09-27-2012, 05:21 PM
#1 |
Oddometer: 840
If I were to connect an ignition coil directly to a battery
What would happen? Provided a spark plug is attached to the coil, too...
09-27-2012, 05:36 PM
#2 |
Wrench Rider
Oddometer: 712
Each time you break the connection to the battery, the plug will fire.
I sometimes bench-test coils by connecting the coil to a battery and sparkplug. Or better, to a spark-tester with a much wider gap of 10mm or more. |
09-27-2012, 05:40 PM
#3 |
Gringo Viejo
Oddometer: 461
This is a good way to install a flame thrower. Just need a source of gas or propane, a metal tube and you are in business
Mexico - Dream, Discover, Ride Hotel Los Arcos, Northern Sonora's Motorcycle Haven http://www.losarcossonora.com |
09-27-2012, 06:42 PM
#4 |
Wrench Rider
Oddometer: 712
09-28-2012, 03:42 AM
#5 |
Oddometer: 4,539
For the flame thrower they used a model T coil that had points that vibrated all the time to drive the flame thrower plug.
Or you could use a normal 12 V relay with 2 sets of contacts, one set wired as a buzzer, the other drives the coil. If you used it a lot, it would not last long but for a novelty it is perfect When gas was 20 cents a gallon this was fun. Rod |
09-28-2012, 04:19 AM
#6 |
Thread Ninja
Oddometer: 1,140
a proper flame thrower, is run by gasoline, or petrol, force fed by compressed air into the petrol tank, to push it out. pump and ignition were two separate buttons too, so u could spray petrol 100 meters away, yes they do travel a bloody long way, not like movies, to run into a bunker, and then ignight it.
ive often thought about a efi fuel pump 12v battery, to make something, quight illegal... |
09-28-2012, 08:55 AM
#7 | |
Oddometer: 56
1. The engine won't turn off when you turn the key off. 2. You'll burn the coil up if its "on" and not running. 3. Drain your battery if the engine isn't running. |
09-28-2012, 01:33 PM
#8 |
Oddometer: 8,492
One more little goodie. 6V car coils are meant to run at ~6.7 volts. 12V car coils are built to run at ~9-10 volts continuously. They'll take 12-13 volts intermittently.
US out of the UN, UN out of the US. |
09-28-2012, 02:14 PM
#9 | |
KLR-650
Oddometer: 260
On topic again... a coil is just a transformer. They only work when the input is changing. 12v, just connected - not changing, will just heat the coil up, nothing at the output at all. You need to make and break the input to get spark on the output. David... |
09-28-2012, 05:05 PM
#10 | |
Thread Ninja
Oddometer: 1,140
09-29-2012, 08:31 AM
#11 | |
Spilt my beer
Oddometer: 3,365
09-29-2012, 09:54 AM
#12 | |
Oddometer: 8,492
09-29-2012, 10:32 AM
#13 |
Oddometer: 4,417
when the starter engages, the battery voltage drops, so the coil is designed to run on the lower voltage (about 10V) to produce a hot spark. once the engine starts and the system resumes normal voltage, current to the coil is reduced by the ballast resistor. in start mode the coil is wired to the main buss through the key switch. in normal run mode the key switch puts the resistor is in series with the coil so the voltage will be reduced to the coil only
09-29-2012, 11:09 AM
#14 |
Oddometer: 8,492
Nailed it.
09-30-2012, 06:44 PM
#15 |
MIL-TFD-41
Oddometer: 872
So why are 6V coils meant to run at 6.7V?
Mike So far, everything that has surprised me has been completely unexpected. BMW R1100RS |
