Old 10-13-2012, 07:41 AM   #31
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,347
Originally Posted by KTM450SX View Post
I actually have a bunch of RC trucks and Helicopters and a nice RC balance charger, that does Lipo, LIfe, NIMH, Nicad
How many cells are in the shorai? is there a balance plug I could use? ( My charger will balance up to 6 cells ). from .1 to 8amp charge rate.
If I could find a balance plug, I could at least try it see if I can bring it back.
I'm assuming I will have to charge it like a regular RC battery .. Plug the main +/- wires in, and additionally plug the balance port in ( if there is one? )
Hey there, I PM'd you but basically with any of the starter batteries you are balancing only banks of three 3.3 volt cells either cylindrical or prismatic to make 13.2 at basically 2.3 amp hour. Double the cell banks in parallel and your numbers just add by 2.3 to get the amp hours. 6.9 amp hour = 3 cell banks of 4 cells, so = 12 cell battery. As I said earlier, alot of the specs of these batteries are BS.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 10-23-2012, 07:13 PM   #32
KTM450SX OP
Oddometer: 263
Well I could not resurrect my battery...its done.
So I bought another one and the charger UGG.
All working now! now that i have the propper charger should be fine, although I do need to figure out what is leeching power while it sits. the clock cant possibly drain that big old battery in 6 months can it?
Anyway Super Enduro is back in action and ready for a trip this weekend freezing nuts...hopefully the snow isn't too bad lol.
2008 KTM 250XC
2007 KTM 950 SE
2005 YZ 125 the mini braaaaaaap
KTM450SX is offline   Reply With Quote
Old 10-23-2012, 07:58 PM   #33
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,347
Likely some kind of electrical fault. I would get it checked or you may end up with another boat anchor for a battery.
Old 10-28-2012, 08:21 PM   #34
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,347
Originally Posted by LukasM View Post
Not that you would know anything about it, but when could we approximately expect the next gen stuff to come to the market?
Now:
First install in a KTM 990 drop in.
Old battery as it sits in rubber tray Weight 8.6 lbs
New battery comes with front mount terminal adapters and drops into tray with no need for spacers. Weight 2.2 lbs
This also has the built-in BMS balance and protection circuit which is why it has a full 2 year warranty.
Old 10-28-2012, 08:30 PM   #35
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,162
You can look for the drain on the system, pull the fuses and then put them back in one at a time you will find the short if there is one causing the drain that will help you locate the circuit it is on.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
WWW.DSM8.whereamiriding.com
DSM8 is offline   Reply With Quote
Times are GMT -7.   It's 08:43 PM.
