Old 12-30-2012, 10:39 AM   #16
Peanuts
Peanuts's Avatar
Oddometer: 1,698
You two guys need to check the part shown in the phot and the locking lever that has a bearing that rolls against it.
No need to drain the oil, just lay the bike over or just drain the oil out the motor then put that back into the oil tank after running the motor for 30 seconds.
Peanuts is offline   Reply With Quote
Old 12-30-2012, 09:51 PM   #17
Dotbond OP
Africa, Africa
Dotbond's Avatar
Oddometer: 773
Bit of an update, the 990 is still fine, but I have recently traded it on a new 690. I had been wanting a 690 for about 6 months so finally bit the bullet. Regarding the 990 gearbox, the motor has to come out of the frame and be stripped/split. So a reasonably major job. The main culprit was one of the bearings that the shift drum relies on. It was binding. Various other parts were replaced as well including all 3 shift forks.
0625618052
BALL BEARING 61805 C3
superceeded by
0625618050
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Times are GMT -7.   It's 05:41 PM.
