Old 09-30-2012, 04:43 PM   #1
KaceCoyote OP
Pass the queer more beer
KaceCoyote's Avatar
Oddometer: 5,632
Posi-lock love
http://www.posi-lock.com/
A friend got me hooked on these back in my VW days, and they've ported over well to bikery. They work well, are cheap, and they don't cost 40 fucktons. May not be as totally awesome as splicing shit together with low-temp solder and a Bic lighter, but in my experience its been more practical. Keeps field expedient repairs from becoming headaches down the line.
Am I the only one using these things? Are there alternative uses I am yet to discover beyond their most obvious mundane functions? I'm generally a klutz with wiring, so these things are life savers for me but what about you guys? Likewise, if there's an -even better- product out there clue me in!
When the smoke clear, you can see the sky again
There will be the chopped off heads of leviathan
My friend, they call 'em strangers
Everybody talk to them end up in some danger
-MF Doom, Strange ways
KaceCoyote is offline   Reply With Quote
Old 09-30-2012, 05:43 PM   #2
rbrsddn
3banger
rbrsddn's Avatar
Oddometer: 2,662
They are great. I use them for the front signals, which make it easy to remove bodywork to adjust valves, etc. Way easier than soldering...
rbrsddn is offline   Reply With Quote
Old 10-01-2012, 10:00 AM   #3
ttpete
Rectum Non Bustibus
Oddometer: 5,947
Posi-Taps work well because they penetrate the insulation and seal around the hole made by the spike, preventing corrosion.
15 BMW RnineT
09 Kaw Versys
Times are GMT -7.   It's 04:39 AM.
