Old 09-22-2012, 09:56 AM   #1
babuja OP
babuja's Avatar
Oddometer: 353
Another XR 650R Acerbis Sahara and Fan Install "How To"
Hy guys,
i've got a Acerbis Sahara Tank to install on my XR 650R and need some advices.
I've lost all parts to fit the tank so need a list of them to try to find them.
Also need a go "How To" tutorial with photos for dummys.
Also have a Hodakaguy tank braces and KTM fan (Spal 4").
At this moment need some help:
1) Identify all parts to fit sahara tank;
2) Find radiator protection that fits along with Sahara tank and KTM fan (Spal 4"):
2.1. Can Devol be sucess fitted or only the Unabiker?
Cheers and Tnks
César
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja screwed with this post 09-22-2012 at 10:07 AM
babuja is offline   Reply With Quote
Old 09-23-2012, 07:01 AM   #2
babuja OP
babuja's Avatar
Oddometer: 353
Again? No one?
Cheers guys
Babuja
________
KTM 950 ADV
Old 11-07-2012, 10:45 AM   #3
babuja OP
babuja's Avatar
Oddometer: 353
HELP Acerbis 24 L fitting Kit?
Hy guys, still couldn't find any infos about a fitting kit to my 24L Acerbis Tank on my XR 650R.
I only have the tank, need some help guys to try to find all parts to fitt it on this beauty.
Cheers guys
Babuja
________
KTM 950 ADV
Old 11-07-2012, 04:15 PM   #4
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,102
Unfortunately Acerbis won't sell you the hardware separately from the tank so you'll have to do a little home brew building. Here's a link to some pics I posted up of the OEM Hardware, scroll down to post #13: CLICK HERE
As far as the radiator brace goes I would just run the tank/tanker brace combo, it really will offer plenty of protection without the brace. I'm not sure what all guards will work with the tanker brace but most should.
Hope this helps
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 11-08-2012, 05:28 AM   #5
babuja OP
babuja's Avatar
Oddometer: 353
Hope this helps
Hodakaguy
Tnks Hodakaguy
Need some idea about T line to use...can´t find anything one ebay.
I remember I had some kind of rapid conector from Tank to T line and from here to Carbs but can´t find it.
Cheers guys
Babuja
________
KTM 950 ADV
babuja screwed with this post 11-08-2012 at 06:12 AM
Old 11-10-2012, 01:16 PM   #6
babuja OP
babuja's Avatar
Oddometer: 353
Fuel line and acessories
Just found what i was looking for:
http://www.motorcycle-superstore.com...-Coupling.aspx
About fuel line what do you guys use with the acerbis sahara: 1/4 or 5/16 line?
Cheers guys
Babuja
________
KTM 950 ADV
Old 11-10-2012, 01:37 PM   #7
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,951
the fan sure looks to be a KTM 640 Lc4/adventure stock fan and shroud
wrk2surf is offline   Reply With Quote
Old 11-11-2012, 04:34 AM   #8
babuja OP
babuja's Avatar
Oddometer: 353
I already have one to install ;)
Cheers guys
Babuja
________
KTM 950 ADV
Old 02-24-2013, 11:02 AM   #9
babuja OP
babuja's Avatar
Oddometer: 353
XR 650R Fan tutorial
Hi,
i've started to draw new suport for the fan in 3mm aluminium
Adjusting fan suport
Fixing fan on suport
And finally
Perfect fitting
On/off switch
Cheers guys
Babuja
________
KTM 950 ADV
Old 02-25-2013, 05:00 AM   #10
babuja OP
babuja's Avatar
Oddometer: 353
DWG fan suport
https://www.dropbox.com/s/qwpxxdiv1b....dwg?n=9957401
Cheers guys
Babuja
________
KTM 950 ADV
Old 04-03-2013, 05:53 AM   #11
babuja OP
babuja's Avatar
Oddometer: 353
Fan Electrical wiring
Cheers guys
Babuja
________
KTM 950 ADV
Old 04-03-2013, 07:20 AM   #12
crypto666
Oddometer: 1,449
You will better function from your fan if you can aerodynamically seperate the front side from the back side of the fan. Look at the fan shroud in your truck/car.
crypto666 is offline   Reply With Quote
Old 04-03-2013, 08:19 AM   #13
babuja OP
babuja's Avatar
Oddometer: 353
Didn't get it...please refrase
Cheers guys
Babuja
________
KTM 950 ADV
Times are GMT -7.   It's 04:19 PM.
