Old 09-20-2012, 04:16 PM   #1
JGroves OP
Late
JGroves's Avatar
Oddometer: 1,246
RM250 dies when hot
nt
JGroves screwed with this post 02-01-2013 at 01:45 PM
JGroves is offline   Reply With Quote
Old 09-20-2012, 06:29 PM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,372
Coil or CDI box.
you don't see luggage racks on a hearse..........act accordingly
Old 10-20-2012, 12:07 PM   #3
SM Crank
Oddometer: 6
Strip the carb, sounds like it pulled some crap out of the bottom of the tank when you ran it dry.
Happened to me!
SM Crank is offline   Reply With Quote
Old 10-20-2012, 03:11 PM   #4
anotherguy
anotherguy's Avatar
Oddometer: 6,372
You can start the bike,let it idle and heat the CDI or coil with a hair dryer and see if it fails when it gets hot. Don't overdo the heat you can kill the component.
Old 10-20-2012, 03:28 PM   #5
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 863
I guess when you simply replace the plug the bike will run again.
PSchrauber is offline   Reply With Quote
Old 11-16-2012, 07:47 AM   #6
third eye
back road loon
Oddometer: 141
I would totally go through the entire fuel system and make sure everything is cleaned out.
third eye is offline   Reply With Quote
Old 11-17-2012, 03:07 AM   #7
Shocktower
Shocktower's Avatar
Oddometer: 9,474
And since it's got some age on it I would also put a new set of main seals, probably worth the 16-20 bucks instead of the 200+ to rebuild a blown up 2 stroke, also claean the carb, i am pretty sure the piliot jet is gummed up too JMHO
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 11-17-2012, 04:17 AM   #8
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 483
Ditto on what has been said. Moving targets can drive you nuts. Most likley the fuel system but maybe not. Start with the basics first (fuel, comp., spark). Check the grounds for your ignition!!! It's an old bike and corrosion can be everywhere. Clean, tighten bolts, screws, put on lock washers to get a good bite into the frame. Might as well move on to a Comp. test or leakdown test before diving into the crank seals. If it turns out to be crank seals or ignition labor and parts may not be worth the fix. If you need new ignition parts, OEM can be SOL. A PVL or other after market ignitions can be upwards of $500!
Good luck.
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete is offline   Reply With Quote
Old 11-17-2012, 05:22 AM   #9
4badboyz
4badboyz's Avatar
Oddometer: 601
had the same kind of issue with my cr250 until I changed the coil. very frustrating to figure out.
tuck in behind me, I'll show you where to crash.
04 FJR1300 07KTM525EXC 03CR250R 77RD400 73CB750
Yet another Translab report... Owen and Mark do Labrador
Moab 2012
James Bay Road. What could go wrong...
4badboyz is offline   Reply With Quote
Old 11-17-2012, 08:55 AM   #10
RodT
Oddometer: 341
tank vent
just a thought, check the tank vent, sometimes this is the problem. I had a new ski-doo, and it would run fine for a little while and die, would not start until it sat for a while. It finally siezed the motor and that's when we found the vent tube was kinked . caused a serious lean condition.
Any fool can criticize,condem and complain and most fools do. Ben Franklin
RodT screwed with this post 11-20-2012 at 08:37 PM
RodT is offline   Reply With Quote
Old 11-17-2012, 09:02 AM   #11
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,837
Uhm, you ran a two stroke out of fuel...in other words, without lube for the piston. Melted rings and a scored bore is my bet.
larryboy is online now   Reply With Quote
Old 11-20-2012, 08:33 PM   #12
RodT
Oddometer: 341
I hope you are kidding ??? I run chainsaws for a living and trust me, they run out of gas alot!!!!Runnig out of gas in a 2 stroke dosen't hurt a thing.
Old 11-20-2012, 08:37 PM   #13
motomark39
I reckon so
motomark39's Avatar
Oddometer: 1,065
coil......
Take it off, have it tested
2014 KTM300xcwSixDays
motomark39 is offline   Reply With Quote
Old 11-21-2012, 04:00 PM   #14
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 11,182
Cool2
Yeah, what they said.
I'd pull the plug when it won't start and look for spark. I've seen the reisitors corrode in the caps too.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 11-24-2012, 08:49 AM   #15
81cr450
Oddometer: 96
Cheap answer is always the best to try first
"just a thought, check the tank vent, sometimes this is the problem. I had a new ski-doo, and it would run fine for a little while and die, would not start until it sat for a while. It finally siezed the motor and that's when we found the vent tube was kinked . caused a serious lean condition."
"I'd pull the plug when it won't start and look for spark. I've seen the reisitors corrode in the caps too."
In that order.
Old bike should really have fresh main seals, $20 for a flywheel puller, $20 seals. It dont cost a mint to ride old bikes just common sense & not throwing money away on guess's. Use the process of elimination on the cheaper fixes especially where you can get it to run. Should be a blast once you get it sorted, I sure wouldnt mind a 90's RMX250 myself
81cr450 is offline   Reply With Quote
Times are GMT -7.   It's 07:02 PM.
