Old 09-27-2012, 09:01 PM   #1
NortwestRider OP
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,957
Rear tires on the front??.
I'm not sure where to post this but I need a 120/90-17 front adventure/dual sport tire and all I can find ( except for 705's and TKC's) are rear tires.I have heard that if you mount them backwards they work ok for the front??.Anybody done this ??
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is online now   Reply With Quote
Old 09-28-2012, 04:50 AM   #2
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,229
i know of some ppl who run that way,,,, non directional tire is the better option.
2 SPOT is offline   Reply With Quote
Old 09-28-2012, 08:21 AM   #3
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,793
Do-able, but why? For what bike?
If it's a road bike with a 17 that's had a 120/70 road tire on it, the 120/90 has very much taller sidewall and flatter tread. They are not radial design and are tube type, and you lose about 60% of your contact patch.
Personally I think it's a bad idea for a road bike. After you hit the guard rail or go off an embankment you'll wished you would have stuck with the right tire.
I just posted on the 705 thread on the fullbores.
EDIT: Oh, and rim width - the 120/90 tire is for a narrower rim than a roadbike with a 120/70. Lose even more of edge tread. Look for riding past the chicken-strips.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 09-28-2012, 08:37 AM   #4
NortwestRider OP
Oddometer: 3,957
It's a GS500 thats going to Alaska and will see alot of dirt roads.A 120 will fit,I have seen one but it was more of a offroad tire than I want.I might go with the FullBore,if it's like the 705 it's sold as a front ir rear.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 09-28-2012, 08:38 AM   #5
NortwestRider OP
Oddometer: 3,957
The stock tire is a 110,there just isn't any 80/20 tires in that size.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 09-28-2012, 09:11 AM   #6
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,793
The fullbore looks identical, has slightly larger spaces between the treadblocks. The 150/70 is V rated, the smaller tires and fronts are 'S'. Which is fine for the front of your bike.
Most any tire will run on the front, but some tend to be a less rounded profile (rear tires) which can further exacerbate the reduced contact patch issue. Or you ride them completely to the edge.
I think the fullbores would be great for dirt roads. I like them fine on the tiger. Knobbies are better though, maybe a Heidenau or Mefo would work as well - lots of sizes.
EDIT: yeah, just looked up tire sizes for GS500. Odd, came with a 110/70-17. I would run the 120/90 fullbore on it. Bet it would work pretty good. You may have to raise the front fender. Highly likely it won't fit under a low fender. Just don't try to scrape the pegs on the twisties.
browneye screwed with this post 09-28-2012 at 09:18 AM
Old 09-28-2012, 09:51 AM   #7
itsatdm
itsatdm's Avatar
Oddometer: 4,873
I ran an 18" rear on the front of my TDM. As long as you pick one with a rounded profile, it will handle fine. I mounted it as I would on the rear.
If you settle for All Terrain instead of knobbies, you can find one that fits.
Pirelll MT 90 A/T and Kenda make ones. If you want a taller aspect ratio, look at tires with inch measurements. They are as tall as wide. A Shinko 4.60 is an example. Typically you will have to run a tube in those.
http://www.motorcycle-superstore.com...res-Tires.aspx
If you have a radial on the rear, you can run a bias tire on the front, but not the opposite.
You probably know this, but metric tires such as 110/90/17 are 110 mm in width, the second number is a percentage of the first or 99mm in this case. Inch tires are all 100%. A 4.60 would be 116.8/116.8mm. I chose the inch tire. I had modded the rear shock mount to gain ground clearance. The taller front did the same for the front of the bike.
itsatdm screwed with this post 09-28-2012 at 10:03 AM
Old 09-28-2012, 10:05 AM   #8
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,484
I run 120/60/17 sport tire on my GS500 and a 120/70 or bigger will rub the fender in a dual sport or offroad tire.I solved this by using a Bandit 400/600 front fender.It's still close.I now run a Katana 750 front end which has the same clearance issues.
Bandit 400/600 front fender on a Katana 750 front end running a 120/60.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 09-28-2012, 10:34 AM   #9
NortwestRider OP
Oddometer: 3,957
I will run a matching rear tire to the front.I might also mount a high fender
(supermoto style ) but I will keep the fork brace and just raise it up.It's
My wifes bike and she is NOT a knee dragger !!.I looked into the MT90 and Kenda 761? And I think they are both tube type.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 09-28-2012, 11:03 AM   #10
mustang
Lurker Extraordinaire
mustang's Avatar
Oddometer: 636
it works just fine , a 120 17 shinko 705 mounted backwards on the front . and mounted tubeless to boot ...........the sky didn't fall , and life was good
mustang is offline   Reply With Quote
Old 09-28-2012, 11:09 AM   #11
Dave.0
Dave.0's Avatar
Oddometer: 784
dunlop 616 come in 17 inch front and rear sizes, and although it is marketed as a sport tire, it does very well on hard pack dirt/gravel
Dave.0 is offline   Reply With Quote
Old 09-28-2012, 11:11 AM   #12
NortwestRider OP
Oddometer: 3,957
I think I will go with the FullBore,I had 2 705's come apart on the front of my Vstrom.How many miles did you get out of the 705 on the front ??.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 09-28-2012, 11:56 AM   #13
NortwestRider OP
Oddometer: 3,957
I just looked at the full bore website and they don't list a 120 so I guess I will take my chances with another 705 !!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 09-28-2012, 12:22 PM   #14
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,819
Me too, Kenda K761, has a good profile, sticks better on the street than a Pirelli MT60, my Kenda is not mounted backwards, mounted it per the rotation arrow
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 09-28-2012, 01:00 PM   #15
NortwestRider OP
Oddometer: 3,957
Is the Kenda a tube type ??.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Times are GMT -7.   It's 12:35 PM.
