Old 03-10-2013, 07:54 PM   #61
boardrider247
Weekend Anarchist
boardrider247's Avatar
Oddometer: 656
I just want to bump this one up.
Hopefully I will be needing a few wheel spacers made in the near future if I get my ass in gear.
Life is a waste of time, Surfing is a great way to waste it
boardrider247 is offline   Reply With Quote
Old 03-11-2013, 01:35 PM   #62
jesusgatos OP
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Funny timing. Need to have some custom wheel spacers made for this project. 5 on 112mm lug pattern, 10mm thick, with a 57.1mm bore on the spindle side and a 66.56mm snout on the wheel side. Can provide drawings with detailed dimensions, but it's pretty straightforward.
jesusgatos is offline   Reply With Quote
Old 03-18-2013, 11:16 PM   #63
assquatch20
Hoss Cat
assquatch20's Avatar
Oddometer: 1,102
I could definitely use somebody that could have a look at my bike and fab up a skidplate and rack.
Some things shouldn't be left like you found them.
assquatch20 is offline   Reply With Quote
Old 05-08-2013, 11:35 PM   #64
assquatch20
Hoss Cat
Oddometer: 1,102
I kilt it
Seriously though, somebody to convert a swingarm for me so I can use eye-to-eye shocks would be great. Plate and rack are taken care of.
Old 05-09-2013, 10:04 PM   #65
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Maybe post-up some more details about exactly what you need help with?
Old 05-10-2013, 12:58 AM   #66
assquatch20
Hoss Cat
Oddometer: 1,102
Somebody who can make a shock clevis and weld it to a swingarm after grinding off the old eye, essentially, that's it. I send them a swingarm, they convert it. I can draw it up in AutoCAD or oldschool if need be. Or maybe take a crack at the Google Sketchup, haven't got to try that yet.
Old 05-10-2013, 01:49 AM   #67
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Even napkin sketches might help, just to give some of us an idea of whether or not we might be able to help you.
Old 05-11-2013, 07:46 AM   #68
xcflyn
xcflyn's Avatar
Oddometer: 1,145
Shoot me a cad DXF,DWG,PDF,NS - and I can most likely take care of it. (NS - napkin sketch)
PM me if you want to send me files or drawings.
xcflyn is offline   Reply With Quote
Old 06-14-2013, 01:00 PM   #69
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,312
I have years of experience in composites. All Fiberglass no CF. I made production molds for Cheetah Racing Bodies, sportbike bodywork for race and direct street replacement. Sort of like what Hotbodies and SharkSkinz (who I think ended up with my molds after we closed up) are doing. I've made hundreds of production molds from 2004-2008 for the 4 Jap manufacturers and now I'm making small runs of fairings for Rally Moto Kit. I can take on smaller parts, smaller runs, smaller volume just now, but I have a feeling I'll be available for larger production volume in a few months....
I also need some metal work done. Right now I have an oil cooler I designed for my bike. If you have some space in your work sched I'd like to talk to you about an inexpensive ( I know aren't we all) one or two off. I need to have it done certainly before August (for testing before Rally de Motos) and would like to have it in a few weeks if possible. Here's a pic. I have solidworks files and dimmed out drawings complete. If it would help I can probably do the CAM file for it also.
http://advrider.com/forums/showpost....postcount=1488
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 06-14-2013, 01:32 PM   #70
Bounder
ExternallyDisplaced
Oddometer: 837
Your oil cooler looks very similar to the one ABP make in Germany.
http://www.abp-racing.de/%C3%B6lk%C3%BChler/
Might be easier to just buy em in?
Bounder is offline   Reply With Quote
Old 06-14-2013, 01:35 PM   #71
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,312
Some pretty bright fellows over there it appears.
Old 06-17-2013, 08:28 AM   #72
Bounder
ExternallyDisplaced
Oddometer: 837
Great minds think alike!
Old 08-14-2013, 07:34 PM   #73
boardrider247
Weekend Anarchist
Oddometer: 656
I'm working on a fork conversion for my 99 Gas Gas EC 300 it uses 25mm ID X 52mm OD roller bearings. The Husqvarna forks/triple I want to use takes a 29mm ID X 50.25mm OD roller bearing.
So far I have had no luck locating a roller bearing with a 29mm ID and 52mm OD.
Is it feasible for someone to make me a shim/spacer from 50.25 to 52mm and 16mm wide?
Old 08-14-2013, 07:48 PM   #74
Daryl_Stamp
Daryl_Stamp's Avatar
Oddometer: 791
Possible, but probably not practical unless you have friends with ID/OD grinding set ups. Any chance the Husqvarna part could be opened up to be able to use a thicker ('easier to make') wall spacer?
OTOH, someone with lots of time and a tool post grinder on a lathe might be able to help you out.
Live while you're alive.
Daryl_Stamp is offline   Reply With Quote
Old 08-14-2013, 07:57 PM   #75
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Not to steal anyones work but is this the bearing you need?
Timken L45449 (inner)
Timken L45410 (outer)
29.000mm bore
50.292mm OD
http://catalog.timken.com/WebProject...Code=trb12flx#
It sort of works. Go to page 111 and 4th one up from the bottom.
"But I swear, a woman's breast is the hardest rock that the Almighty ever made on this earth, and I can find no sign on it." Bear Claw Chris Lapp
Justin
01 F650GS Dakar
KG6BWS is offline   Reply With Quote
Times are GMT -7.   It's 12:20 PM.
