Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 09-30-2012, 09:24 PM   #1
hayduke357 OP
hayduke357
hayduke357's Avatar
Oddometer: 464
2012 jeep wrangler six speed manual
I was going to pull the trigger on a 2012 jeep wrangler unlimited manual today, however, been reading some problems with the Manual Trans. I have read most of the forms but most seem to be operator error. Anyone with real word experience with the 2012 manual?
hayduke357 is offline   Reply With Quote
Old 09-30-2012, 10:31 PM   #2
DLFLHT
Oddometer: 378
I've been looking too and saw a little bit about the manual transmission, but I think the Pentastar cylinder head issues are a much bigger deal for me. I decided to wait for a 2013 as I think the 2012s will have a cloud over them in the resale market down the road.
DLFLHT is offline   Reply With Quote
Old 10-01-2012, 07:30 AM   #3
Mini Trail
n°°b
Oddometer: 2,227
I have one, 14,000 miles no issues with the transmission but I have nicked reverse before trying to shift into 8th gear. It doesn't happen going from 5th to 6th but more if you get lost or change your mind or whatever and have to find 6th from Nuetral. The gates aren't real defined.
Most of my trouble came from driving an F150 5 speed for the past 10 years even its worn 300K mile 4.6 V8 had way more torque than the Pentastar. I was used to just side stepping the clutch and not touching the gas. I stalled the Jeep a bunch learning low speed driving.
Your cycle had a bell on it.
Mini Trail is offline   Reply With Quote
Old 10-01-2012, 12:31 PM   #4
jeepkevin
Oddometer: 76
I had an 05 LJ that used the same Mercedes 6 sp as the JK. The most common complaint is the first gear issue. You put it in first let out the clutch and bang the shifter goes back to neutral very quickly. After you have this happen a few times, you realize it is you that doesn't have the shifter all the way in first. It's like something binds when you push forward into first and the shifter stops short. Pull back and push forward again and all is good. Once you get used to driving it you realize the shifter isn't going forward all the way.
We purchased a 12' with the auto for my wife, she doesn't like to drive a stick. Just hit 7k and the Jeep is finally starten to loosen up a little. We really enjoy the vehicle. We tow a 2 bike trailer and it does well. The longer wheelbase of the 4 door certainly helps.
jeepkevin is offline   Reply With Quote
Old 10-01-2012, 01:52 PM   #5
GP640
GP640's Avatar
Oddometer: 3,328
I had a 6 speed jk for a few years. The 1st gear issue was repaired on a TSB.
The clutch was on its way at 66,000km and the front axle was staring to leak (for the 8th time)
Other than that, stay outta the mud with it because there is a big opening on the bottom
of the bell housing that'll let crud get up in the clutch. Brilliant design for an off road vehicle
GP640 is offline   Reply With Quote
Old 10-01-2012, 08:37 PM   #6
Tripl Nikl
Tripl Nikl's Avatar
Oddometer: 3,038
Wow! Considering the niche the Wrangler is aimed at--that's a bunch of crap!
Out of curiosity, were you running huge tires? The Dana 44 should be good to go with 35s--at least on early Broncos it was/is.
And that opening? WTF? Can it be fixed with some tubing to make it vent at a higher level or something? Or, what's that opening there for?
Also, if you're planning on going wheeling, it sounds like first is geared to high for the torque available--that's something that'd be worth researching before commiting to the rig or tranny. There's probably a fix out there, like a low-range adapter that can be installed, but I bet that's a $2K solution to the absent torque.
Tripl Nikl is offline   Reply With Quote
Old 10-02-2012, 09:10 AM   #7
GP640
GP640's Avatar
Oddometer: 3,328
I had stock rubber on my Rubicon.
The opening is right on the bottom of the housing and is an oval a couple of inches wide by a half
inch or so. Stoopid design for sure.
I never ran across a solution except for "don't shift in water". My throw out bearing was making
noise and those are a weak link as well with no aftermarket upgrade.
65000 km is way too soon for the problems we had.
Totally disappointed with our Jeep except for those sunny days in the mountains with the top down.
Old 10-02-2012, 06:01 PM   #8
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,471
I just drove a '10 4 door wrangler 1300 miles for a client. It had the 6 cylinder engine in it and IMHO 6th gear was a waste: There's not enough torque in that engine to keep the little car (it isn't a Jeep anymore) moving up highway hills at 65mph, to say nothing of 75+.
Reverse is there, but you need to look for it.
Comfy ride though; good sound system, power seats, A/C etc.
I was underwhelmed.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 10-02-2012, 06:50 PM   #9
Carlo Muro
Supercàzzola
Carlo Muro's Avatar
Oddometer: 2,116
i haven't driven this engine in a Wrangler but I have had it in a couple rental mini-vans lately. I can see where torque would be an issue. Most kitchen appliances have more than this engine. Get it in its power band however and it will SCOOT. I've been itching for a Rubicon with the Pentastar. I do think I'd go the auto route though. I've had a XJ 4.0 5-spd for the past 12 years and I really think autos do wheel better.
Carlo Muro is offline   Reply With Quote
Old 10-02-2012, 08:01 PM   #10
soldierguy
Location: California, sometimes the coast, sometimes Tahoe
Oddometer: 466
I had a '12 Rubicon with the 5-speed automatic. Had to sell it due to quickly worsening medical issues that made driving it painful.
I don't know what some of you are talking about with regard to torque and the Pentastar. The Pentastar has great torque from right off the line...google up some power & torque curves, and you'll see that it makes more torque across a much broader rev band than the 3.8 or the 4.0. Depending on whose torque graphs you look at, you may or may not see the 3.6 at worst produces a few less (as in less than 5) lb-ft of torque just off idle...some graphs I've seen put it dead even. From roughly 1500 rpm on up, the 3.6 makes more.
Now perceptions may be a different story. Because the midrange and top end of the 3.6 are both FAR stronger than either the 3.8 or 4.0, the perception may be that the 3.6 has less torque. Also, Jeep has been putting 3.21 gears in a lot more Pentastar Wranglers than they used to when the 3.8 was around (at least that's what I've seen on dealer lots)...compare a 3.21-equipped Pentastar to a 4.10-equipped 3.8, and the 3.8 will feel stronger off the line, no doubt. Get the 3.73 gears or the 4.10 gears though, and the Wrangler flat out moves, regardless of what's showing on the tach. Lastly, the Pentastar throttle mapping is different than the 3.8. The 3.8 used to jump off the line because a tiny gas pedal tip-in gave a disproportionately large throttle opening...not as bad as some cars out there, but the 3.8 throttle mapping was definitely weighted to make it feel stronger off the line. The Pentastar mapping is quite smooth and gentle at tip-in, to make metering out low-rpm torque at low speeds a very easy thing.
But take it for what it's worth...I drove several 3.8 Wranglers (modded and stock) before buying a 3.6. I hated the 3.8, but the 3.6 is a great engine in my book.
soldierguy
'13 Yamaha Super Tenere - my dream bike
soldierguy is offline   Reply With Quote
Old 10-04-2012, 12:13 AM   #11
discochris
discochris's Avatar
Location: Sometimes the Twin Cities, Sometimes NW Wisconsin
Oddometer: 1,286
I concur. I test drove a 3.8 last year, and was underwhelmed. I now own a 2012 Wrangler Sport 2dr with the 3.6. I've been very impressed with the motor from a performance and mileage standpoint. I'm averaging about 20 mpg and have been quite pleased overall.
discochris is offline   Reply With Quote
Old 10-04-2012, 06:22 PM   #12
flux_capacitor
I know a shortcut!
flux_capacitor's Avatar
Oddometer: 9,619
I bought a 2007 2-door 6-speed manual. I like it a lot. I agree sixth is a waste. I travel a major freeway to work every day and never get outta fifth. Finding reverse is annoying as hell. You really have to move the stick to the right with purpose.
I don't intend to do a ton of mods to it. It'll see duty as a forest road camping machine and daily driver. I think it's cool for that in stock form. Around here I see a lot of people spending a lot of money on accessories to "look the part". I don't get it.
flux_capacitor is offline   Reply With Quote
Old 10-04-2012, 06:43 PM   #13
Mini Trail
n°°b
Oddometer: 2,227
I didn't mean to diss the Pentastar, it is plenty powerfull once it revs. I waited a year to get it mostly for the gas mileage. I use 6th all the time, literally. I drive 100 miles per day and once i get to 6th i lug it around in 6th down to 45 or 40.
Old 10-04-2012, 09:23 PM   #14
jrunberg
Oddometer: 103
Your gears make a HUGE difference in how things feel. It's not just about the engine.
I've got a '05 LJ Rubicon (11" longer than the standard 2 door, but the same otherwise) with 35" tires and it cruises at 45 in 6th. Just lopes along – 4.10 gears really make the difference. Not huge power anywhere but it's a Jeep and I'm fine with it.
For street work it's decently comfortable with Clayton long arms and a 5" lift. Offroad it just goes wherever you point it. If I had to do again I'd (perish the thought) do an auto to give finer control in the steep stuff.
jrunberg is offline   Reply With Quote
Old 10-05-2012, 10:17 AM   #15
131unlimited
Oddometer: 448
I wheel in swamps with a lot of mud and water along with some rock trails in another state when I get the time.
past --
99 TJ with the AX-15 --- 95k -- 5 speed tranny. awesome tranny
2005 LJ ---- 80k ---- 6 speed, zero problems
current --
2007 JK Unlimited rubicon --- 47k ---- 6 speed , zero probs
131unlimited is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:56 AM.
