Old 09-22-2013, 11:59 PM   #706
Paulvt1
Paulvt1's Avatar
Oddometer: 3,566
I do like the dash. Clear and concise. The red is growing on me..
Paulvt1 is offline   Reply With Quote
Old 09-23-2013, 05:34 AM   #707
mitch96
Oddometer: 138
All it needs is cruise control and it would be a lo cost alterntive to the Triumph Explorer or the Yamaha Tenere?, all be it with less power and no shaft drive...
Then again with the money saved you could dress this girl up just the way you like it..
how do you say Akrapovic???
I'll be seeing it in the flesh in Orlando Fla at the MC expo.. Can't wait..
Maybe they will have test rides!!!!!!!!!!!!!!
I noticed that on the dash panel it says to use 95 RON fuel aka hightest or super..........
The cams are not attached to the chain, just idler gears. That would sure make it easier to adj and replace the shims under bucket.. I like it!!
I'm doing so good, I can't stand it!!
mitch96 screwed with this post 09-23-2013 at 05:57 AM
mitch96 is offline   Reply With Quote
Old 09-23-2013, 05:41 AM   #708
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,772
Originally Posted by svs View Post
MC News Australia has a good write up and a shit load of good pictures.. Real bikes being ridden. Looks good.
http://www.mcnews.com.au/2014_Bikes/...000/Intro1.htm
Zapp
"I will not let the White City fall... nor our people fail.” - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 09-23-2013, 05:51 AM   #709
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,772
I previously thought similar, about suspension and clearance [separately].
That was before I went to work on those on my K4 Weestrom.
I had custom forks made [which I still have, btw if anyone wants to try it themselves] that gave me +2" to work with up front, and dogbones to jack up the rear. I'm 6'2" - I stripped it naked up front and mounted a small GPS as speedo etc, mounted a DR headlamp assembly, turn signals etc. and road it for 3 months or so.
What I found was that a big bike just has too much engine etc between the seat and the oil pan unless its a subaru engine like BMW uses... In practicality, the inconvenience of a tall saddle height [I was using the stock DL650 which is pretty low] became more important than whether or not the bashplate got to do what I pay it to do. In rough terrain, stepping a boot down in a hole while trying to push/maneuver out of a jam, the 460lb bike was winning the battle... I began to rethink all that ground clearance [not to mention exacerbation of big bike's natural top-heaviness]. A well-designed skid plate does wonders -
my conclusion was that the ground clearance was overrated assuming the suspension did a good job [mine was beefy and I am not obese]
Originally Posted by AceRider01 View Post
I think 19/17 is okay with an option to for 21/18 but suzuki needs to address 2 real issues to have some real credibity on the these adventure bikes.
1) suspension travel - somewhere at least over 200mm - relatively easy
2) Ground clearance - change the routing of those pipes - add at least another 80mm
these wont make it a true dual purpose and will still be ridden by people who does mostly pavement and gentle unpaved roads but at least it will go where most people are likely to take such a heavy pig too.
ATM it is the softest of all pretend adventure bikes.
Zapp
Old 09-23-2013, 06:19 AM   #710
GrahamD
GrahamD's Avatar
Oddometer: 5,366
If they have done what they said and tuned the motor to work more broadly then that is a plus. Don't worry so much about the HP. It's plenty. It's more about HP in the your riding envelope. If you like spinning motors at red line all day then this will not be for you but if you ride like 90% of people over the age of 17 then it will be a more involving engine and more relaxed if that is your thing.
And while I like the shaft drive, a chain oiler on a good chain can get you some pretty good life even in dust and dirt.
And anyway, poor old Suzuki is stuck being a low cost alternative. I think it is now in their DNA.
But that usually means a great value bike.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 09-23-2013, 06:26 AM   #711
mitch96
Oddometer: 138
Didn't have any luck with mine on the DL650 in Alaska.. Either too much or too little oil on the chain. The gizmo that drips the oil on the chain got tore UP in that harsh environment. Everytime I stopped it was out of shape oiling the ground..
what kind did you use???
Old 09-23-2013, 06:36 AM   #712
GrahamD
GrahamD's Avatar
Oddometer: 5,366
CLS. Big oil reserve, (up to 500ml), temperate compensated, and adjustable on the dash in 10 steps from "off" to "Exxon Valdez". Never let me down.
Old 09-23-2013, 09:02 AM   #713
Kawidad
Kawidad's Avatar
Oddometer: 4,911
Originally Posted by NuckaMan View Post
Oh wow....me likely!!!! On paper, Suzuki has hit almost all the bases!!!! Bravo.
Can't wait to hear the performance numbers and of course the MSRP.
Wire wheel option would be nice.
According to the web:
Max figures
99 HP at 8000 RPM
76 ft/lb at 4000 RPM
(At a peak of 99 HP presumably at the crank, it is at the bottom of the class.)
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is online now   Reply With Quote
Old 09-23-2013, 09:37 AM   #714
Paulvt1
Paulvt1's Avatar
Oddometer: 3,566
MCN UK are saying 59mpg (IMP) and £10,000 GBP. That'll probably be for the base spec one..
http://www.motorcyclenews.com/MCN/Ne...-tech-details/
Paulvt1 screwed with this post 09-23-2013 at 09:42 AM
Old 09-23-2013, 09:49 AM   #715
Rustycage
Oddometer: 3,917
Max figures
99 HP at 8000 RPM
Which class? 1200 yes, but not sure that is the target.
Rustycage is offline   Reply With Quote
Old 09-23-2013, 11:12 AM   #716
Mighty Kentor
Mighty Kentor's Avatar
Oddometer: 255
Wow, the suggested performance specs are exactly what I would have ordered from Suzuki. Broad usable power, less weight, greater range. It's a winner in my books!! I'd love to have one in my garage~
Max figures
99 HP at 8000 RPM
It has no competition in it's class, but if you're comparing it to the million pound S-10, or Triumphs, I'll take the lighter example any day of the week.
It's more fun to ride a slow bike fast than a fast bike slow.
Mighty Kentor is offline   Reply With Quote
Old 09-23-2013, 11:36 AM   #717
svs
All Hands on Deck!
svs's Avatar
Oddometer: 24,982
It has no competition in it's class,.
That's the point..
It's the lightest of the big bikes and the best value.
If a physical fact can produce a psychological state, a psychological state can produce a physical fact... The whole of creation is asleep within the deep of man and is awakened to objective existence by his subconscious assumptions.
svs is offline   Reply With Quote
Old 09-23-2013, 11:58 AM   #718
Pecha72
Oddometer: 4,220
well according to the net, max torque used to be @ 6400 rpm.. that´s promising.
Pecha72 is online now   Reply With Quote
Old 09-23-2013, 12:23 PM   #719
Pablodakar
Oddometer: 117
Suzuki DR350SEX
Suzuki KingQuad 450
Pablodakar is offline   Reply With Quote
Old 09-23-2013, 01:09 PM   #720
Kawidad
Kawidad's Avatar
Oddometer: 4,911
Yeah, that's the class as it stands today. Especially since Suzuki increased the size of the engine slightly. In the world of bike marketing it could easily be considered an 1100 and not a 1000, so 1200 is what it is.
I'm not being critical of Suzuki's decision to keep the displacement around 1000cc instead of upping it like the competition. In the market place Suzuki did (really) good things with the weight, but not so much with the power and displacement. Especially if you consider the Triumph Tiger 800 is making around 94 HP at the crank for less money than the potential selling price of the Strom. If the estimated price figure of 10,000 BGP, which would put it around $16,000 mark is considered and accurate.
As I see it, if Suzuki can bring it to the US market for under $12,000 give or take, it will have a winner. If the price is truly around the 16 large mark, then it will be a dud.
Times are GMT -7.   It's 07:20 AM.
