Old 09-29-2012, 07:05 AM   #1
m800mm OP
Oddometer: 65
Michelin T- 63 how are they working
How are the t-63 working for you guys. I need a new front to replace my scorp..
I have a mefo SE on the rear and thought that might be a good combo for the 990.
I spend alot of time on the slab.
m800mm is offline   Reply With Quote
Old 09-29-2012, 09:02 AM   #2
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,104
I tried the T-63 and took it off. It was slightly better for me in the dirt than the TKC-80, but leaned over on the slab it was unpredictable and uncomfortable. If you compare them, the TKC has about 4x the side knob area so it makes sense.
For my uses and terrain, the TKC is a better choice.
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 09-29-2012, 02:33 PM   #3
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 571
T63 front
I like them on my SE. Theres better tires for more street. I'm not trying to drag my pegs on the street so they work good enough for me. The knobs don't wear as funny as 606 or MT21 on the street. I can get them real cheap.So i'm happy
dogsslober is offline   Reply With Quote
Old 09-29-2012, 07:30 PM   #4
AdvRonski
They call me......Ronski
Oddometer: 556
I had the opposite experience from alleycatdad. I could push the T63 very hard on the street, as in going on a sportbike ride on twisty WI backroads, while keeping up with R1's and Ducatis. The TKC80, with it's taller knobs, will squirm and walk a bit at the same pace.
Plus, the T63's are cheaper!
Ronski
Enduro Racer & Google Earth Adventurer
AdvRonski is offline   Reply With Quote
Old 09-30-2012, 10:52 AM   #5
mjlang
Man Caves Rule!
mjlang's Avatar
Oddometer: 151
I ran a set of T63s on a 1100 on/off road ride in Mexico last year. I snowed on us in the mountains for the first 200 miles, so wet and a little slimy; they worked better than I anticipated. Further south, it was hot with lots of deep sand. As long as you kept moving, the rear worked OK. The front was fine in all conditions.
The only flaw was that the rear started to rip at the base of each knob. It didn't rip through the carcass but I really had to be careful for the last 300 miles as not to destroy the tire.
Bottom line; I don't think the rear holds up well on a 950/990 due to the HP and wheel spin. My buddy has a set on his KLR and they worked really well so I'd say on a lighter lower HP bike, no problem. I don't know how they would do on a street-going ocean liner GS 1200.
If it flys, f*cks, or floats... RENT IT!
'06 KTM 950 Adventure S
'07 KTM 450 EXC
mjlang is offline   Reply With Quote
Old 10-01-2012, 04:36 PM   #6
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,693
I run 36psi frt & rear at all times
Originally Posted by m800mm View Post
... I need a new front to replace my scorp..
I have a mefo SE on the rear ...
I spend alot of time on the slab...
The T63 fronts have too Flimsy of Sidewalls for a big bike.
The TKC has short tread depth & also thin sidewalls.
The stock (SE) front Metzeler Karoo TRAVELER knobbie has outlasted ANY front tire I've found for true 50/50 dual sporting.
I love the REAR Mefo Super Explorer
High air pressures is the key to longevity & less likely flats on big bikes
Brown Dog is offline   Reply With Quote
Old 10-01-2012, 06:00 PM   #7
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,106
You're serious? I think I got 1000 miles out of the stock front and fewer out of the rear. It was great on the street though.
traveltoad is offline   Reply With Quote
Old 10-01-2012, 06:23 PM   #8
Brown Dog
Brown Dog's Avatar
Oddometer: 1,693
The Expen$ive Karoo "traveler" Front - NOT the regular cheaper Karoo front.
All rear karoo rears is DOO DOO IMHO.
Old 10-01-2012, 06:29 PM   #9
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,106
Ahh... . Ok.
Old 10-01-2012, 06:36 PM   #10
genghis9021
Arak Connoisseur
genghis9021's Avatar
Oddometer: 206
Karoo 2 (not Brown Dog's 'T') and K60 Mefo/Hidenau
I got 6500 miles out of a Karoo 2 (with a Tubliss insert) on a ride from Beyneu, Kazakhstan to Ulaan Bator, Mongolia. There was alot of bad tarmac and a helluva lot more dirt/sand/gravel.
The Karoo 2 is CHEAP, like the T63. The Tubliss extended life, in my experience, another 2000 miles.
The Karoo (T) on my Husky TE630 is fantastic on street and I chase sport bikes into every corner I can.
It's hard to add to the K60's reputation. On this run, 12,000 miles and I'm still a long way from the wear bars. That's on a 2.5" rear rim with a 140/80.
2011 Husky TE 630 2011 Husaberg FE 570S
2006 KTM 950 'S' ADV 2005 Suzuki DRZ 400 SM
"The perfect is the enemy of the good."
Orange, it's the new black Tour.
genghis9021 is offline   Reply With Quote
Old 10-01-2012, 07:12 PM   #11
dogsslober
dogsslober's Avatar
Oddometer: 571
The question was
How you like a T63 front. That is if you have ran one. Not what your favorite tires are
Old 10-01-2012, 07:22 PM   #12
avocadofarmer
Oddometer: 161
I've got one on the Adv now and it's been good...haven't had a chance to run a lot of dirt lately, got about 3k on the tire and it looks good. Very little cupping and good tread left. It feels way better on and off road than the Mefo Explorer it replaced.
Keep the PSI up!
avocadofarmer is offline   Reply With Quote
Old 10-01-2012, 08:13 PM   #13
genghis9021
Arak Connoisseur
Oddometer: 206
I like the T63 on a Husky 630, etc. The ADV is a little heavy. PSI has to be kept up. The sidewalls are not stiff, just like the 21" TKC (the 19" TKC is relatively stiff).
The Michelin Desert, which the T63 is based is not cheap but is great on the ADV, on front.
Old 10-02-2012, 02:48 PM   #14
m800mm OP
Oddometer: 65
I guess I will just have to try it myself as there are so many
opinions. I think the scorps have very soft sidewalls so I don't
know if thats a problem. After having a rear flat on the stock
scorp it was a breeze to change by the side of the road but the new
Mefo has a stiff sidewall and probably be a bitch.
Old 10-02-2012, 09:01 PM   #15
genghis9021
Arak Connoisseur
Oddometer: 206
The soft sidewall will be especially noticeable (!) when you flat . . . ever moreso on a heavy bike.
Times are GMT -7.   It's 05:18 AM.
