Old 09-26-2012, 07:19 PM   #1
BillyD OP
BillyD's Avatar
Oddometer: 635
KTM 640 Cuts Out Once Warmed Up
So here's an odd one.
The 640A starts up and idles just fine when cold.
However, once it's warmed up (4 bars), it then cuts out and dies. Bike is on the lift and not being ridden (so its not likely the ignition switch issue)..
It doesn't seem to be running out of gas. It seems more electrical given how it suddenly cuts out and dies.
But I can't think of anything electrical that is temperature dependent. The ignition coil looks to be in good physical condition. On my previous LC4, I had the ignition pickup and/or stator go bad, but in that case the bike wouldn't start at all.
Anyone else with similar symptoms?
Thanks.
Bill
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Ducati 851, Moto Guzzi 850 Lemans, Ercole & 2VT and Yamaha RD350.
BillyD is offline   Reply With Quote
Old 09-26-2012, 07:59 PM   #2
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,301
Thanks.
Bill
An easy way to tell if it's ignition related is to pull the plug and check for spark when the bike starts its stalling thing once warm...
gunnerbuck screwed with this post 09-26-2012 at 08:07 PM
gunnerbuck is offline   Reply With Quote
Old 09-26-2012, 08:19 PM   #3
BillyD OP
BillyD's Avatar
Oddometer: 635
The issue with that is the bike will restart after it dies and run for a bit. So the problem seems intermittent.
Bill
Old 09-26-2012, 08:41 PM   #4
jon6.0
jon6.0's Avatar
Oddometer: 546
Almost sounds like a fuel supply issue. Like the tank isn't venting properly.
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 09-26-2012, 10:24 PM   #5
BillyD OP
BillyD's Avatar
Oddometer: 635
That was the first thing I thought of too, but it still does it with the gas cap removed. I too have been caught out previously by inadequate tank venting.
For grins, I also swapped out the Keihin 41 FCR with the stock Mikuni and then swapped fuel pumps even though I couldn't rationalize why they would act up based on temperature. I have yet to check the fuel petcock screen to see if it might be clogged, but based on the about of gas that flows freely from the hose, all should be good.
The mystery continues....
Bill
Old 09-27-2012, 02:44 AM   #6
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,636
Ignition pick-up coil is worth a look. When they warm up, resistance changes and they fail. Leave the bike parked on the side of the road for a few minutes, and then when they cool down the bike starts up again. First generation Hinckley Triumphs were renowned for it, this was the pickup-coil's classic failure mode: they rarely died outright.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is online now   Reply With Quote
Old 09-27-2012, 06:08 AM   #7
BillyD OP
BillyD's Avatar
Oddometer: 635
Yeah, that's pretty much where my head is at too, especially in light of it failing in my other LC4 640 as well. Thanks for the Triumph cross-link.
Once replaced, I'll report back.
Bill
Old 09-27-2012, 10:00 PM   #8
bmwktmbill
Traveler
Oddometer: 5,218
Billy,
Just for the heck of it wiggle the main fuse and change the spark plug...if you haven't.
I've had plugs do those symptoms and the main fuse on my Adventure did that to me on a lonely road in the Dakotas.
The fuse holder got worn and the legs were loose.
With your symptoms does the bike die or does all the electricity go away?
I have had a kill switch issue and an ignition switch issue as well that caused various problems. The engine vibration is enought to mimic a gravel road(haha).
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 10-11-2012, 09:32 PM   #9
BillyD OP
BillyD's Avatar
Oddometer: 635
Problem Solved
Originally Posted by bmwktmbill View Post
Billy,
Replaced the ignition pulse coil, still had a miss.
I checked the plug earlier, but Bill's comment got me thinking. Upon closer inspection of the ignition wire and
spark plug boot, here's what I found.
Problem solved. Also now has some dielectric grease to help prevent a repeat.
Thanks one and all for the help.
By coincidence, here's a thread on dielectric grease and contact lubricants...http://www.advrider.com/forums/showthread.php?t=832375
Bill
Old 10-11-2012, 11:09 PM   #10
bmwktmbill
Traveler
Oddometer: 5,218
Billy,
Just went down and greased my cap just to be sure.
Maybe you will start something.
Good one...!
bill
Bill Shockley
Old 10-12-2012, 07:15 AM   #11
SRG
SRG
SRG's Avatar
Oddometer: 1,319
I can't tell what I'm looking at the pic above - can you please explain for the blind what the issue was?
SRG is offline   Reply With Quote
Old 10-12-2012, 07:49 AM   #12
BillyD OP
BillyD's Avatar
Oddometer: 635
There's a plastic thingee between the iginition wire from the coil and spark plug. The picture is of the end opposite the spark plug.
There is some speculation in the other thread on dielectric grease that this condition was caused not by corrosion, but rather because the ignition wire might have been loose enough to cause arcing.
In any case, I cut the end of the ignition wire, cleaned the electrode and reassembled with small amount of dielectric grease and life is good again.
I get despondent when one of my bikes is misbehaving....
Bill
Old 10-12-2012, 08:26 AM   #13
SRG
SRG
SRG's Avatar
Oddometer: 1,319
So, it was the contact in the cap that fits on the coil (that was corroded/not getting good contact), correct?
I've seen others have a dodgey connection at the spark plug cap - this was similar - just at the other end?
Old 10-13-2012, 07:24 AM   #14
BillyD OP
BillyD's Avatar
Oddometer: 635
The latter..... P/N 58439090000
Bill
Times are GMT -7.   It's 01:47 PM.
