Old 09-28-2012, 03:27 PM   #16
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,291
I think Benesesso means that you should put the locktite on the shaft instead of the set screw if the shaft still slips after you replace the grub screws (love that term!) with bolts.
GreaseMonkey is offline   Reply With Quote
Old 09-28-2012, 04:06 PM   #17
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Yup. While waiting for Dirty-Sanchez to provide the official recommendation, I'd make sure the shaft, cam and screws were real clean. Then use Loctite's high strength retaining compound and the red "Stud Lock" on the screws.
Either that or some high strength epoxy.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 09-28-2012, 07:42 PM   #18
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,696
Originally Posted by JAB View Post
There is a square key on it already with one of the set screws on top of it to clamp it.
Thought about drilling and tapping one more hole for a set screw and drilling a matching divot into the shaft for the screw to catch.
Keep it coming.
I think it's gib keys that have a slight taper. Knurled cup setscrews hold very well, drilling and tapping the end of the shaft for a washer works if you have room.
3 setscrews isn't unheard of, ran in and out until they dig in and stay tight, as mentioned loctite will help a sloppy fit.
katbeanz is offline   Reply With Quote
Old 09-28-2012, 11:54 PM   #19
Beezer
Oddometer: 5,737
try the locklite, if that don't do it, what I wound do is drill a hole down between the shaft and the cam, tap it for something like a 1/4" or 5/16" bolt and then run a grade 8 bolt into the hole. the shaft and the cam each get half the bolt. obviously the cam needs to be in the right place.
Beezer is offline   Reply With Quote
Old 09-29-2012, 06:18 PM   #20
ttpete
Rectum Non Bustibus
Oddometer: 5,829
With the setscrew you have in there, you're torque limited because the hex socket isn't supported by the threaded hole and will break apart if too much torque is applied. Headless set screws should always be flush with the surface or below it. I'd be inclined to drill a deep dimple in the shaft and then use a hardened Unbrako or Allen brand hardened allen head capscrew with a point ground on it to match the dimple, using a locknut, red loctite and sufficient torque.
15 BMW RnineT
09 Kaw Versys
Old 10-03-2012, 09:47 PM   #21
JAB OP
Unsprung Weight
JAB's Avatar
Oddometer: 1,243
The verdict
First off, thanks to all for the ideas and support.
Did the repair on Monday and the cam has not moved. Original plan was to replace both set(grub)screws with grade 8 hex bolts and jamb nuts. Due to tight clearances I was only able to replace the larger bolt and left the screw on the key as it was. Also used some Loctite retaining goo on the shaft. The hex bolt made a big difference in the amount I was able to tighten it. Has a good bite on the shaft now. If it were to move again I would consider one of those pointed bolts with a divot drilled into the shaft. So we're back up and running and all is well in printing land once again.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 10-06-2012, 07:46 PM   #22
no5s
Terror at 2 mph
no5s's Avatar
Oddometer: 342
set screw
Look up dog point set screw for a simple fix.
12 Super Tenere
84 R80 ST
64 R50/2
65 Triumph TR6 Desert Sled
65 Triumph T100SC TT Bike
no5s is online now   Reply With Quote
Times are GMT -7.   It's 08:39 PM.
