Old 10-07-2012, 01:07 PM   #151
bluesman
Oddometer: 3,360
OK...so I've seen it in real life yesterday on Intermot.
It does not look that bad. Kinda bearable if you do not look at 3/4 view. Rear strongly resembles BMWs GSes somehow closer to 800 GS.
Front strongly resembles multistrada with Diavel headlight.
Luggage they show on photos WILL make it very ugly. Without it - MUCH better.
Rest...
They used totally usual DL1000 motor and arrangement in it. Perhaps because it is concept.
Oil rad still hangs low-low, everything still quite exposed. Spacers, rear brake holder - all machined as one-off, you can see it - unpainted alloy with signs of machining.
Cockpit...that's where it gets ugly. It is large dull flat piece of plastic with clocks stuck in the middle surrounded by loads of empty plastic surface. I hope they will do something about it, as it looks kinda...like real cheap car door panel.
Rest - to be tested when available.
I hope it will be all you looking for guys! Best of luck. No sarcasm.
bluesman is offline   Reply With Quote
Old 10-07-2012, 07:55 PM   #152
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,853
Originally Posted by Pecha72 View Post
Actually I wonder, why no manufacturer has made an ADV bike with a “boxed” or enclosed chain drive?? It has only a few small downsides: takes a bit more work to adjust it, and it could make changing tyres a bit harder (that however depends on the solution).
But on the other hand, it has more or less all the upsides: simplicity, weight (the box does not need to weight much at all), and durability fully comparable to a shaft drive (I mean the good ones, that you DON´T need to work on too often!) Plus when it is inside a box, on oil bath and lubricated 100% all the time, it won´t get dirty, and the need to even adjust it becomes very small. So regarding maintenance, it is almost like a well-working shaft drive.
Maybe it is a cost issue on a bike like the DL1000 (but I don´t believe it would be on all current large-capacity allroad-bikes). Also maybe all buyers would not like the looks of it. But if I was looking for a bike to go RTW, this kind of solution would be in one word perfect for me, and I could not care less about its looks.
There used to be enclosed chains on bikes, but that was a long time ago. Maybe the manufacturers don´t actually want the chains to last 40-60 thousand miles afterall, and the average user doesn´t care, if they last 20 or 40 thousand. But on a real RTW-tourer, this would be the way to go.
Here's a good look at the enclosed chain system on my slightly modified XV920 Yamaha.
I rode this on a 13,500 mile round trip and had 0 chain issues. The Shinko tires I used did not do well in mud though.
bk brkr baker is online now   Reply With Quote
Old 10-08-2012, 05:46 AM   #153
M0t0Rider
M0t0Rider's Avatar
Oddometer: 214
Originally Posted by Twilight View Post
Here is the improvement Suzuki needs to do to the concept to make me buy it! (from stromtrooper.com)
Ahhhhh....much better!
M0t0Rider is offline   Reply With Quote
Old 10-08-2012, 07:11 AM   #154
Kawidad
Kawidad's Avatar
Oddometer: 4,977
Sorry, don't agree.
To me, the front end Suzuki uses on the new concept looks like they might have actually done some wind tunnel testing, whereas, we all know about the buffeting from previously built bikes.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 10-08-2012, 10:28 AM   #155
Pecha72
Oddometer: 4,268
Originally Posted by Kawidad View Post
Sorry, don't agree.
There have been much less complaints about the buffeting on the 2012 Wee.
I still think the final 2014 Vee is going to have more resemblance to the newest Wee, than that concept bike has.
Pecha72 is online now   Reply With Quote
Old 10-08-2012, 11:34 AM   #156
2tallnwide
2tallnwide's Avatar
Oddometer: 2,579
After reading all of the looks comments I had to make sure I wasn't in a Harley thread on Road Warriors...
I like the new bike just fine, but it's not one I would trade my '05 Tiger for.
When I do get another adventure TOURING bike it will have a shaft drive.
If you're gonna dish it out make sure it tastes good.
http://www.youtube.com/watch?v=zBkh6lrOfT4
2tallnwide is offline   Reply With Quote
Old 10-08-2012, 12:14 PM   #157
opmike
Choosing to be here.
opmike's Avatar
Oddometer: 343
I really don't understand all the outrage about the design. All adventure bikes are just varying degrees of ugly, and for me, that's part of the charm in some way.
The only thing I'd like to see done differently are a change to dual headlights for both light output and to keep the V-Strom look, and something needs to be done about those passenger pegs. It looks like they'd get bent in a tip over from that head-on shot. Personally, I'd like to see the exhaust hanger/passenger pegs designed as bolt-on components, and not welded to the subframe.
Twilight's photochop was really well done, and I'd like to see something along those lines for the production unit.
"you want to fix the Pledge of Allegiance, put a disclaimer at the end: with liberty and justice for all...must be 18, void where prohibited, some restrictions may apply, not available in all states."
opmike is online now   Reply With Quote
Old 10-08-2012, 01:04 PM   #158
switchback
Eatin' Dirt Since 1982
switchback's Avatar
Oddometer: 1,485
Don't you know, those who don't ride enough have plenty of time to bitch. Shaft vs. chain, beak no beak... it has been said about most others as well. If it performs well we will all be better off having more options to choose from.
David
Wind is strong and cold
Rain blurs the winding road ahead
I live on two wheels
switchback is offline   Reply With Quote
Old 10-08-2012, 04:04 PM   #159
RaY YreKa
Palanquins RTW
RaY YreKa's Avatar
Oddometer: 16,299
The 'concept' front end looks all marketing led, rather than utility led.
It is what is is: MS1200 sells, so make a MS1200-a-like front end. Voila, sales gold!
I guess if you have to hit quarterly sales-targets, then you will latch on to whatever sold well last quarter for your competitor?
Dealers/techs might do well from riders who do 12,000+ miles a year, but for the manufacturers I really doubt they give a fig once the warranty is up.
IBA #40578
shine on, you crazy emo diamond
RaY YreKa is offline   Reply With Quote
Old 10-09-2012, 03:01 PM   #160
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,769
But like I said, I hope I'm wrong.
Just came back to this thread... Man do I like beeing right and see you regretting your words .
Loutre is offline   Reply With Quote
Old 10-10-2012, 03:47 AM   #161
Pecha72
Oddometer: 4,268
If you're referring to a "2013 DL1000", that by your info was published on some French magazine/website in January 2012, that is still wrong. For one thing, it's not coming for 2013. And they never reveal their next year's models in January, because it just would not make any sense. (That an updated DL1000 is coming at some point was not really hard to guess either, when you look at what others were doing). I think the French really had no clue, just speculation.
But don't get me wrong, this could well be my next bike, unless they screw up very badly on something (which I doubt they will).
Old 10-10-2012, 08:40 AM   #162
Nightstrom
Oddometer: 14
Its a good looking bike except for the beak design. While I like the looks of the beak on the Ducati Multi and Triumph Tigers, they need to point it down a hair and reshape it. Wider and more squared off. If BMW's 1200 beak gets any bigger, its going to be like the old locomotives that had the cow catchers on the front. It will just scoop stuff out of your way as you ride down the road.
Nightstrom is offline   Reply With Quote
Old 10-11-2012, 01:33 AM   #163
Paulvt1
Paulvt1's Avatar
Oddometer: 3,597
Here's a bit of footage that shows the bike in the metal. Doesn't look too bad to me.
http://www.motorcyclenews.com/MCN/Ne...12-highlights/
Paulvt1 is offline   Reply With Quote
Old 10-11-2012, 02:06 AM   #164
PeterW
Oddometer: 2,748
Finally a shot from the left side.
What's the lump on the side of the head, just a mount or something more interesting ?.
Pete
PeterW is offline   Reply With Quote
Old 10-11-2012, 11:30 PM   #165
lukasteam
Life is beautiful !!!
lukasteam's Avatar
Oddometer: 523
I like it . It looks different, like nothing else out there. I don't know why some folks say it resembles a GS . You can not say that every bike that has a beak looks like a GS.Beak was way before GS and actually I think Suzuki DR-BIG was the first soft enduro with the beak, love it or hate it . I don't know if it's going to be any off-road worthy though , probably not more then the old DL1000 .
I guess we'll have to wait and see...
Wherever you go , go with all your heart ... Confucius
lukasteam is offline   Reply With Quote
Times are GMT -7.   It's 05:23 AM.
