Old 10-27-2011, 07:27 AM   #1
NJ Grizzly OP
NJ Grizzly's Avatar
Oddometer: 166
V Strom whats your mileage
I own a 2008 dl 650 with over 33k. Only had one problem. The headlight / starter switch in all that riding.
thanks
NJ Grizzly is offline   Reply With Quote
Old 10-27-2011, 07:35 AM   #2
pjm204
Oddometer: 2,012
I'm on my third strom, sold my first, a 2006 DL1000 with around 23k to get a 2008 DL650 that I wrecked at 12k, which I replaced with a 2006 dl650 that is now just shy of 20k.
Best all around bike I've ever owned.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 10-27-2011, 07:38 AM   #3
HarveyMushman
commutingmysentence
HarveyMushman's Avatar
Oddometer: 16,339
99,800-something. No problems.
EDIT: I take that back. There was a thermostat issue. Somewhat fixed now.
Tim
photo galleries
HarveyMushman is offline   Reply With Quote
Old 10-27-2011, 01:01 PM   #4
Chuck in Indiana
Oddometer: 322
I'm approaching 24K miles on my /09 ABS model. I've owned it almost two years. It has done very well for me. I use it for long distance touring and camping trips. Am planning on up-grading the suspension, checking the valves and changing to new sprockets and chain this winter. Gives me something to do when it is cold outside and I can't ride.
Chuck in Indiana is offline   Reply With Quote
Old 10-27-2011, 01:09 PM   #5
SV_Dwayne
SV_Dwayne's Avatar
Oddometer: 310
'06 DL650 with 43k miles on it.
Never had a problem with it. Usual wear and tear stuff, just changed front brake pads for the first time, new battery this summer, stuff like that.
Kicking ass seems to be THE ONLY solution to life's problems. Kicking ass is the first, second and third option. Plan B and C are also kicking ass.
SV_Dwayne is offline   Reply With Quote
Old 10-27-2011, 01:26 PM   #6
pjm204
Oddometer: 2,012
I checked my valves at 19,200 and all of them were tight....some out of spec but all needed adjustment
Old 10-27-2011, 01:55 PM   #7
CanadianTiger
CanadianTiger's Avatar
Oddometer: 49
How do you ride the bike? Heavy throttle, high rpm? Or relaxed easy low rpm riding?
Richard
2012 DL650 V-strom (White standard)
CanadianTiger is offline   Reply With Quote
Old 10-27-2011, 01:59 PM   #8
WeeMcD
V-Strom explorer
WeeMcD's Avatar
Oddometer: 475
thanks
Bought my 2007 DL 650 new and it now has 46k miles. Had same headlight/starter switch issue and rubbed through harness under tank. Other than that, it has been general maintenance. Love this bike.
Blog of my adventures: www.BestScenicRoutes.com
"When all else fails get a bigger hammer."
WeeMcD is offline   Reply With Quote
Old 10-27-2011, 02:00 PM   #9
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 1,009
My 2007 DL650A is approaching 74,000 miles. The stock headlight wiring is a weak link. I had an Eastern Beaver headlight relay kit for a long time before going to HID lights that also are relay controlled. It's a lot easier on the stock system to turn on a relay rather than a headlight.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is offline   Reply With Quote
Old 10-27-2011, 02:32 PM   #10
pbarmy
pbarmy's Avatar
Oddometer: 1,818
16,800.Just replaced my roached chain,which was toast after a run to Barber vintage fest,some 1600 miles.Lovin the bike so far,had 4500 or so when I bought it some two and a half years ago.Oh and new brake pads too,thogh the og's still had material left.
pbarmy is offline   Reply With Quote
Old 10-27-2011, 03:06 PM   #11
emti
Oddometer: 271
2008, 26 thousand miles, no major problems, emti
emti is offline   Reply With Quote
Old 10-27-2011, 03:14 PM   #12
theDoktor
Husky Racer
Oddometer: 145
2007 DL650 with 13,750 miles. Bought with 8K this spring. No problems so far- just replacement tires & routine maintenance. My Eastern Beaver dual headlight relay kit just shipped today. Thanks for the heads-up on this weak link item, Greywolf!
theDoktor is offline   Reply With Quote
Old 10-27-2011, 03:18 PM   #13
pebble35
pebble35's Avatar
Oddometer: 1,562
Had a 2007 650 that I owned for all of 6 months. But I did put 24,000 miles on it in that time !
3 sets of tyres, two sets of brake pads, one air filter, three oil changes and one chain & sprocket set (but it did not really need it). Valves checked Just before sale and all OK.
Looking to buy a 2012 Wee soon ...............
Proud to be supporting Pyndon
www.lyndonposkittracing.com
www.bikersjersey.com for all your KTM parts
A 2,400 KM ride around Egypt by Scooter - ride report here
pebble35 is offline   Reply With Quote
Old 10-27-2011, 05:16 PM   #14
phunmusicphan
Dude
phunmusicphan's Avatar
Oddometer: 429
K7 DL650 14,498 today. Got it last October with 11,400 on it. Love it!
Were off like a herd of turtles.
We are off like a herd of turtles!
phunmusicphan is offline   Reply With Quote
Old 10-27-2011, 07:11 PM   #15
der_saeufer
?איפה בירה
Oddometer: 652
'04 with 86k here, 5k of which are mine. The PO (hi Austin!) fried the clutch pretending it was a KLR and had to adjust the valves a couple times. Otherwise no issues, and no evil headlight wiring through the starter switch on the '04. It burns somewhere around 250mL of oil between changes. Wish I could get my 21k mile KLR to do that.
der_saeufer is offline   Reply With Quote
Times are GMT -7.   It's 04:27 PM.
