America and their response was a hearty "That is terrible, but we can not help you. Your bike is out of warranty so we can not help you."
What do I do now? Can I do something? Anyone have ideas for me? Keep e-mailing them? Face it that BMW has terrible customer service?
Any advice would be helpful.
Created webpage to try and get BMW attention. Not sure if its worth but might as well try it. Please join:
"Facts are stubborn things; and whatever may be our wishes, our inclinations, the dictates of our passions, they cannot alter the state of facts and evidence." -John Adams
ebohnet1 screwed with this post 10-08-2012 at 06:54 PM
ebohnet1 is offline   Reply With Quote
Old 09-20-2012, 09:40 AM   #2
pcwirepro
Aspiring Adventurer
Oddometer: 282
Bummer
Tps
Plug wires
pcwirepro is offline   Reply With Quote
Old 09-20-2012, 09:48 AM   #3
ebohnet1 OP
ebohnet1's Avatar
Oddometer: 75
list
I think they checked the TPS.
I am currently trying to get them to send me a list of everything they have checked/done so I will post that as soon as i get it.
Old 09-20-2012, 09:50 AM   #4
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,897
Hall Effect Sensor?
Current: 2014 R1200GSW & 2007 DR650
jdub is offline   Reply With Quote
Old 09-20-2012, 10:04 AM   #5
chiwo
chiwo's Avatar
Oddometer: 69
I had a similar issue, and it was the FI inyector filters.
Yes fuel inyector has a filter, that it can get clogged.
Replaced filters and now bike runs smoother than ever.
chiwo is offline   Reply With Quote
Old 09-20-2012, 10:26 AM   #6
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,567
You shouldn't pay for parts changed that aren't fixing the bike! Coils etc.
scooteraug02 is offline   Reply With Quote
Old 09-20-2012, 10:42 AM   #7
ebohnet1 OP
ebohnet1's Avatar
Oddometer: 75
List
Here is the email i got back from the dealer.
HE IS STILL BAFFLED ABOUT IT THE FIRST WAS THE INCONSISTENT HALL SENSOR READINGS (REPLACED THE PART). DOUBLE CHECKED THE IGNITION TIMING A FEW TIMES
REPLACED THE INJECTORS, CHECKED THE FUEL PUMP AND LINES. PERFORMED ALL THE DIAGNOSTIC TESTS FROM THE MOSS COMPUTER FOR A (TURNS OVER BUT DOES NOT START)
CHECKED WIRING HARNESS CONNECTIONS AND WIRES FOR BREAKS (FINAL TEST WAS REPLACE THE ECM) DID SO WITH A DONOR BIKE. BIKE FIRED UP AND RAN GOOD. RE-INSTALLED OLD ECM AND BIKE RAN FINE AS WELL. NEXT DAY ROUTED THE WIRING HARNESS AND ZIP TIED. RE-INSTALLED THE FUEL TANK WOULD NOT START. REMOVED THE TANK AND STARTED TO OPEN THE WIRING HARNESS TO FIND A BROKEN OR CHAFED WIRE (NOTHING) TO COMPLETELY CHECK THE HARNESS THE BIKE WOULD NEED TO BE DISMANTLED TO REACH THE WIRES INDER THE BATTERY BOX
WHILE THESE TESTS WERE PERFORMED THE BIKE WOULD SOMETIMES START WHEN THE THROTTLE WAS APPLIED (ENGINE WAS RESPONSIVE AND SOUNDED GOOD)
WOULD NOT IDLE OR START AT IDLE
Old 09-20-2012, 10:50 AM   #8
Mrmerlin
K1300S fast as shi..
Mrmerlin's Avatar
Oddometer: 341
I would guess that your broken wire is near the steering head,
get a wire tester and twist the bars back and forth,
Look particularly at the flexing areas that were secured by a zip tie,
this is a known issue where Franz didnt make the wire loop long enough then super cranked the wire bundle and the wires quickly broke where they were flexing
Mrmerlin is offline   Reply With Quote
Old 09-20-2012, 11:05 AM   #9
scooteraug02
Dog Rancher
Oddometer: 4,567
Tagesk had a dead 1150-click here His turned out to be a wire damaged by battery acid I think.
Old 09-20-2012, 02:37 PM   #10
BTL
No more snow!!
BTL's Avatar
Oddometer: 440
yikes..not good but do keep us posted on the result, good data for all down the road perhaps...hopefully not!
BTL is offline   Reply With Quote
Old 09-20-2012, 04:38 PM   #11
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 5,017
Sounds like the HES. Was a thread a few years back where a 1150 owner went nuts trying to hunt down a problem. Turned out the replacement HES was defective.
bemiiten is offline   Reply With Quote
Old 09-20-2012, 07:09 PM   #12
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,817
I'm concerned about your $2000.00 and counting bill that the dealer has racked up.
def is online now   Reply With Quote
Old 09-21-2012, 04:05 AM   #13
ebohnet1 OP
ebohnet1's Avatar
Oddometer: 75
not counting. They have been told they can not work on it for money anymore. Anything they do now is free of charge.
Old 09-21-2012, 07:24 AM   #14
scooteraug02
Dog Rancher
Oddometer: 4,567
When they say it won't start, is it turning over but not starting or press the start button and nothing.
I read somewhere if you have strange electrical problems it is a bad ground.
My dad had a VW Scirocco that was practically rebuilt under warranty trying to fix a problem. They finally found the negative battery cable was bad.
Friend's Goldwing tail lights acted up in the middle of a trip. Did some research and found the problem to be a bad ground on a wire connection.
What if your vacuum tube between the injectors was cracked/leaking? Would that cause the same problem?
Good luck.
Old 09-21-2012, 07:37 AM   #15
def
def's Avatar
Oddometer: 10,817
The FI filters are small screens that fit into the inlet of the FI trapping anything that comes down the high pressure line. Usually, FI cleaning services replace these little screen filters as a part of the cleaning process.
Times are GMT -7.   It's 10:59 AM.
