Old 09-24-2012, 09:29 PM   #1
burmbuster OP
burmbuster's Avatar
Oddometer: 1,430
Tiger 800 XC oil....
Whatcha using? Got out of the break in stage and will not wait until 6k miles to change it. The Castrol stuff the dealer uses is hard to come by around here other than from the dealer.
burmbuster screwed with this post 09-24-2012 at 09:42 PM
burmbuster is offline   Reply With Quote
Old 09-24-2012, 09:34 PM   #2
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,577
swimmer is offline   Reply With Quote
Old 09-25-2012, 04:48 AM   #3
tedder
irregular
tedder's Avatar
Oddometer: 8,797
I'm glad you specified XC. The Tiger 800 can use many oils, but the XC requires Castrol purchased from the dealer.
tedder is offline   Reply With Quote
Old 09-25-2012, 04:56 AM   #4
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
I buy the Castrol at Oreilly's. I change it every 3000 miles. I'm at 11,600 miles & it gets changed at the 12,000 mile service. After that I'll start using something else because I'm going to maintain my bike myself. I like Silkolene but I have to order it.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 09-25-2012, 05:27 AM   #5
burmbuster OP
burmbuster's Avatar
Oddometer: 1,430
Gee, Tedder, your an absolute genius. I'm glad you pointed out that the model of the Tiger that I have makes all the difference. I will be sure to send my threads to you first so you can review them before I post them. Then again, where you live explains quite a bit.
Ever heard of Motul, Silkolene, Bel-Ray, Lucas? That's right genius. There are other brands that meet the OEM requirements other than Castrol. It was a simple question that only needed a simple answer. Just curious what brand other Tiger owners use if different from Castrol.
Oh, but wait. You don't even own a Tiger so what could you possibly bring to this conversation that would carry any weight? Nada.
Old 09-25-2012, 05:28 AM   #6
burmbuster OP
burmbuster's Avatar
Oddometer: 1,430
Thanks, Rob. I will look there. The filters shipped so I will call you when they come in.
Brad
Old 09-25-2012, 06:49 AM   #7
oktulsa17
Oddometer: 207
What a @ss. Tedder tries gives a honest answer to a question you asked and you go off on him. If you don't want feedback, why bother asking?
oktulsa17 is offline   Reply With Quote
Old 09-25-2012, 06:53 AM   #8
bluesman
Oddometer: 3,329
Oil specifications and grades clearly stated in Owners Manual.
As long as oil comply with mentioned grade and standard - any brand will do.
Fortunately on this side of pond Castrol available on every corner and I was using it anyway on my other bikes...It's no better or worse than majority of quality oils of that grade.
bluesman is offline   Reply With Quote
Old 09-25-2012, 07:09 AM   #9
Dirtmonkey8
VA is for Riders
Dirtmonkey8's Avatar
Oddometer: 1,128
Continue using Semi Synthetic
My dealer told me he has seen some incomplete break ins (rings not seated) on the Speed Triples following the manufacturer's recommendation to switch to full synthetic at the first change. He said to continue using semi synthetic until the second change. He also said that Triumph switched to Castrol only because of the supply problems they had with Mobil1. Mobil 1 is certainly a good choice and easier to find. Bel Ray, AMS OIl, etc. are usually as hard to come by as the specific Castrol full synthetic that Triumph recommends.
A little dirt don't hurt.
Dirtmonkey8 is offline   Reply With Quote
Old 09-25-2012, 07:28 AM   #10
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,655
This is the correct answer.
FWIW, I have been using Castrol Power RS 10W50 synthetic.
Old 09-25-2012, 07:31 AM   #11
rustynut2
Oddometer: 481
I found the castol performance 1 4t stuff at advance auto, no one else had what the book called for. Not saying that is the only oil out there. They had it on a side shelf for motorcycles
Work harder, millions on welfare depend on you.
12 T800XC
09 KLR 650
rustynut2 is online now   Reply With Quote
Old 09-25-2012, 07:44 AM   #12
tedder
irregular
tedder's Avatar
Oddometer: 8,797
Spend more time around here before you get overly butthurt. Oil threads are a dime a dozen.
I was talking about the "baby tiger" before it was ever announced, I've hooliganed an 800 with barely 50 miles on it, I've made oil mistakes on other bikes.
Old 09-25-2012, 08:21 AM   #13
bluesman
Oddometer: 3,329
There is no relation whatsoever between using mineral, synth of half-synth oil and unsuccessful break in - not technically nor "scientifically".
I ran in bikes new and after DYI top end rebuild and never seen issue using full synth 10w50 (as it is cheap from Hein Gericke).
But I have seen how bad is performance (life-wise) of mineral oil comparing to synthetic.
Tiger motor is not in any way special in terms of top-end design. Therefore I think dealer seen cases of incorrect break in and related it with oil type. I'd argue his statement not correct.
Old 09-25-2012, 10:13 AM   #14
burmbuster OP
burmbuster's Avatar
Oddometer: 1,430
He was being a smartass. He was not giving an honest answer.
_______________
2013 KTM 690 Enduro R
Old 10-18-2012, 04:01 AM   #15
LBJM
LBJM's Avatar
Oddometer: 4
+ 1
Tiger 800 XC
LBJM is offline   Reply With Quote
Times are GMT -7.   It's 01:38 PM.
