Old 09-24-2012, 11:59 AM   #1
eastbloc OP
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,345
max trailer size/weight?
I'm looking to pare down my four-wheeled collection by eliminating my F150, which I use solely for the occasional Home Depot trip or to haul around a project. I'm thinking about getting a trailer small enough to use around the city on my GS rig, but solid enough to tow behind my car if I need to do a longer trip.
Will a 5x7 trailer like this one, weighing in at 305lbs, pose any problem for me to poke around behind my R1150GS @ 45-50mph tops on short trips?
http://www.walmart.com/ip/UtilityMat...ndingMethod=rr
eastbloc is offline   Reply With Quote
Old 09-24-2012, 12:43 PM   #2
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,428
I have a 40" X 48" trailer that I pull behind my GS rig and it does real well with it. I have hauled my XL500R behind it at 75 down the Interstate with no problems and regularly haul the Rokon with it. The trailer weighs about 120# and the XL is around 340#. The Rokon is a right at 200#.
The trailer also works well as a Mardi Gras float:
06 Ural Patrol
03 R1150 GS Sport/ Friendship II
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
http://www.advrider.com/forums/showthread.php?t=592860
http://dirtydr.smugmug.com/
Proud Member of the Patrol Patrol
DirtyDR is offline   Reply With Quote
Old 09-24-2012, 03:36 PM   #3
eastbloc OP
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,345
That's great, and it's super light, but I need it to be able to haul materials as well as motorcycles.
I guess the combined weight of your scoot and trailer suggests I'll be fine.
Old 09-25-2012, 08:18 AM   #4
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,428
I was going more for gross tonnage information than size there.
The Ural and my GS rig are both a hair pver 5' wide and I didn't want the trailer sticking out past the rigs on the sides with mine.
I do have rails I can put in and a deck on mine for trips to the dump and such but it is still only 40" X 48".
06 Ural Patrol
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
Old 09-25-2012, 08:33 AM   #5
eastbloc OP
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,345
Is it just the perspective of the photo, or did you mount the trailer tongue off-center?
I need to measure the width of my rig. I'd like for it to be able to take a drive with me in the trailer behind my car if needed. I don't really think I would mind if it's wider than the rig. For my purposes, the rig would be hauling the trailer on no more than 20 mile round trips.
Old 09-25-2012, 08:36 AM   #6
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,428
I offset the trailer tongue so that the trailer tires track in the rigs tire tracks. I can run it in the snow and you only see one set of tracks.
06 Ural Patrol
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
Old 09-25-2012, 08:40 AM   #7
eastbloc OP
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,345
Very nice!
Old 09-26-2012, 02:24 PM   #8
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,188
Taken from Girl on an Old Motorcycle thread:
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 09-26-2012, 08:37 PM   #9
eastbloc OP
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,345
These Harbor Freight trailers look more suited for my needs. They're significantly lighter and cheaper while retaining the basic dimensions I want:
http://www.harborfreight.com/1195-lb...els-90154.html
Old 09-26-2012, 09:17 PM   #10
DerViking
Shred
Oddometer: 335
I tow a 4 wheel trailer around the yard with my 250. Based on my experience with heavy trucks and trailers, brakes will be the determining factor. If you are hauling cement, I would look into a inertial brake controller, and a trailer with light electric brakes. Will dramatically improve your outcome in a panic situation. I think you can get hubs and brake disks for the 4 bolt setups that would roughly match your target size.
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly.
DerViking is offline   Reply With Quote
Times are GMT -7.   It's 02:19 PM.
