Old 09-29-2012, 02:28 PM   #1
SF_Rider OP
Oddometer: 443
Holy frijoles! 16 tooth!
Just had new chain and sprockets installed. Went with the 16 up front. Man. If you thought the 990 was fast to begin with, hang on tight.
If your thinking of doing this just jump in. If you weren't thinking of doing this, start thinking of doing it!
SF_Rider is offline   Reply With Quote
Old 09-29-2012, 02:43 PM   #2
triplenickel
triplenickel's Avatar
Oddometer: 2,200
Wait until you start playing with the back end.
07 SE
PG007
Old 09-29-2012, 04:07 PM   #3
mousitsas
Oddometer: 2,143
I thought so myself until I started de-restricting the intake....
Old 09-30-2012, 07:15 AM   #4
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 556
2004 called, said something about getting caught up.
Sporting Wood is offline   Reply With Quote
Old 09-30-2012, 07:17 AM   #5
hooliken
One finger braker!
hooliken's Avatar
Oddometer: 2,101
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
If Momma ain't happy ain't NOBODY happy!
2007 950R Super Enduro
2006 Buell XB12X
hooliken is online now   Reply With Quote
Old 10-01-2012, 02:33 AM   #6
BartG
BartG's Avatar
Oddometer: 170
I went from 17 - 42 to 16 - 45... let me tell you, BIG difference!
No point in having a ADV that can do over 200KPH
BartG is offline   Reply With Quote
Old 10-01-2012, 03:36 AM   #7
mousitsas
Oddometer: 2,143
Gearing on its own does not mean much. Goes hand to hand with how good fueling is. Based on my experience with the different setups I have tried on my SE, I would say that 1st with 16/45 is a necessity on a stock carb-ed 950 but pretty useless on the street with a better carb/exhaust setup. Right now I have 17/42 and my bike can climb my garage ramp (not too steep but steep enough) on 1st at idle.
Old 10-01-2012, 01:48 PM   #8
DrKayak
Retro Rider
DrKayak's Avatar
Oddometer: 536
I run crazy low gearing on my 450. 50MPH is maxed out in 6th. I considered going lower than 17/42 on my 950 but just can't see wanting it geared any lower on the street.
Once I was on some wicked technical stuff and the 950 got hot from slipping the clutch to go slow. On the other hand, I use 6th on the pavement every ride to milk more range out of the fuel hungry beast.
06 950 Adventure
96 Beta Techno
07 450 EXC
04 FZ1
DrKayak is offline   Reply With Quote
Old 10-01-2012, 02:22 PM   #9
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,303
I'm putting that on my bike soon, I've had the chain and sprockets a while, just haven't had a chance to do it yet. Can't wait!
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Chad Berger KTM950ADV, DR650
Lone Wolf Expeditions
rokklym is online now   Reply With Quote
Old 10-01-2012, 02:31 PM   #10
TheMuffinMan
TheMuffinMan's Avatar
Oddometer: 3,715
I run 16/42 and that feels a good mixed size. For all the mountains around me a 16/45 would be nicer for the technical climbs but I wouldn't want the deceased range brought on by the lower fuel economy at highway speeds (120-130 kph)
Then again after going to a .5 clutch oil jet slipping the clutch for an extended duration isn't an issue with 16/42.
"Civilize the mind, but make savage the body."
To the house of a friend the way is never long.
"Show respect to all, but grovel to none."
'12 690 Enduro // 690 Wiki
TheMuffinMan is online now   Reply With Quote
Old 10-01-2012, 02:50 PM   #11
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,303
With the stock gearing I rarely use 6th, so I think I should be OK with the lower gearing for now. Next springs long trip might be much, but maybe I'll just throw on a 17 for that.
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Old 10-01-2012, 03:40 PM   #12
triplenickel
Oddometer: 2,200
The gearing changes really don't have much effect on range I find, I'm at 16/47 and still get the damn near same as I did with stock and there's no comparing the 2 fun wise.
07 SE
PG007
Old 10-01-2012, 09:24 PM   #13
Just Paul
Pro Cat Herder
Just Paul's Avatar
Oddometer: 1,942
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
THE BEST THINGS IN LIFE ARE NOT THINGS
Just Paul is offline   Reply With Quote
Old 10-02-2012, 07:01 AM   #14
Sporting Wood
Oddometer: 556
+1
Its incorrect to associate lower rpm's at speed with better mileage. Its just an assumption, completely unsubstantiated, and a reflection of the posters misunderstanding of how motors work. If this were true, every vehicle would be geared to idle for cruise... Motor efficiency is a function of several factors, rpm being only a small part, torque curve being the biggest.
Since you have your bike geared to where your riding right in the meat of the LC8's torque, your mpg is no worse.
I personally found that running 16/45 slightly boosted my typical range over what I got when I first got my bike. Now typically getting the light around 180-190 miles, and running big fat 175 main jets to boot.
Old 10-02-2012, 10:38 AM   #15
Navin
Unwounding
Navin's Avatar
Oddometer: 4,326
16-50 is the cat's pajamas. +1 on the MPG, has little to no effect. The wrist controls the fuel.
Navin is offline   Reply With Quote
Times are GMT -7.   It's 11:43 AM.
