Old 10-02-2012, 04:53 AM   #1
rjsurfer OP
Oddometer: 207
Flat spotting rear tires getting old
I ride strictly on the road for commuting and both my old Vstrom and my DRZ400SM always flatspot the rear tires after 6,000-7,000 miles, fronts always get 13k or so. I'm very conscientious about maintaining tire pressure, and going above or below the factory specs for tire pressure, makes no difference. Plus the rear tires are twice as wide as the fronts so you would think they would at least wear out more evenly.
It seems such a waste because the sides of the tires still have almost all the rubber left on them. Can anyone recommend a good tire designed to hold up better on the highway?
Please, no comments on riding harder or being more aggressive these are commuter bikes ridden on straight highways
Ron W.
DRZ 400SM
DL-650 Gone but not forgotten
rjsurfer is offline   Reply With Quote
Old 10-02-2012, 04:55 AM   #2
LngRidr
Oddometer: 180
Switch to a car tire.
Jon Kohler
sent from my iPhone
Jon Kohler
Colbert, GA
2015 KLR 650
1980 Harley-Davidson FXEF
IBA# 24562
LngRidr is offline   Reply With Quote
Old 10-02-2012, 05:02 AM   #3
sierraoffroad
sierraoffroad's Avatar
Oddometer: 1,339
go with metzler marathon. they are spendy, but will last over 10k miles on your vstrom and drz
2013 Super Tenere
2004 Yamaha Wr250f
sierraoffroad is offline   Reply With Quote
Old 10-02-2012, 05:34 AM   #4
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,964
+1
I have had great luck with the Metz 880. Long lasting 12k+ on big heavy bikes (R1150RT). Good stick, both wet and dry
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is offline   Reply With Quote
Old 10-02-2012, 09:19 AM   #5
rjsurfer OP
Oddometer: 207
Looked at the sizing on the Metzler nothing in my 17" size range.
Ron W.
DRZ 400SM
Old 10-02-2012, 10:33 AM   #6
fast4d
Oddometer: 2,401
PR2 or PR3
they go quite a while before they flat spot and handling doesn't seem to be affected much.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 10-02-2012, 10:38 AM   #7
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,313
Sounds like your machines spend most of their time upright. Your tire wear is normal for those conditions.
Best advice; do track days or find a longer lasting tire.
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 10-02-2012, 11:39 AM   #8
TwoShots
Vagabond
TwoShots's Avatar
Oddometer: 1,448
You just gave me a flashback to a garage guy who once told me I needed to "lean over more" while riding. That way I would have less of a "flat spot."
I think he forgot we live in UT.
TwoShots is offline   Reply With Quote
Old 10-03-2012, 11:48 AM   #9
thetable
thetable's Avatar
Oddometer: 1,446
Originally Posted by fast4d View Post
PR2 or PR3
This!
My worst flat spot torture test of PR2s was: 1600 miles of slab to Denver at super-legal speeds, on a C14, no flat spot. Couple days of twisties, then another 1200 miles of slab to Ann Arbor. Was just able to feel the flat spot touching the tire with my hand in Ann Arbor. Another 500 miles of slab to Maryville, TN and the flat spot was just barely visible.
I'm running PR3s exclusively now, and they wear pretty similarly.
Unless you are dragging your front brakes all the time, the rear is going to wear out faster. You are always loading the rear any time you are maintaining speed or accelerating.
thetable is online now   Reply With Quote
Old 10-03-2012, 12:12 PM   #10
Woland
Wannabe adventurer
Woland's Avatar
Oddometer: 227
PR3's. Got almost 12k out of a set on my R1200R. By then the rear was pretty flat ;) But the wear pattern didn't impact handling that much and came on so gradual you'll have plenty of time getting used to it :)
Woland is offline   Reply With Quote
Old 10-03-2012, 04:34 PM   #11
rjsurfer OP
Oddometer: 207
OP back here, decided to go with a 150/70x17 Pilot Road 3.
Seemed like the consensus best in breed for highway touring.
Ron W.
DRZ 400SM
Old 10-04-2012, 05:05 PM   #12
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,555
I know that if I ever end up with a bike that can fit one - while I'm still living in south Florida - I'm going to run a car tire on the rear in that same situation. Flat spotting that fast means a lot of straight-up commuting, and I sure don't need sportbike-handling capability out of a commuter. Last year, when I did over 20k miles of motorcycle commuting, I would have used a car tire if one fit the bike I was riding.
Mambo Dave is offline   Reply With Quote
Times are GMT -7.   It's 05:58 PM.
